I'm using Arduino Nano and it gives an error like "Low memory available, may cause stability problems"
I had an error like this and it gives "An error occurred while uploading the sketch" error with this error. Any help? :frowning_face:
Please post the sketch that causes the error
Please follow the advice given in the link below when posting code . Use code tags when posting code here to make it easier to read and copy for examination
Sounds like you've got two separate problems. One is the low memory issue, which results in a warning. If that's all you got, the sketch would still upload and usually it (sort of) still runs.
If it won't upload, then there are also additional errors on top of the one you mentioned.
UKHeliBob, It is my code, LCD5110_Graph example.
LCD5110_Graph_Demo.ino (3.6 KB)
const unsigned char arduino_logo[] ={
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0xC0, 0xE0, 0xF0, 0xF8, 0xF8, 0xFC, 0xFC,   // 0x0010 (16) pixels
0xFE, 0xFE, 0x7F, 0x7F, 0x7F, 0x3F, 0x3F, 0x3F, 0x3F, 0x3F, 0x7F, 0x7F, 0x7F, 0xFE, 0xFE, 0xFE,   // 0x0020 (32) pixels
0xFC, 0xFC, 0xF8, 0xF0, 0xF0, 0xE0, 0xC0, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0xC0, 0xE0,   // 0x0030 (48) pixels
0xF0, 0xF0, 0xF8, 0xFC, 0xFC, 0xFE, 0xFE, 0xFE, 0x7F, 0x7F, 0x7F, 0x3F, 0x3F, 0x3F, 0x3F, 0x7F,   // 0x0040 (64) pixels
0x7F, 0x7F, 0x7F, 0xFE, 0xFE, 0xFC, 0xFC, 0xF8, 0xF8, 0xF0, 0xE0, 0xC0, 0x86, 0x06, 0x06, 0x00,   // 0x0050 (80) pixels
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xC0, 0xFC, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,   // 0x0060 (96) pixels
0x1F, 0x07, 0x01, 0x00, 0x00, 0x00, 0x00, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80,   // 0x0070 (112) pixels
0x80, 0x80, 0x00, 0x00, 0x01, 0x01, 0x03, 0x0F, 0x1F, 0x3F, 0xFF, 0xFF, 0xFF, 0xFE, 0xFC, 0xFE,   // 0x0080 (128) pixels
0xFF, 0xFF, 0xFF, 0x3F, 0x1F, 0x0F, 0x03, 0x01, 0x01, 0x00, 0x00, 0x80, 0x80, 0x80, 0x80, 0xF8,   // 0x0090 (144) pixels
0xF8, 0xF8, 0xF8, 0x80, 0x80, 0x80, 0x00, 0x00, 0x00, 0x00, 0x01, 0x07, 0x1F, 0xFF, 0xFF, 0xFF,   // 0x00A0 (160) pixels
0xFF, 0xFF, 0xFC, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0x7F, 0xFF,   // 0x00B0 (176) pixels
0xFF, 0xFF, 0xFF, 0xFF, 0xF0, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x07, 0x07, 0x07, 0x07,   // 0x00C0 (192) pixels
0x07, 0x07, 0x07, 0x07, 0x07, 0x03, 0x00, 0x00, 0x00, 0x00, 0x80, 0xC0, 0xF0, 0xF8, 0xFE, 0xFF,   // 0x00D0 (208) pixels
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFE, 0xF8, 0xF0, 0xC0, 0x80, 0x00, 0x00, 0x00, 0x00, 0x07,   // 0x00E0 (224) pixels
0x07, 0x07, 0x07, 0x3F, 0x3F, 0x3F, 0x3F, 0x07, 0x07, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00, 0xC0,   // 0x00F0 (240) pixels
