Imac USB Port Assignment - Master and Slave I2C
I hope I'm in the right section of the forum for my question, if not Please redirect me.
I connect 2 Arduino Unos to 2 different USB ports on my Imac to try this tutorial :
It works once, then when I disconnect and reconnect the arduinos the USB port assignment
messes up. i.e. I get both arduinos on the same port. Changing ports manually will not work either.
How do I solve this problem ?
If you disconnect the Arduinos, quit the IDE and start it again after you reconnected the Arduinos. The port mess is a problem of your Mac, the port assignment is handled by the OS.
