Image on web
I'm trying to display an image on the internet through "Ethernet Shield," but I am not able to link the code that I found. The image in this code is in byte format. Someone can help me use it in my code?
I want the image is in this format because I'm trying to get it from matlab and then wanted to show it on the web.
The code i found:
/* Web_Image.pde - example sketch for Webduino library */
/* For webduino version 1.2 */
/* DISCLAIMER -- the Webduino server can only handle one web connection
 * at a time.  Because of this, loading the root page on this sketch may
 * not correctly show the LED icon if the browser starts requesting that
 * picture before the page has finished loading.
 * This problem should be reduced greatly once the Ethernet library
 * has been modified to do proper packet buffering.  With the library
 * in Arduino 15, each character is sent in its own TCP/IP packet.
 * This is very inefficient and means that it takes much longer to
 * send a web page than it should.  When this bug is fixed, the web
 * server will have sent its last data and closed the connection by
 * the time the client reads the HTML, so it's ready to handle the
 * image request.
#include "SPI.h"
#include "Ethernet.h"
#include "WebServer.h"
// CHANGE THIS TO YOUR OWN UNIQUE VALUE
static uint8_t mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
static uint8_t ip[] = { 169, 254, 190, 210 };
WebServer webserver("", 80);
/* The default page just returns HTML to show the image */
void defaultCmd(WebServer &server, WebServer::ConnectionType type, char *url_tail, bool tail_complete)
  if (type == WebServer::POST)
    // ignore POST data
    server.httpFail();
    return;
  /* for a GET or HEAD, send the standard "it's all OK headers" */
  server.httpSuccess();
  /* we don't output the body for a HEAD request */
  if (type == WebServer::GET)
    /* store the HTML in program memory using the P macro */
    P(message) =
      "<html><head><title>Webduino Image Example</title>"
      "<body>"
      "<h2>LED Image</h2>"
      "<img src='led.png' width=256 height=256>"
      "</body></html>";
    server.printP(message);
void imageCmd(WebServer &server, WebServer::ConnectionType type, char *url_tail, bool tail_complete)
  /* this data was taken from a PNG file that was converted to a C data structure
   * by running it through the directfb-csource application. */
  P(ledData) = {
    0x89, 0x50, 0x4e, 0x47, 0x0d, 0x0a, 0x1a, 0x0a, 0x00, 0x00, 0x00, 0x0d, 0x49, 0x48, 0x44, 0x52,
    0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x10, 0x08, 0x02, 0x00, 0x00, 0x00, 0x90, 0x91, 0x68,
    0x36, 0x00, 0x00, 0x00, 0x01, 0x73, 0x52, 0x47, 0x42, 0x00, 0xae, 0xce, 0x1c, 0xe9, 0x00, 0x00,
    0x00, 0x04, 0x67, 0x41, 0x4d, 0x41, 0x00, 0x00, 0xb1, 0x8f, 0x0b, 0xfc, 0x61, 0x05, 0x00, 0x00,
    0x00, 0x20, 0x63, 0x48, 0x52, 0x4d, 0x00, 0x00, 0x7a, 0x26, 0x00, 0x00, 0x80, 0x84, 0x00, 0x00,
    0xfa, 0x00, 0x00, 0x00, 0x80, 0xe8, 0x00, 0x00, 0x75, 0x30, 0x00, 0x00, 0xea, 0x60, 0x00, 0x00,
    0x3a, 0x98, 0x00, 0x00, 0x17, 0x70, 0x9c, 0xba, 0x51, 0x3c, 0x00, 0x00, 0x00, 0x18, 0x74, 0x45,
    0x58, 0x74, 0x53, 0x6f, 0x66, 0x74, 0x77, 0x61, 0x72, 0x65, 0x00, 0x50, 0x61, 0x69, 0x6e, 0x74,
    0x2e, 0x4e, 0x45, 0x54, 0x20, 0x76, 0x33, 0x2e, 0x33, 0x36, 0xa9, 0xe7, 0xe2, 0x25, 0x00, 0x00,
    0x00, 0x57, 0x49, 0x44, 0x41, 0x54, 0x38, 0x4f, 0x95, 0x52, 0x5b, 0x0a, 0x00, 0x30, 0x08, 0x6a,
    0xf7, 0x3f, 0xf4, 0x1e, 0x14, 0x4d, 0x6a, 0x30, 0x8d, 0x7d, 0x0d, 0x45, 0x2d, 0x87, 0xd9, 0x34,
    0x71, 0x36, 0x41, 0x7a, 0x81, 0x76, 0x95, 0xc2, 0xec, 0x3f, 0xc7, 0x8e, 0x83, 0x72, 0x90, 0x43,
    0x11, 0x10, 0xc4, 0x12, 0x50, 0xb6, 0xc7, 0xab, 0x96, 0xd0, 0xdb, 0x5b, 0x41, 0x5c, 0x6a, 0x0b,
    0xfd, 0x57, 0x28, 0x5b, 0xc2, 0xfd, 0xb2, 0xa1, 0x33, 0x28, 0x45, 0xd0, 0xee, 0x20, 0x5c, 0x9a,
    0xaf, 0x93, 0xd6, 0xbc, 0xdb, 0x25, 0x56, 0x61, 0x01, 0x17, 0x12, 0xae, 0x53, 0x3e, 0x66, 0x32,
    0xba, 0x00, 0x00, 0x00, 0x00, 0x49, 0x45, 0x4e, 0x44, 0xae, 0x42, 0x60, 0x82
    // ignore POST data
    server.httpFail();