0xF0, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x7F, 0x0F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,   // 0x0100 (256) pixels
0x00, 0x00, 0x00, 0x00, 0x03, 0x07, 0x0F, 0x1F, 0x3F, 0x7F, 0x7F, 0xFF, 0xFE, 0xFE, 0xFC, 0xFC,   // 0x0110 (272) pixels
0xF8, 0xF8, 0xF8, 0xF8, 0xF8, 0xF8, 0xF8, 0xFC, 0xFC, 0xFC, 0xFE, 0xFF, 0x7F, 0x7F, 0x3F, 0x3F,   // 0x0120 (288) pixels
0x1F, 0x0F, 0x07, 0x03, 0x01, 0x00, 0x00, 0x00, 0x01, 0x03, 0x07, 0x0F, 0x1F, 0x3F, 0x3F, 0x7F,   // 0x0130 (304) pixels
0x7F, 0xFF, 0xFE, 0xFC, 0xFC, 0xFC, 0xF8, 0xF8, 0xF8, 0xF8, 0xF8, 0xF8, 0xF8, 0xFC, 0xFC, 0xFE,   // 0x0140 (320) pixels
0xFE, 0xFF, 0x7F, 0x7F, 0x3F, 0x1F, 0x0F, 0x07, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,   // 0x0150 (336) pixels
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xC0, 0xC0, 0xC0, 0x80, 0x00, 0x00,   // 0x0160 (352) pixels
0x00, 0x00, 0xC1, 0xC1, 0xC1, 0xC1, 0xC1, 0xC1, 0x81, 0x81, 0x01, 0x01, 0xC1, 0xC1, 0xC0, 0xC0,   // 0x0170 (368) pixels
0xC0, 0xC0, 0x80, 0x00, 0x00, 0x00, 0x80, 0xC0, 0xC0, 0x00, 0x00, 0x00, 0xC0, 0xC0, 0x80, 0x00,   // 0x0180 (384) pixels
0x00, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC1, 0xC1, 0x01, 0x01, 0xC1, 0xC1, 0xC1, 0x01, 0x01,   // 0x0190 (400) pixels
0x01, 0xC1, 0xC1, 0x01, 0x00, 0x00, 0x80, 0xC0, 0xC0, 0xC0, 0xC0, 0x80, 0x80, 0x00, 0x00, 0x00,   // 0x01A0 (416) pixels
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xC0, 0xF8, 0xFF, 0x3F, 0x3B,   // 0x01B0 (432) pixels
0x3F, 0x7F, 0xFE, 0xF0, 0x00, 0x00, 0xFF, 0xFF, 0xFF, 0x1C, 0x3C, 0xFF, 0xFF, 0xC7, 0x00, 0x00,   // 0x01C0 (448) pixels
0xFF, 0xFF, 0xFF, 0xE0, 0xE0, 0xF1, 0x7F, 0x3F, 0x1F, 0x00, 0x3F, 0x7F, 0xFF, 0xE0, 0xC0, 0xE0,   // 0x01D0 (464) pixels
0xFF, 0x7F, 0x3F, 0x00, 0x00, 0xE0, 0xE0, 0xFF, 0xFF, 0xFF, 0xE0, 0xE0, 0xC0, 0x00, 0x00, 0xFF,   // 0x01E0 (480) pixels
0xFF, 0x07, 0x0F, 0x3E, 0xFC, 0xFF, 0xFF, 0x00, 0x00, 0x3F, 0x7F, 0xFF, 0xE0, 0xC0, 0xE1, 0x7F,   // 0x01F0 (496) pixels
0x7F, 0x0E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
const unsigned char The_End[] ={
0x00, 0x80, 0x80, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xE0, 0x60, 0x00, 0x00,   // 0x0010 (16) pixels
0x80, 0xC0, 0xC0, 0x00, 0x00, 0xC0, 0xC0, 0xC0, 0x00, 0x00, 0x80, 0xC0, 0xC0, 0xC0, 0xC0, 0xE0,   // 0x0020 (32) pixels
0xC0, 0xC0, 0xC0, 0xC0, 0xE0, 0x60, 0x00, 0x00, 0x00, 0x00, 0x00, 0xC0, 0xC0, 0xC0, 0xC0, 0xE0,   // 0x0030 (48) pixels
0xE0, 0xC0, 0xC0, 0xC0, 0xE0, 0xE0, 0x00, 0x00, 0x00, 0x80, 0x80, 0xC0, 0xC0, 0xC0, 0x00, 0x00,   // 0x0040 (64) pixels
0x00, 0x00, 0x80, 0xE0, 0xF0, 0xF0, 0x60, 0x40, 0xF0, 0xF0, 0xF0, 0xF0, 0xE0, 0xE0, 0xC0, 0xC0,   // 0x0050 (80) pixels
0x80, 0x00, 0x00, 0x00, 0x00, 0x03, 0x03, 0x03, 0x81, 0xFC, 0xFF, 0x0F, 0x03, 0x00, 0x00, 0x00,   // 0x0060 (96) pixels
