this is the error I'm getting, the code is below it...
/Users/mikmaster63/Documents/Arduino/sketch_jul22a_hum_lcd/sketch_jul22a_hum_lcd.ino:13:23: error: expected primary-expression before ')' token
DHT11 HT(sensePin,Type);
/Users/mikmaster63/Documents/Arduino/sketch_jul22a_hum_lcd/sketch_jul22a_hum_lcd.ino:18:7: error: expected initializer before '+' token
int dt+1000;
/Users/mikmaster63/Documents/Arduino/sketch_jul22a_hum_lcd/sketch_jul22a_hum_lcd.ino: In function 'void setup()':
/Users/mikmaster63/Documents/Arduino/sketch_jul22a_hum_lcd/sketch_jul22a_hum_lcd.ino:23:6: error: 'class DHT11' has no member named 'begin'
HT.begin();
/Users/mikmaster63/Documents/Arduino/sketch_jul22a_hum_lcd/sketch_jul22a_hum_lcd.ino: In function 'void loop()':
/Users/mikmaster63/Documents/Arduino/sketch_jul22a_hum_lcd/sketch_jul22a_hum_lcd.ino:32:3: error: 'tempf' was not declared in this scope
tempf=HT.readTemperature(true);
/Users/mikmaster63/Documents/Arduino/sketch_jul22a_hum_lcd/sketch_jul22a_hum_lcd.ino:32:3: note: suggested alternative: 'tempF'
tempF
/Users/mikmaster63/Documents/Arduino/sketch_jul22a_hum_lcd/sketch_jul22a_hum_lcd.ino:32:32: error: no matching function for call to 'DHT11::readTemperature(bool)'
In file included from /Users/mikmaster63/Documents/Arduino/sketch_jul22a_hum_lcd/sketch_jul22a_hum_lcd.ino:1:0:
/Users/mikmaster63/Documents/Arduino/libraries/DHT11/src/DHT11.h:53:7: note: candidate: int DHT11::readTemperature()
int readTemperature();
/Users/mikmaster63/Documents/Arduino/libraries/DHT11/src/DHT11.h:53:7: note: candidate expects 0 arguments, 1 provided
exit status 1
Compilation error: expected primary-expression before ')' token
#include "DHT11.h" #define Type DHT11 #include <LiquidCrystal.h>
int rs=7;
int en=8;
int d4=9;
int d5=10;
int d6=11;
int d7=12;
LiquidCrystal lcd(rs,en,d4,d5,d6,d7);
int sensePin=2;
float humidity;
float tempC;
float tempF;
int setTime=500;
int dt+1000;
HT.begin();
delay(setTime);
lcd.begin(16,2);
Serial.print("Humidity: ");
Serial.print(humidity);
Serial.print("% Temperature ");
Serial.print(tempC);
Serial.print(" C ");
Serial.print(tempF);
Serial.print(" F ");
As others have pointed out this is the offending line. I found the video 50
Paul does use that line but it is an unfortunate use of “Type” which may have worked in an older version of the IDE, but doesn’t in a newer version.
Try replacing the word “Type” with something like “Model” in both places.
“Type” is probably a reserved word and shouldn’t be use for a constant or variable name.
When debugging it is best to address the first error reported first. The first error can cause cascading errors further along.
Edit: the line of code is discussed around 15:00 in the video. FYI.
Can anyone explain me how this works?
Type is replaced by DH11 by the #define.
But DH11 is not a C strung and not a number...
So: what type does the library expect?
Is it an enum that is defined inside the library?
Ah, thanks for your explanation.
I did not see this practice earlier.
It seems like a good way of making a library flexible.
I do not really see the pros of the #define Type DHT11. To me it is just obfuscating...
Here the idea is to put at the top of the sketch things that might change, so they can be easily edited.
Instead of needing to find the constructor (or even know about it) and replace the official constant there.
The writer is more or less forced to use # define for its text substitution, as we see, without looking one would not know that DHT22 was an integer to write, in the modern fashion
const byte Type = DHT22;
The worst is sketches that appear to have gone to enough trouble to make such changes, but fail somehow, so changing manifest constants is not sufficient.
In the end there is nothing better than knowing how to read code, and working with good code to begin with whether borrowed or stolen.
Type is definitely not a good name....
SensorType would heve been immediately clear...
Type also is used as part of the C language (typedef). Int float etc. are also types...
Actually, neither type nor Type is a reserved word. We can forgive the Ice Tea guy for not knowing better than to just avoid it so there is no confusion nor wasted words on the matter.
Here it is clear. It gets unclear when it is in a #define at the top of a file where it is unclear what kind of type. So, I think it is up to OP to keep it or to rename Type to SensorType.
