IM TRYING TO HAVE THE SECOND LED TO HAVE A DELAY AND TURN OF AND TURN ON LED 3
int buttonPin = 8;
int fi = 2; int se = 13; int th = 3;
int buttonPushCounter = 0; int buttonState = 0; int lastButtonState = 0;
void setup() { Serial.begin(9600); pinMode(buttonPin, INPUT); pinMode(fi, OUTPUT); pinMode(se, OUTPUT); pinMode(th, OUTPUT);
digitalWrite(fi, HIGH); digitalWrite(se, HIGH); digitalWrite(th, HIGH); delay(300); digitalWrite(fi, LOW); digitalWrite(se, LOW); digitalWrite(th, LOW); }
void loop() { digitalWrite(fi, HIGH); // read the pushbutton input pin: buttonState = digitalRead(buttonPin);
// compare the buttonState to its previous state if (buttonState != lastButtonState) { // if the state has changed, increment the counter if (buttonState == HIGH) { // if the current state is HIGH then the button // wend from off to on: buttonPushCounter++; if(buttonPushCounter == 9){ buttonPushCounter = 2;} Serial.println("on"); Serial.print("number of button pushes: "); Serial.println(buttonPushCounter); } else { // if the current state is LOW then the button // went from on to off: Serial.println("off"); } } // save the current state as the last state, //for next time through the loop lastButtonState = buttonState; switch(buttonPushCounter) {
case 1: digitalWrite(fi, LOW); digitalWrite(se, HIGH); delay(500); digitalWrite(se, LOW); digitalWrite(th, LOW);
} } Serial.println(buttonState); }
Please edit your post and add code tags around your code
Type
** **[code]** **
before the code
Type
** **[/code]** **
after the code
Please rephrase your question; you have three LEDs. What needs to happen when you push the button. And what does your code currently do when you push the button?
so I have three LED and one PUSHBUTTON LED #1 is HIGH BOTTON PRESS LED #1 should turn OFF and LED #2 should come on then LED #2 should have a delay of 1000 turn off and the LED #3 should come on
int buttonPin = 8;
int fi = 2;
int se = 13;
int th = 3;
  delay(300);
   digitalWrite(fi, HIGH); // Door fully close.
      if(buttonPushCounter == 3){ buttonPushCounter = 1;}
    else {
    case 1:
    case 2:
    case 3:
You have an extra set of brackets in the switch statement.
Have a look at the demo Several Things at a Time which illustrates the use of millis() to manage timing without blocking.
...R