0xEE, 0x6F, 0x67, 0xFF, 0xFF, 0x7F, 0x71, 0x30, 0xF0, 0xFF, 0x3F, 0x39, 0x38, 0x18, 0x00, 0x01,   // 0x0070 (112) pixels
0x00, 0xF8, 0xFF, 0x1F, 0x0F, 0x0C, 0x0D, 0x8D, 0x80, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01,   // 0x0080 (128) pixels
0x00, 0xC0, 0xFF, 0x7F, 0x0F, 0x0C, 0x0D, 0x0D, 0x84, 0x80, 0x80, 0x07, 0x07, 0x83, 0xFF, 0xFF,   // 0x0090 (144) pixels
0x1F, 0x3F, 0xFE, 0xF8, 0xF8, 0xFE, 0xDF, 0x03, 0x00, 0x00, 0x00, 0x03, 0xFF, 0xFF, 0x1F, 0x00,   // 0x00A0 (160) pixels
0x00, 0x80, 0x81, 0xC3, 0xE7, 0x7F, 0x3E, 0x00, 0x00, 0x00, 0x00, 0x06, 0x07, 0x07, 0x03, 0x00,   // 0x00B0 (176) pixels
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x04, 0x0F, 0x07, 0x03, 0x00, 0x00, 0x0F, 0x0F, 0x07, 0x00,   // 0x00C0 (192) pixels
0x00, 0x06, 0x06, 0x3F, 0x1F, 0x0F, 0x0F, 0x0E, 0x06, 0x06, 0x06, 0x07, 0x07, 0x03, 0x00, 0x00,   // 0x00D0 (208) pixels
0x00, 0x00, 0x06, 0x1F, 0x3F, 0x1F, 0x0F, 0x0E, 0x06, 0x06, 0x06, 0x07, 0x07, 0x07, 0x03, 0x00,   // 0x00E0 (224) pixels
0x06, 0x0F, 0x07, 0x01, 0x00, 0x00, 0x00, 0x01, 0x0F, 0x07, 0x03, 0x00, 0x00, 0x18, 0x1C, 0x1F,   // 0x00F0 (240) pixels
0x0F, 0x07, 0x06, 0x07, 0x03, 0x03, 0x01, 0x01, 0x00, 0x00, 0x00, 0x00,
const unsigned char pacman1[] ={
0x80, 0xE0, 0xF0, 0xF8, 0xFC, 0xFE, 0xFE, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x7E, 0x3E, 0x1C,   // 0x0010 (16) pixels
0x0C, 0x00, 0x00, 0x00, 0x1F, 0x7F, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xF9,   // 0x0020 (32) pixels
0xF0, 0xE0, 0xC0, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x03, 0x07, 0x07, 0x0F,   // 0x0030 (48) pixels
0x0F, 0x0F, 0x0F, 0x0F, 0x0F, 0x07, 0x07, 0x03, 0x03, 0x00, 0x00, 0x00,
const unsigned char pacman2[] ={
0x80, 0xE0, 0xF0, 0xF8, 0xFC, 0xFE, 0xFE, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFE, 0xFE, 0x7C,   // 0x0010 (16) pixels
0x7C, 0x38, 0x20, 0x00, 0x1F, 0x7F, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xF9,   // 0x0020 (32) pixels
0xF9, 0xF0, 0xF0, 0xE0, 0xE0, 0xC0, 0x40, 0x00, 0x00, 0x00, 0x00, 0x01, 0x03, 0x07, 0x07, 0x0F,   // 0x0030 (48) pixels
0x0F, 0x0F, 0x0F, 0x0F, 0x0F, 0x07, 0x07, 0x03, 0x03, 0x01, 0x00, 0x00,
const unsigned char pacman3[] ={
0x80, 0xE0, 0xF0, 0xF8, 0xFC, 0xFE, 0xFE, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFE, 0xFE, 0xFC,   // 0x0010 (16) pixels
0xF8, 0xF0, 0xE0, 0x80, 0x1F, 0x7F, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,   // 0x0020 (32) pixels
0xFF, 0xFF, 0xFF, 0xFF, 0xFB, 0xF9, 0x79, 0x19, 0x00, 0x00, 0x00, 0x01, 0x03, 0x07, 0x07, 0x0F,   // 0x0030 (48) pixels
0x0F, 0x0F, 0x0F, 0x0F, 0x0F, 0x07, 0x07, 0x03, 0x01, 0x00, 0x00, 0x00,
const unsigned char pill[] ={
0x0E, 0x1F, 0x1F, 0x1F, 0x0E,
Graphics.c
@koraks, thanks for the information.
