Hi guys, i am trying to make an earthquake detector that activates the buzzer when it detects movement and if there is still movement after 5 seconds it will start the relay, if the movement stops before 5 seconds then the system will not start the relay.
I am still a newbie in programming and this is all the code i can come up with.
i am using ADXL 335 accelerometer sensor and arduino uno.
#define buzzer 12 // buzzer pin
#define led 13 //led pin
#define relay 11 // relay pin
#define x A0 // x_out pin of Accelerometer
#define y A1 // y_out pin of Accelerometer
#define z A2 // z_out pin of Accelerometer
/*variables*/
int xsample=0;
int ysample=0;
int zsample=0;
long start;
unsigned long startMillis;
unsigned long currentMillis;
const unsigned long period = 5000;
/*Macros*/
#define samples 50
#define maxVal 20 // max change limit
#define minVal -20 // min change limit
pinMode(buzzer, OUTPUT);
pinMode(led, OUTPUT);
for(int i=0;i<samples;i++) // taking samples for calibration
xsample+=analogRead(x);
ysample+=analogRead(y);
zsample+=analogRead(z);
xsample/=samples; // taking avg for x
ysample/=samples; // taking avg for y
zsample/=samples; // taking avg for z
delay(3000);
currentMillis = millis();
int value1=analogRead(x); // reading x out
int value2=analogRead(y); //reading y out
int value3=analogRead(z); //reading z out
int xValue = xsample-value1; // finding change in x
int yValue = ysample-value2; // finding change in y
int zValue = zsample-value3; // finding change in z
/* comparing change with predefined limits*/
if(xValue < minVal || xValue > maxVal || yValue < minVal || yValue > maxVal || zValue < minVal || zValue > maxVal)
Describe what your code does and how this differs from what you want it to do. Use serial print to make sure it is doing as expected.
Delays make your code stop and do nothing and are to be avoided. You have a large delay in setup. You can look at “blink without delay” for ideas if you really need to delay but remain responsive
The code is incomplete, in that it won't even compile... surely there is more... it's like it stops mid flight. It's like you wrote a sentence but didn't ....
Ok. If that is all you have then, like they said above, you have stopped mid flow.
Open a new sketch and it will automatically have code that compiles, so infinitely better than what you have now.
Now decide on 1 thing you want to code, not 3! Look at examples and code it. Use serial to show that it is doing as you intend. Once it is working then save that sketch with a name that describes it. Now open a new sketch and do the same for thing number 2. Now try to combine those sketches. Now you should have these sketches:
Thing 1 (I compile and do what I say)
Thing 2 (I compile and do what I say)
Thing 1+2 (I compile and do what I say)
In this way you will always have a working sketch and know exactly where your problems are. You can then ask for help and people will be able to see your code and understand it
Did you consider to use a different sensor? A metal mass suspended in a metal can with little distance all around. An earthquake will shake the can while the mass will (sufficiently) stand still and make contact.
my problem is the relay switchess when it detects movement and switch again after 5 seconds even though there is no movement. what i want is the relay only switch when there is movement after 5 seconds.
/*variables*/
int xsample=0;
int ysample=0;
int zsample=0;
long start;
/*Macros*/
#define samples 50
bool stationary = true;
pinMode(relay, OUTPUT);
delay(3000);
unsigned char i, j ;
int xValue = xsample - value1; // finding change in x
int yValue = ysample - value2; // finding change in y
int zValue = zsample - value3; // finding change in z
int lastx, lasty, lastz;
if(xValue > minVal || xValue < maxVal || yValue > minVal || yValue < maxVal || zValue > minVal || zValue < maxVal)
startMillis = millis(); // timer start
stationary = false;
digitalWrite (buzzer, HIGH) ; //send tone
delay (1);
digitalWrite (buzzer, LOW) ; //no tone
delay (1);
else {
// not moving
stationary = true;
if (stationary && currentMillis - startMillis >= period) {
digitalWrite(relay, LOW);
digitalWrite(relay, HIGH);
