I'm trying to make a random answer generating machine but when I click the button nothing happens, do you know what is wrong?
#include <LiquidCrystal.h>
char* ANESWER {"yes", "no", "maybe", "why?", "____ you!"};
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
const int button = 8;
  lcd.begin(2, 16);
  randomSeed(ANESWER[0, 4]);
  pinMode(button, INPUT_PULLUP);
  int read = digitalRead(button);
  if (read == HIGH) {
    lcd.setCursor(0, 3);
    lcd.print(ANESWER[0, 4]);
    delay(5000);
    lcd.clear();
  }else{
  lcd.clear();
Uses a push button connected to pin 8. Also I used a 1602 16x2 LCD.
Your code has many problems- it does not compile.
First, when you post code USE CODE TAGS. When you paste your code highlight it and click on </>.
Next, Before you copy the code, use CTRL T in the IDE to properly format it.
Do not use a word processor like MS Word. It completely screws up the punctuation of the code.
Right off the bat - you have not properly formatted the char array "ANESWER".
You have not provided a schematic, but the line:
pinMode(button, INPUT);
Should probably be
Are you trying to simulate a politician?
(sorry I couldn't help myself)
:+1: :+1: :+1:
Hello
try this sketch. You have to merge the LCD , change the input pin and than random answer generating machine shall works.
#define ProjectName "I’m trying to make a  but when I click the button nothing happ"
struct ANSWERBUTTON {
  byte pin;
  bool state;
  String answer[5];
} answerButton {A0, 0, {"yes", "no", "maybe", "why", "___you!"}};
const int heartBeat {
  LED_BUILTIN
void setup() { // put your setup code here, to run once:
  Serial.print("File   : "), Serial.println(__FILE__);
  Serial.print("Date   : "), Serial.println(__DATE__);
  Serial.print("Project: "), Serial.println(ProjectName);
  pinMode (heartBeat, OUTPUT);
  pinMode (answerButton.pin, INPUT_PULLUP);
  Serial.println(F(".\nlet´s go! "));
void loop() { // put your main code here, to run repeatedly:
  digitalWrite(heartBeat, millis() / 500 % 2);
  static unsigned long debounceMillis;
  if (millis() - debounceMillis >= 50) {
    debounceMillis = millis();
    bool state = !digitalRead(answerButton.pin);
    if (answerButton.state != state) {
      answerButton.state = state;
      if (answerButton.state) Serial.println(answerButton.answer[random(0,5)]);
thanks!
is this better?
thanks!!!
Thank you
IN 1775 English inventor Alexander Cumming was granted the first patent for a fluid toilet
Not to be confused with his much later successor, Thomas Crapper.
? That's not a random answer
No, it's a very regular answer.
I guess in the end, this thread was not a random answer generator.
@kv2rules sometimes it is easier to have more variables.
For example, make first a variable to get a random number, then use it for the array.
int randomIndex = random( 0, NUM_ANSWERS);
lcd.print( answerTable[randomIndex]);
This is an example with a single button.
LiquidCrystal lcd( 12, 11, 5, 4, 3, 2);
const int buttonPin = 8;
int lastButtonState;
#define NUM_ANSWERS 7
const char * answerTable[NUM_ANSWERS] =
  "yes",
  "no",
  "maybe",
  "why?",
  "tomorrow",
  "I don't know",
  "ask new question",
  lcd.begin( 2, 16);
  lcd.setCursor( 0, 0);
  lcd.print( "Ask a question");
  lcd.setCursor( 0, 1);
  lcd.print( "and press button");
  delay( 2000);
  lcd.clear();
  pinMode( buttonPin, INPUT_PULLUP);
  // Try to get a random start by using the noise of the analog input(s)
  long seed = 12345678L + analogRead(0) + analogRead(1) + analogRead(2);
  randomSeed( seed);
  lastButtonState = digitalRead( buttonPin);
  int read = digitalRead( buttonPin);
  if( read != lastButtonState)
    lastButtonState = read;
    if( read == LOW)               // low when button is pressed
      lcd.setCursor( 0,0);
      delay( 4000);
      lcd.clear();
The sketch in Wokwi:
This project is of course, called the "Magic Eight Ball". :grin:
