what im trying to do is make a code that tells the arduino and the sd card shield to open or create a .txt then after the arduino opens or creates the file to then read the code Random() (that i found on the reference page) and put the results in the .txt file so then later on i could save those numbers.
this is the code i have so far:
#include <SD.h>
File myFile;
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
Serial.print("Initializing SD card...");
// On the Ethernet Shield, CS is pin 10. It's set as an output by default.
// Note that even if it's not used as the CS pin, the hardware SS pin
// (10 on most Arduino boards, 53 on the Mega) must be left as an output
// or the SD library functions will not work.
pinMode(10, OUTPUT);
if (!SD.begin(10)) {
Serial.println("initialization failed!");
return;
Serial.println("initialization done.");
// open the file. note that only one file can be open at a time,
// so you have to close this one before opening another.
myFile = SD.open("test.txt", FILE_WRITE);
// if the file opened okay, write to it:
if (myFile) {
Serial.print("Writing to test.txt...");
myFile.println(
This is where im having trouble the program keeps saying that im missing this ; be for the { but when i add it, the program then says it cant read that part of the code
randomSeed(analogRead(0));
// print a random number from 0 to 299
randNumber = random(300);
Serial.println(randNumber);
delay(50);
// close the file:
myFile.close();
Serial.println("done.");
// if the file didn't open, print an error:
Serial.println("error opening test.txt");
// re-open the file for reading:
myFile = SD.open("test.txt");
if (myFile) {
Serial.println("test.txt:");
// read from the file until there's nothing else in it:
while (myFile.available()) {
Serial.write(myFile.read());
// close the file:
myFile.close();
please help
p.s the pinmode is 10 because i have the seed studio sheild