Wait... there are more errors! :fearful:
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x25
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x25
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x25
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x25
avrdude: ser_recv(): read error: Access denied.
Ok, so the memory problem is kind of obvious with those big arrays with image data. It doesn't have to be a problem if the rest of the code is efficient. Btw, please always post the full code of your project. People don't like to download .ino files, fire up the IDE etc.
So that's a typical connection problem. Check cabling, if the board works, drivers properly installed etc.
Hi, @MDurmusPro
And your code.
// LCD5110_Graph_Demo
// Copyright (C)2015 Rinky-Dink Electronics, Henning Karlsen. All right reserved
// web: http://www.RinkyDinkElectronics.com/
// This program is a demo of most of the functions
// in the library.
// This program requires a Nokia 5110 LCD module.
// It is assumed that the LCD module is connected to
// the following pins:
//      SCK  - Pin 8
//      MOSI - Pin 9
//      DC   - Pin 10
//      RST  - Pin 11
//      CS   - Pin 12
#include <LCD5110_Graph.h>
LCD5110 myGLCD(8,9,10,11,12);
extern unsigned char SmallFont[];
extern unsigned char TinyFont[];
extern uint8_t arduino_logo[];
extern uint8_t The_End[];
extern uint8_t pacman1[];
extern uint8_t pacman2[];
extern uint8_t pacman3[];
extern uint8_t pill[];
float y;
uint8_t* bm;
int pacy;
  myGLCD.InitLCD();
  myGLCD.setFont(SmallFont);
  randomSeed(analogRead(7));
  myGLCD.clrScr();
  myGLCD.drawBitmap(0, 0, arduino_logo, 84, 48);
  myGLCD.update();
  delay(2000);
  myGLCD.clrScr();
  myGLCD.print("LCD5110_Graph", CENTER, 0);
  myGLCD.print("DEMO", CENTER, 20);
  myGLCD.drawRect(28, 18, 56, 28);
  for (int i=0; i<6; i++)
    myGLCD.drawLine(57, 18+(i*2), 83-(i*3), 18+(i*2));
    myGLCD.drawLine((i*3), 28-(i*2), 28, 28-(i*2));
  myGLCD.setFont(TinyFont);
  myGLCD.print("(C)2015 by", CENTER, 36);
  myGLCD.print("Henning Karlsen", CENTER, 42);
  myGLCD.update();
  delay(5000);
  myGLCD.clrScr();
  for (int i=0; i<48; i+=2)
    myGLCD.drawLine(0, i, 83, 47-i);
    myGLCD.update();
  for (int i=83; i>=0; i-=2)
    myGLCD.drawLine(i, 0, 83-i, 47);
    myGLCD.update();
  delay(2000);
  myGLCD.clrScr();
  myGLCD.drawRect(0, 0, 83, 47);
  for (int i=0; i<48; i+=4)
    myGLCD.drawLine(0, i, i*1.75, 47);
    myGLCD.update();
    myGLCD.drawLine(83, 47-i, 83-(i*1.75), 0);
    myGLCD.update();
  delay(2000);
  myGLCD.clrScr();
  for (int i=0; i<8; i++)
    myGLCD.drawRoundRect(i*3, i*3, 83-(i*3), 47-(i*3));
    myGLCD.update();
  delay(2000);
  myGLCD.clrScr();
  for (int i=0; i<17; i++)
    myGLCD.drawCircle(41, 23, i*3);
    myGLCD.update();
  delay(2000);
  myGLCD.clrScr();
  myGLCD.drawLine(0, 23, 84, 23);
  myGLCD.drawLine(41, 0, 41, 47);
  for (int c=0; c<4; c++)
    for (int i=0; i<84; i++)
      y=i*0.017453292519943295769236907684886;
      myGLCD.invPixel(i, (sin(y*6)*20)+23);
      myGLCD.update();
      delay(20);
  delay(2000);
  for (int pc=0; pc<3; pc++)
