I'm struggling to make state change detection on a rotary switch work.
Hello everyone. I usually don't like to ask for help, but I'm at a total loss.
Basically I'm trying to figure out a way to detect a change on a 8-position rotary switch. Here is the setup: A rotary switch, with one common connected to ground. And all 8 pins connected to a mega board. I need some relatively simple way to detect when one of those 8 pins changes it's state, After the State change has been detected, The code should check what position the rotary is at.The rotary switch is a non shorting. so there is a small period where all pins will be floating I've tried to implement the included example program with no success. The pins I use for the Positions are 28, 30, 32, 34, 36, 38, 40, 42. All of the mega boards Interrupt pins are reserved. My programming experience is Intermediate.
inrg:
Post the code you're tried so far. Use Code Tags.
If the input pins are set for INPUT_PULLUP that should not matter. Pins will always read HIGH unless the rotary switch has switched them to ground, then they will read LOW.
