const int numReadings = 10;
const int numPorts = 2;
long numberofReadings=numReadings;
int readings[numReadings][numPorts]; // the readings from the analog input ports
int readIndex[numPorts];// the index of the current reading
I am trying to set up a two dimensional array to store readings from external sensors.
I have made the dimensions of the array numReadings and numPorts constants which will be used throughout the program calculating averages etc. I'm using small number to start with 10 reading and two sensors but this will increase once I have things working.
However my compile is failing at the first step saying:-
"declaration of 'readings' as multidimensional array must have bounds for all dimensions except the first"
which a) I don't understand and b) my code looks to be similar to other code segments in tutorials
Apologies in advance if this is a dumb question but I have tried and can't see my way out of this.
AWOL:
Post the code you're having problems with and the error messages you're seeing.
I rather thought I had done as you suggest?
The compiler is highlighting the fourth line down.
I can't see how to copy the actual error message in orange. How is this done?
The full code
is
//set up the global variables
float total[numPorts]; // the running totals for each port
float average[numPorts]; // the average for each port
// initialize serial:
analogReference(EXTERNAL);
InitArray(readings,numReadings,numPorts); //call function to pre-fill the arrays
average= GetNewAverage(readings, numReadings,numPorts);
// send it to the computer as ASCII digits
Serial.print(average);
Serial.print(" ");
delay(1000); // delay in between reads for stability
Serial.println(" ");
void InitArray(int readings[][],int nubReadings, int numPorts){
// initialize all the readings to an initial read value from each port
for (int j=0; j< numPorts; j++){
int initReading=analogRead(j);
for (int i = 0; i < numReadings; i++) readings[i][j] = initReading;
total[j]=numberofReadings*initReading;
average[j]=initReading;
float GetNewAverage(int readings[][], int numReadings, int numPorts){
for (int j=0;j<numPorts; j++){
// subtract the last reading:
total = total - readings[readIndex][j];
// read from the sensor:
readings[readIndex][j] = analogRead(j);
// add the reading to the total:
total = total + readings[readIndex][j];
// advance to the next position in the array:
readIndex = readIndex + 1;
// if we're at the end of the array...
if (readIndex >= numReadings) {
// ...wrap around to the beginning:
readIndex = 0;
and the error messages are:
Func7_2_dimensional_array:7: error: declaration of 'readings' as multidimensional array must have bounds for all dimensions except the first
Func7_2_dimensional_array:8: error: declaration of 'readings' as multidimensional array must have bounds for all dimensions except the first
Func7_2_dimensional_array.ino: In function 'void setup()':
Func7_2_dimensional_array:19: error: invalid conversion from 'int ()[2]' to 'int'
Func7_2_dimensional_array:7: error: too many arguments to function 'void InitArray(int, int)'
Func7_2_dimensional_array:19: error: at this point in file
Func7_2_dimensional_array.ino: In function 'void loop()':
Func7_2_dimensional_array:23: error: invalid conversion from 'int ()[2]' to 'int'
Func7_2_dimensional_array:8: error: too many arguments to function 'float GetNewAverage(int, int)'
Func7_2_dimensional_array:23: error: at this point in file
Func7_2_dimensional_array:23: error: incompatible types in assignment of 'float' to 'float [2]'
Func7_2_dimensional_array:25: error: call of overloaded 'print(float [2])' is ambiguous
C:\Documents and Settings\RCM\Desktop\Calorimeter development environment\arduino-1.0.5\hardware\arduino\cores\arduino/Print.h:58: note: candidates are: size_t Print::print(char)
C:\Documents and Settings\RCM\Desktop\Calorimeter development environment\arduino-1.0.5\hardware\arduino\cores\arduino/Print.h:59: note: size_t Print::print(unsigned char, int)
C:\Documents and Settings\RCM\Desktop\Calorimeter development environment\arduino-1.0.5\hardware\arduino\cores\arduino/Print.h:60: note: size_t Print::print(int, int)
C:\Documents and Settings\RCM\Desktop\Calorimeter development environment\arduino-1.0.5\hardware\arduino\cores\arduino/Print.h:61: note: size_t Print::print(unsigned int, int)
C:\Documents and Settings\RCM\Desktop\Calorimeter development environment\arduino-1.0.5\hardware\arduino\cores\arduino/Print.h:62: note: size_t Print::print(long int, int)
C:\Documents and Settings\RCM\Desktop\Calorimeter development environment\arduino-1.0.5\hardware\arduino\cores\arduino/Print.h:63: note: size_t Print::print(long unsigned int, int)
Func7_2_dimensional_array.ino: At global scope:
Func7_2_dimensional_array:30: error: declaration of 'readings' as multidimensional array must have bounds for all dimensions except the first
Func7_2_dimensional_array:39: error: declaration of 'readings' as multidimensional array must have bounds for all dimensions except the first
Func7_2_dimensional_array.ino: In function 'float GetNewAverage(int, int)':
Func7_2_dimensional_array:42: error: invalid types 'int [10][2][int [2]]' for array subscript
Func7_2_dimensional_array:44: error: invalid types 'int [10][2][int [2]]' for array subscript
Func7_2_dimensional_array:46: error: invalid types 'int [10][2][int [2]]' for array subscript
Func7_2_dimensional_array:48: error: incompatible types in assignment of 'int*' to 'int [2]'
Func7_2_dimensional_array:50: error: ISO C++ forbids comparison between pointer and integer
Func7_2_dimensional_array:52: error: incompatible types in assignment of 'int' to 'int [2]'
9fingers:
If you had, do you really think I would be asking?
Your problem is "readings" in the function prototype - you need to tell the compiler the size of the second dimension (the "stride") of the array.
Also, "nubReadings" is not "numReadings"
The error suggests that numPorts is not declared somewhere but haven't I set is as a global in line 2?
average= GetNewAverage(readings);
Serial.print(" ");
void InitArray(int readings[][numPorts]){
float GetNewAverage(int readings[][numPorts]){
readIndex = 0;
errors:
Func7_2_dimensional_array:7: error: 'numPorts' was not declared in this scope
Func7_2_dimensional_array:8: error: 'numPorts' was not declared in this scope
Func7_2_dimensional_array:7: error: too many arguments to function 'void InitArray()'
Func7_2_dimensional_array:8: error: too many arguments to function 'float GetNewAverage()'
Func7_2_dimensional_array.ino: In function 'float GetNewAverage(int ()[2])':
Func7_2_dimensional_array:42: error: invalid types 'int ()[2][int [2]]' for array subscript
Func7_2_dimensional_array:44: error: invalid types 'int ()[2][int [2]]' for array subscript
Func7_2_dimensional_array:46: error: invalid types 'int ()[2][int [2]]' for array subscript
The compiler is right. A const int is a variable. Array sizes must be declared with hard coded numbers (except optionally the first, if you have initializers).
Instead of
so (?) using #define means everytime I refer to numPorts, the compiler inserts 2
But it seems to want a "," or "..." and I don't follow that.
Sorry to be a pain
Bob
#define numReadings 10
#define numPorts 2
Serial.print(" ");
void InitArray(int readings[][numPorts],int numReadings, int numPorts){
float GetNewAverage(int readings[][numPorts], int numReadings, int numPorts){
readIndex = 0;
errors:
Func7_2_dimensional_array:8: error: expected ',' or '...' before numeric constant
Func7_2_dimensional_array:9: error: expected ',' or '...' before numeric constant
Func7_2_dimensional_array:8: error: too many arguments to function 'void InitArray(int ()[2], int)'
Func7_2_dimensional_array:16: error: at this point in file
Func7_2_dimensional_array:9: error: too many arguments to function 'float GetNewAverage(int ()[2], int)'
Func7_2_dimensional_array:20: error: at this point in file
Func7_2_dimensional_array:20: error: incompatible types in assignment of 'float' to 'float [2]'
Func7_2_dimensional_array:22: error: call of overloaded 'print(float [2])' is ambiguous
Func7_2_dimensional_array:27: error: expected ',' or '...' before numeric constant
Func7_2_dimensional_array:36: error: expected ',' or '...' before numeric constant
Func7_2_dimensional_array.ino: In function 'float GetNewAverage(int ()[2], int)':
Func7_2_dimensional_array:39: error: invalid types 'int ()[2][int [2]]' for array subscript
Func7_2_dimensional_array:41: error: invalid types 'int ()[2][int [2]]' for array subscript
Func7_2_dimensional_array:43: error: invalid types 'int ()[2][int [2]]' for array subscript
Func7_2_dimensional_array:45: error: incompatible types in assignment of 'int*' to 'int [2]'
Func7_2_dimensional_array:47: error: ISO C++ forbids comparison between pointer and integer
Func7_2_dimensional_array:49: error: incompatible types in assignment of 'int' to 'int [2]'
I'll pick up your points later please Ray L and AWOL
Firstly who is correct out of AWOL and BobKay
Should I be using
int const numPorts =2;
or
#define numports 2
I can then sort that out and move on to the other points
I will also get one function working first and use that the inform changes to the second function.
small steps at a time!
Most compilers are not going to like that. If the compiler did what you're trying to do with that statement, it would move the array to memory location 0. My guess is that there's some pretty important stuff already stored there.
The compiler shouldn't allow that, and will give an invalid lvalue assignment error
I've cut the code down to one function and one call in set up and nothing in loop()
to keep it simple.
It may now be more a case of me not understanding function calls properly?
we now have
const int numReadings =10;
const int numPorts =2;
void InitArray(int readings[][numPorts],numReadings,numPorts){
and Errors:
Func9_2_dimensional_array:7: error: 'numPorts' was not declared in this scope
Func9_2_dimensional_array:7: error: 'numReadings' has not been declared
Func9_2_dimensional_array:7: error: 'numPorts' has not been declared
Func9_2_dimensional_array.ino: In function 'void setup()':
Func9_2_dimensional_array:17: error: invalid conversion from 'int (*)[2]' to 'int'
Func9_2_dimensional_array:7: error: too many arguments to function 'void InitArray(int, int)'
Func9_2_dimensional_array:17: error: at this point in file
Func9_2_dimensional_array.ino: At global scope:
Func9_2_dimensional_array:22: error: 'numReadings' is not a type
Func9_2_dimensional_array:22: error: 'numPorts' is not a type
AWOL:
Which is why I said most compilers won't like that. It's trying to replace a constant lvalue. To a beginner, which is easier to understand: The compiler won't like that, or You're trying to reassign a constant lvalue? A beginner probably doesn't even know what an lvalue is.