    return;
  /* for a GET or HEAD, send the standard "it's all OK headers" but identify our data as a PNG file */
  server.httpSuccess("image/png");
    server.writeP(ledData, sizeof(ledData));
  // setup the Ehternet library to talk to the Wiznet board
  Ethernet.begin(mac, ip);
  /* register our default command (activated with the request of
   * http://x.x.x.x/ */
  webserver.setDefaultCommand(&defaultCmd);
  /* register our image output command */
  webserver.addCommand("led.png", &imageCmd);
  /* start the server to wait for connections */
  webserver.begin();
  // process incoming connections one at a time forever
  webserver.processConnection();
My Code
  Web Server
 A simple web server that shows the value of the analog input pins.
 using an Arduino Wiznet Ethernet shield.
 Circuit:
 * Ethernet shield attached to pins 10, 11, 12, 13
 * Analog inputs attached to pins A0 through A5 (optional)
 created 18 Dec 2009
 by David A. Mellis
 modified 9 Apr 2012
 by Tom Igoe
#include <SPI.h>
#include <Ethernet.h>
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = {
IPAddress ip(169,254,190, 177);
// Initialize the Ethernet server library
// with the IP address and port you want to use
// (port 80 is default for HTTP):
EthernetServer server(80);
   while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  // start the Ethernet connection and the server:
  server.begin();
  Serial.print("server is at ");
  Serial.println(Ethernet.localIP());
  // listen for incoming clients
  if (client) {
    Serial.println("new client");
    // an http request ends with a blank line
    boolean currentLineIsBlank = true;
    String vars;
    int varGraph=1;
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        Serial.write(c);
        vars.concat(c);
        if (vars.endsWith("=Grafico"))
         varGraph=1;
        // if you've gotten to the end of the line (received a newline
        // character) and the line is blank, the http request has ended,
        // so you can send a reply
        if (c == '\n' && currentLineIsBlank) {
          // send a standard http response header
          client.println("Content-Type: text/html");
          client.println("Connnection: close");
          client.println();
          client.println("<!DOCTYPE HTML>");
          client.println("<html>");
                    // add a meta refresh tag, so the browser pulls again every 5 seconds:
          client.println("<meta http-equiv=\"refresh\" content=\"5\">");
          // output the value of each analog input pin
          client.println(F("<form action='' name='menu' enctype='text/plain'>"));
          client.println(F("<input type='submit' name='Home' id='Home' value='Grafico' />"));
          client.println(F("</form>"));
          if(varGraph==1)
              //SHOW IMAGE HERE
          client.println("</html>");
        if (c == '\n') {
          // you're starting a new line
        else if (c != '\r') {
          // you've gotten a character on the current line
          currentLineIsBlank = false;
    // give the web browser time to receive the data
    delay(1);
    // close the connection:
    client.stop();
    Serial.println("client disonnected");
You can't do that. You can send image data to a browser, and have it display the image.
Why not? Does this mean that you can't compile and link the code, or does it mean that you can't post a link to the code?
What are you trying to get from matlab? The image? Does matlab even know how to send an image file?
Yes, I explained myself very bad
No i try to link the codes together to have the functionality of the code I found on my own sketch.
The matlab does know how to convert image to binary and send this.
bump :cold_sweat:
you might try to use dropbox / from matlab save to your public dropbox folder / right click it there, to get the web url
use the web url in your arduino shield page /... (dont store it on your arduino)
Instead of bumping read the comments in the code you posted:
  • by running it through the directfb-csource application. */