    pacy=random(0, 28);
    for (int i=-20; i<84; i++)
      myGLCD.clrScr();
      for (int p=4; p>((i+20)/20); p--)
        myGLCD.drawBitmap(p*20-8, pacy+7, pill, 5, 5);
      switch(((i+20)/3) % 4)
        case 0: bm=pacman1;
        case 1: bm=pacman2;
        case 2: bm=pacman3;
        case 3: bm=pacman2;
      myGLCD.drawBitmap(i, pacy, bm, 20, 20);
      myGLCD.update();
      delay(25);
  for (int i=0; i<25; i++)
    myGLCD.clrScr();
    myGLCD.drawBitmap(0, i-24, The_End, 84, 24);
    myGLCD.update();
    delay(100);
  myGLCD.print("Runtime (ms):", CENTER, 32);
  myGLCD.printNumI(millis(), CENTER, 40);
  myGLCD.update();
  for (int i=0; i<5; i++)
    myGLCD.invert(true);
    myGLCD.invert(false);
Tom... :smiley: :+1: :coffee: :australia:
I checked the cabling, I don't have the avrdude error now, but i still have low memory warning and an error occurred while uploading the sketch.
Good!
Like I said: you're declaring big arrays. They take up memory in the Arduino.
Must we guess at what kind of error you got this time...? I don't like that game.
Yeah, I think Arduino Nano's memory is too small for this, because I can do it with Uno.
I like Arduino IDE, but when I got errors not helping, I hate every single code language.
Perhaps we could help if you posted the full error messages here
Hi, @MDurmusPro
Errors are helping by telling you that you are nearly out of memory.
How else would you expect to be notified when it uploads and you code looks buggy?
UNO or Nano, both show the same warning.
UNO
Sketch uses 9426 bytes (29%) of program storage space. Maximum is 32256 bytes.
Global variables use 1550 bytes (75%) of dynamic memory, leaving 498 bytes for local variables. Maximum is 2048 bytes.
Low memory available, stability problems may occur.
Nano
Sketch uses 9426 bytes (30%) of program storage space. Maximum is 30720 bytes.
To get your code to compile (run) I had to change;
const unsigned char
to
unsigned char
Tom.... :smiley: :+1: :coffee: :australia:
@TomGeorge Thanks! I hope it'll work!
Funny, since they're the exact some microcontroller with the exact same amount of memory.
Well, I sympathize with you. But as long as you don't tell us about the specific errors you're getting, nobody can help you.
I think I need to make more searching about electronic cards ._.
Uhh... you're right.
Ok then.
This is the error.
An error occurred while uploading the sketch.
And my card is Arduino Nano, Atmega328P on COM5. Want more info?
There's probably a little more text in that same window. You may have to enlarge it a bit to see it all. We need the rest of it as well.
Or you could just simply use the "Copy error messages" button in the IDE to make sure that you copy all of it
Arduino:1.8.15 (Windows Store 1.8.49.0) (Windows 10), Board:"Arduino Nano, ATmega328P"
Sketch used 9426 bytes (30%) of the program's storage. Maximum of 30720 bytes.
Global variables use 1550 bytes (75%) of memory. 498 bytes are left for local variables. Maximum is 2048 bytes.
option enabled in File -> Preferences.
How about following those instructions to get some more information on your error?
Arduino: 1.8.16 (Windows Store 1.8.51.0) (Windows 10), Board: "Arduino Nano, ATmega328P"
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.51.0_x86__mdqgnx93n4wtt\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.51.0_x86__mdqgnx93n4wtt\hardware -hardware C:\Users\Acer\OneDrive - leverage proactive deliverables\Belgeler\ArduinoData\packages -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.51.0_x86__mdqgnx93n4wtt\tools-builder -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.51.0_x86__mdqgnx93n4wtt\hardware\tools\avr -tools C:\Users\Acer\OneDrive - leverage proactive deliverables\Belgeler\ArduinoData\packages -built-in-libraries C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.51.0_x86__mdqgnx93n4wtt\libraries -libraries C:\Users\Acer\OneDrive - leverage proactive deliverables\Belgeler\Arduino\libraries -fqbn=arduino:avr:nano:cpu=atmega328 -vid-pid=1A86_7523 -ide-version=10816 -build-path C:\Users\Acer\AppData\Local\Temp\arduino_build_997005 -warnings=none -build-cache C:\Users\Acer\AppData\Local\Temp\arduino_cache_64398 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.51.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.51.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.51.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.51.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.51.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.51.0_x86__mdqgnx93n4wtt\hardware\tools\avr -verbose C:\Users\Acer\OneDrive - leverage proactive deliverables\Belgeler\Arduino\sketch_sep09d\sketch_sep09d.ino
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.51.0_x86__mdqgnx93n4wtt\arduino-builder -compile -logger=machine -hardware C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.51.0_x86__mdqgnx93n4wtt\hardware -hardware C:\Users\Acer\OneDrive - leverage proactive deliverables\Belgeler\ArduinoData\packages -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.51.0_x86__mdqgnx93n4wtt\tools-builder -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.51.0_x86__mdqgnx93n4wtt\hardware\tools\avr -tools C:\Users\Acer\OneDrive - leverage proactive deliverables\Belgeler\ArduinoData\packages -built-in-libraries C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.51.0_x86__mdqgnx93n4wtt\libraries -libraries C:\Users\Acer\OneDrive - leverage proactive deliverables\Belgeler\Arduino\libraries -fqbn=arduino:avr:nano:cpu=atmega328 -vid-pid=1A86_7523 -ide-version=10816 -build-path C:\Users\Acer\AppData\Local\Temp\arduino_build_997005 -warnings=none -build-cache C:\Users\Acer\AppData\Local\Temp\arduino_cache_64398 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.51.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.51.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.51.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.51.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.51.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.51.0_x86__mdqgnx93n4wtt\hardware\tools\avr -verbose C:\Users\Acer\OneDrive - leverage proactive deliverables\Belgeler\Arduino\sketch_sep09d\sketch_sep09d.ino
Using board 'nano' from platform in folder: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.51.0_x86__mdqgnx93n4wtt\hardware\arduino\avr
Using core 'arduino' from platform in folder: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.51.0_x86__mdqgnx93n4wtt\hardware\arduino\avr
Detecting libraries used...
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.51.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10816 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.51.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.51.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "C:\\Users\\Acer\\AppData\\Local\\Temp\\arduino_build_997005\\sketch\\sketch_sep09d.ino.cpp" -o nul
Alternatives for LCD5110_Graph.h: [LCD5110_Graph]
ResolveLibrary(LCD5110_Graph.h)
  -> candidates: [LCD5110_Graph]
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.51.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10816 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.51.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.51.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "-IC:\\Users\\Acer\\OneDrive - leverage proactive deliverables\\Belgeler\\Arduino\\libraries\\LCD5110_Graph" "C:\\Users\\Acer\\AppData\\Local\\Temp\\arduino_build_997005\\sketch\\sketch_sep09d.ino.cpp" -o nul
Using cached library dependencies for file: C:\Users\Acer\OneDrive - leverage proactive deliverables\Belgeler\Arduino\libraries\LCD5110_Graph\DefaultFonts.c
Using cached library dependencies for file: C:\Users\Acer\OneDrive - leverage proactive deliverables\Belgeler\Arduino\libraries\LCD5110_Graph\LCD5110_Graph.cpp
Generating function prototypes...
