#include <dht11.h>
#define DHT11PIN 4
int greenLED = 13;
int redLED = 12;
dht11 DHT11;
pinMode(13, OUTPUT); // green LED
digitalWrite(13, LOW);
pinMode(12, OUTPUT); // red LED
digitalWrite(12, LOW);
int chk = DHT11.read(DHT11PIN);
int input = digitalRead(DHT11PIN);
if (DHT11PIN == 0)
digitalWrite(13, HIGH);
else (DHT11PIN > 0);
digitalWrite(12, HIGH);
Serial.print("Humidity (%): ");
Serial.println((float)DHT11.humidity, 2);
Serial.print("Temperature (C): ");
Serial.println((float)DHT11.temperature, 2);
delay(5000);
Welcome to the forum
#define DHT11PIN 4
if (DHT11PIN == 0)
Because of the first statement the second one will never be true
Did you mean to trad the state of the pin rather than its value ?
just to add to the good point of @UKHeliBob (in case it's needed)
that's the temperature you want to compare to 0 (the one you print)
that's probably not needed
You may also want to turn off the LEDs at some point. If they ever do get written HIGH, nothing will change that.
a7
...and lose the semicolon when you've fixed the condition.
and don't forget the if