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.51.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10816 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.51.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.51.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "-IC:\\Users\\Acer\\OneDrive - leverage proactive deliverables\\Belgeler\\Arduino\\libraries\\LCD5110_Graph" "C:\\Users\\Acer\\AppData\\Local\\Temp\\arduino_build_997005\\sketch\\sketch_sep09d.ino.cpp" -o "C:\\Users\\Acer\\AppData\\Local\\Temp\\arduino_build_997005\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.51.0_x86__mdqgnx93n4wtt\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\Acer\\AppData\\Local\\Temp\\arduino_build_997005\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.51.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10816 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.51.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.51.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "-IC:\\Users\\Acer\\OneDrive - leverage proactive deliverables\\Belgeler\\Arduino\\libraries\\LCD5110_Graph" "C:\\Users\\Acer\\AppData\\Local\\Temp\\arduino_build_997005\\sketch\\sketch_sep09d.ino.cpp" -o "C:\\Users\\Acer\\AppData\\Local\\Temp\\arduino_build_997005\\sketch\\sketch_sep09d.ino.cpp.o"
Compiling libraries...
Compiling library "LCD5110_Graph"
Using previously compiled file: C:\Users\Acer\AppData\Local\Temp\arduino_build_997005\libraries\LCD5110_Graph\DefaultFonts.c.o
Using previously compiled file: C:\Users\Acer\AppData\Local\Temp\arduino_build_997005\libraries\LCD5110_Graph\LCD5110_Graph.cpp.o
Compiling core...
Using precompiled core: C:\Users\Acer\AppData\Local\Temp\arduino_cache_64398\core\core_arduino_avr_nano_cpu_atmega328_181e0f64b51f9dc50a0bb8aa27d6db3e.a
Linking everything together...
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.51.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\\Users\\Acer\\AppData\\Local\\Temp\\arduino_build_997005/sketch_sep09d.ino.elf" "C:\\Users\\Acer\\AppData\\Local\\Temp\\arduino_build_997005\\sketch\\sketch_sep09d.ino.cpp.o" "C:\\Users\\Acer\\AppData\\Local\\Temp\\arduino_build_997005\\libraries\\LCD5110_Graph\\DefaultFonts.c.o" "C:\\Users\\Acer\\AppData\\Local\\Temp\\arduino_build_997005\\libraries\\LCD5110_Graph\\LCD5110_Graph.cpp.o" "C:\\Users\\Acer\\AppData\\Local\\Temp\\arduino_build_997005/..\\arduino_cache_64398\\core\\core_arduino_avr_nano_cpu_atmega328_181e0f64b51f9dc50a0bb8aa27d6db3e.a" "-LC:\\Users\\Acer\\AppData\\Local\\Temp\\arduino_build_997005" -lm
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.51.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\\Users\\Acer\\AppData\\Local\\Temp\\arduino_build_997005/sketch_sep09d.ino.elf" "C:\\Users\\Acer\\AppData\\Local\\Temp\\arduino_build_997005/sketch_sep09d.ino.eep"
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.51.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-objcopy" -O ihex -R .eeprom "C:\\Users\\Acer\\AppData\\Local\\Temp\\arduino_build_997005/sketch_sep09d.ino.elf" "C:\\Users\\Acer\\AppData\\Local\\Temp\\arduino_build_997005/sketch_sep09d.ino.hex"
Using library LCD5110_Graph in folder: C:\Users\Acer\OneDrive - leverage proactive deliverables\Belgeler\Arduino\libraries\LCD5110_Graph (legacy)
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.51.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-size" -A "C:\\Users\\Acer\\AppData\\Local\\Temp\\arduino_build_997005/sketch_sep09d.ino.elf"
Problem uploading to board.  See https://support.arduino.cc/hc/en-us/sections/360003198300 for suggestions.
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.51.0_x86__mdqgnx93n4wtt\hardware\tools\avr/bin/avrdude -CC:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.51.0_x86__mdqgnx93n4wtt\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM5 -b115200 -D -Uflash:w:C:\Users\Acer\AppData\Local\Temp\arduino_build_997005/sketch_sep09d.ino.hex:i
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.51.0_x86__mdqgnx93n4wtt\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM5
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
My brain burned.
Wait... What the heck is this "Overriding Baud Rate" mean and why it is 115200???
It's just the default upload speed. Don't worry about it.
Did you follow this:
