I´m using arduino for a project using the 0V7670 camera. I did the project like this and worked perfectly (How to Use OV7670 Camera Module with Arduino Uno).
Now I am trying to make some changes in the project. Instead of using cable connectors I´m trying to use the APC 220 antennas (APC220 Radio Communication Module-DFRobot) for image transmission. I tried everything but it´s not working out. What should I do?
Start by describing what you tried and post your full code following the advice in How to get the best out of this forum
I´m doing a project using an arduino board and a OV7670 camera. I did the project, following the instructions carefully. It worked. (How to Use OV7670 Camera Module with Arduino Uno). I used the following code in arduino:
#include <stdint.h>
#include <avr/io.h>
#include <util/twi.h>
#include <util/delay.h>
#include <avr/pgmspace.h>
#define F_CPU 16000000UL
#define vga 0
#define qvga 1
#define qqvga 2
#define yuv422 0
#define rgb565 1
#define bayerRGB 2
#define camAddr_WR 0x42
#define camAddr_RD 0x43
/* Registers /
#define REG_GAIN 0x00 / Gain lower 8 bits (rest in vref) /
#define REG_BLUE 0x01 / blue gain /
#define REG_RED 0x02 / red gain /
#define REG_VREF 0x03 / Pieces of GAIN, VSTART, VSTOP /
#define REG_COM1 0x04 / Control 1 /
#define COM1_CCIR656 0x40 / CCIR656 enable */
#define REG_BAVE 0x05 /* U/B Average level /
#define REG_GbAVE 0x06 / Y/Gb Average level /
#define REG_AECHH 0x07 / AEC MS 5 bits /
#define REG_RAVE 0x08 / V/R Average level /
#define REG_COM2 0x09 / Control 2 /
#define COM2_SSLEEP 0x10 / Soft sleep mode /
#define REG_PID 0x0a / Product ID MSB /
#define REG_VER 0x0b / Product ID LSB /
#define REG_COM3 0x0c / Control 3 /
#define COM3_SWAP 0x40 / Byte swap /
#define COM3_SCALEEN 0x08 / Enable scaling /
#define COM3_DCWEN 0x04 / Enable downsamp/crop/window /
#define REG_COM4 0x0d / Control 4 /
#define REG_COM5 0x0e / All "reserved" /
#define REG_COM6 0x0f / Control 6 /
#define REG_AECH 0x10 / More bits of AEC value /
#define REG_CLKRC 0x11 / Clocl control /
#define CLK_EXT 0x40 / Use external clock directly /
#define CLK_SCALE 0x3f / Mask for internal clock scale /
#define REG_COM7 0x12 / Control 7 / //REG mean address.
#define COM7_RESET 0x80 / Register reset /
#define COM7_FMT_MASK 0x38
#define COM7_FMT_VGA 0x00
#define COM7_FMT_CIF 0x20 / CIF format /
#define COM7_FMT_QVGA 0x10 / QVGA format /
#define COM7_FMT_QCIF 0x08 / QCIF format /
#define COM7_RGB 0x04 / bits 0 and 2 - RGB format /
#define COM7_YUV 0x00 / YUV /
#define COM7_BAYER 0x01 / Bayer format /
#define COM7_PBAYER 0x05 / "Processed bayer" /
#define REG_COM8 0x13 / Control 8 /
#define COM8_FASTAEC 0x80 / Enable fast AGC/AEC /
#define COM8_AECSTEP 0x40 / Unlimited AEC step size /
#define COM8_BFILT 0x20 / Band filter enable /
#define COM8_AGC 0x04 / Auto gain enable /
#define COM8_AWB 0x02 / White balance enable /
#define COM8_AEC 0x01 / Auto exposure enable /
#define REG_COM9 0x14 / Control 9- gain ceiling /
#define REG_COM10 0x15 / Control 10 /
#define COM10_HSYNC 0x40 / HSYNC instead of HREF /
#define COM10_PCLK_HB 0x20 / Suppress PCLK on horiz blank /
#define COM10_HREF_REV 0x08 / Reverse HREF /
#define COM10_VS_LEAD 0x04 / VSYNC on clock leading edge /
#define COM10_VS_NEG 0x02 / VSYNC negative /
#define COM10_HS_NEG 0x01 / HSYNC negative /
#define REG_HSTART 0x17 / Horiz start high bits /
#define REG_HSTOP 0x18 / Horiz stop high bits /
#define REG_VSTART 0x19 / Vert start high bits /
#define REG_VSTOP 0x1a / Vert stop high bits /
#define REG_PSHFT 0x1b / Pixel delay after HREF /
#define REG_MIDH 0x1c / Manuf. ID high /
#define REG_MIDL 0x1d / Manuf. ID low /
#define REG_MVFP 0x1e / Mirror / vflip /
#define MVFP_MIRROR 0x20 / Mirror image /
#define MVFP_FLIP 0x10 / Vertical flip */
#define REG_AEW 0x24 /* AGC upper limit /
#define REG_AEB 0x25 / AGC lower limit /
#define REG_VPT 0x26 / AGC/AEC fast mode op region /
#define REG_HSYST 0x30 / HSYNC rising edge delay /
#define REG_HSYEN 0x31 / HSYNC falling edge delay /
#define REG_HREF 0x32 / HREF pieces /
#define REG_TSLB 0x3a / lots of stuff /
#define TSLB_YLAST 0x04 / UYVY or VYUY - see com13 /
#define REG_COM11 0x3b / Control 11 /
#define COM11_NIGHT 0x80 / NIght mode enable /
#define COM11_NMFR 0x60 / Two bit NM frame rate /
#define COM11_HZAUTO 0x10 / Auto detect 50/60 Hz /
#define COM11_50HZ 0x08 / Manual 50Hz select /
#define COM11_EXP 0x02
#define REG_COM12 0x3c / Control 12 /
#define COM12_HREF 0x80 / HREF always /
#define REG_COM13 0x3d / Control 13 /
#define COM13_GAMMA 0x80 / Gamma enable /
#define COM13_UVSAT 0x40 / UV saturation auto adjustment /
#define COM13_UVSWAP 0x01 / V before U - w/TSLB /
#define REG_COM14 0x3e / Control 14 /
#define COM14_DCWEN 0x10 / DCW/PCLK-scale enable /
#define REG_EDGE 0x3f / Edge enhancement factor /
#define REG_COM15 0x40 / Control 15 /
#define COM15_R10F0 0x00 / Data range 10 to F0 /
#define COM15_R01FE 0x80 / 01 to FE /
#define COM15_R00FF 0xc0 / 00 to FF /
#define COM15_RGB565 0x10 / RGB565 output /
#define COM15_RGB555 0x30 / RGB555 output /
#define REG_COM16 0x41 / Control 16 /
#define COM16_AWBGAIN 0x08 / AWB gain enable /
#define REG_COM17 0x42 / Control 17 /
#define COM17_AECWIN 0xc0 / AEC window - must match COM4 /
#define COM17_CBAR 0x08 / DSP Color bar /
- This matrix defines how the colors are generated, must be
- tweaked to adjust hue and saturation.
- Order: v-red, v-green, v-blue, u-red, u-green, u-blue
- They are nine-bit signed quantities, with the sign bit
- stored in0x58.Sign for v-red is bit 0, and up from there.
#define REG_CMATRIX_BASE 0x4f
#define CMATRIX_LEN 6
#define REG_CMATRIX_SIGN 0x58
#define REG_BRIGHT 0x55 / Brightness /
#define REG_CONTRAS 0x56 / Contrast control /
#define REG_GFIX 0x69 / Fix gain control /
#define REG_REG76 0x76 / OV's name /
#define R76_BLKPCOR 0x80 / Black pixel correction enable /
#define R76_WHTPCOR 0x40 / White pixel correction enable /
#define REG_RGB444 0x8c / RGB 444 control /
#define R444_ENABLE 0x02 / Turn on RGB444, overrides 5x5 /
#define R444_RGBX 0x01 / Empty nibble at end /
#define REG_HAECC1 0x9f / Hist AEC/AGC control 1 /
#define REG_HAECC2 0xa0 / Hist AEC/AGC control 2 /
#define REG_BD50MAX 0xa5 / 50hz banding step limit /
#define REG_HAECC3 0xa6 / Hist AEC/AGC control 3 /
#define REG_HAECC4 0xa7 / Hist AEC/AGC control 4 /
#define REG_HAECC5 0xa8 / Hist AEC/AGC control 5 /
#define REG_HAECC6 0xa9 / Hist AEC/AGC control 6 /
#define REG_HAECC7 0xaa / Hist AEC/AGC control 7 /
#define REG_BD60MAX 0xab / 60hz banding step limit /
#define COM1_CCIR656 0x40 / CCIR656 enable /
#define REG_BAVE 0x05 / U/B Average level /
#define MVFP_FLIP 0x10 / Vertical flip /
#define REG_AEW 0x24 / AGC upper limit /
#define COM17_CBAR 0x08 / DSP Color bar */
#define REG_BRIGHT 0x55 /* Brightness /
#define MTX1 0x4f / Matrix Coefficient 1 /
#define MTX2 0x50 / Matrix Coefficient 2 /
#define MTX3 0x51 / Matrix Coefficient 3 /
#define MTX4 0x52 / Matrix Coefficient 4 /
#define MTX5 0x53 / Matrix Coefficient 5 /
#define MTX6 0x54 / Matrix Coefficient 6 /
#define MTXS 0x58 / Matrix Coefficient Sign /
#define AWBC7 0x59 / AWB Control 7 /
#define AWBC8 0x5a / AWB Control 8 /
#define AWBC9 0x5b / AWB Control 9 /
#define AWBC10 0x5c / AWB Control 10 /
#define AWBC11 0x5d / AWB Control 11 /
#define AWBC12 0x5e / AWB Control 12 /
#define REG_GFI 0x69 / Fix gain control /
#define GGAIN 0x6a / G Channel AWB Gain /
#define DBLV 0x6b
#define AWBCTR3 0x6c / AWB Control 3 /
#define AWBCTR2 0x6d / AWB Control 2 /
#define AWBCTR1 0x6e / AWB Control 1 /
#define AWBCTR0 0x6f / AWB Control 0 */
struct regval_list{
uint8_t reg_num;
uint16_t value;
const struct regval_list qvga_ov7670 PROGMEM = {
{ REG_COM14, 0x19 },
{ 0x72, 0x11 },
{ 0x73, 0xf1 },
{ REG_HSTART, 0x16 },
{ REG_HSTOP, 0x04 },
{ REG_HREF, 0xa4 },
{ REG_VSTART, 0x02 },
{ REG_VSTOP, 0x7a },
{ REG_VREF, 0x0a },
{ 0xff, 0xff }, /* END MARKER */
const struct regval_list yuv422_ov7670 PROGMEM = {
{ REG_COM7, 0x0 }, /* Selects YUV mode /
{ REG_RGB444, 0 }, / No RGB444 please /
{ REG_COM1, 0 },
{ REG_COM15, COM15_R00FF },
{ REG_COM9, 0x6A }, / 128x gain ceiling; 0x8 is reserved bit /
{ 0x4f, 0x80 }, / "matrix coefficient 1" /
{ 0x50, 0x80 }, / "matrix coefficient 2" /
{ 0x51, 0 }, / vb /
{ 0x52, 0x22 }, / "matrix coefficient 4" /
{ 0x53, 0x5e }, / "matrix coefficient 5" /
{ 0x54, 0x80 }, / "matrix coefficient 6" /
{ REG_COM13, COM13_UVSAT },
{ 0xff, 0xff }, / END MARKER */
const struct regval_list ov7670_default_regs PROGMEM = {//from the linux driver
{ REG_COM7, COM7_RESET },
{ REG_TSLB, 0x04 }, /* OV /
{ REG_COM7, 0 }, / VGA /
- Set the hardware window. These values from OV don't entirely
- make sense - hstop is less than hstart. But they work...
{ REG_HSTART, 0x13 }, { REG_HSTOP, 0x01 },
{ REG_HREF, 0xb6 }, { REG_VSTART, 0x02 },
{ REG_VSTOP, 0x7a }, { REG_VREF, 0x0a },
{ REG_COM3, 0 }, { REG_COM14, 0 },
/* Mystery scaling numbers /
{ 0x70, 0x3a }, { 0x71, 0x35 },
{ 0x72, 0x11 }, { 0x73, 0xf0 },
{ 0xa2,/ 0x02 changed to 1*/1 }, { REG_COM10, 0x0 },
/* Gamma curve values /
{ 0x7a, 0x20 }, { 0x7b, 0x10 },
{ 0x7c, 0x1e }, { 0x7d, 0x35 },
{ 0x7e, 0x5a }, { 0x7f, 0x69 },
{ 0x80, 0x76 }, { 0x81, 0x80 },
{ 0x82, 0x88 }, { 0x83, 0x8f },
{ 0x84, 0x96 }, { 0x85, 0xa3 },
{ 0x86, 0xaf }, { 0x87, 0xc4 },
{ 0x88, 0xd7 }, { 0x89, 0xe8 },
/ AGC and AEC parameters. Note we start by disabling those features,
then turn them only after tweaking the values. /
{ REG_COM8, COM8_FASTAEC | COM8_AECSTEP },
{ REG_GAIN, 0 }, { REG_AECH, 0 },
{ REG_COM4, 0x40 }, / magic reserved bit /
{ REG_COM9, 0x18 }, / 4x gain + magic rsvd bit /
{ REG_BD50MAX, 0x05 }, { REG_BD60MAX, 0x07 },
{ REG_AEW, 0x95 }, { REG_AEB, 0x33 },
{ REG_VPT, 0xe3 }, { REG_HAECC1, 0x78 },
{ REG_HAECC2, 0x68 }, { 0xa1, 0x03 }, / magic /
{ REG_HAECC3, 0xd8 }, { REG_HAECC4, 0xd8 },
{ REG_HAECC5, 0xf0 }, { REG_HAECC6, 0x90 },
{ REG_HAECC7, 0x94 },
{ REG_COM8, COM8_FASTAEC | COM8_AECSTEP | COM8_AGC | COM8_AEC },
{ 0x30, 0 }, { 0x31, 0 },//disable some delays
/ Almost all of these are magic "reserved" values. /
{ REG_COM5, 0x61 }, { REG_COM6, 0x4b },
{ 0x16, 0x02 }, { REG_MVFP, 0x07 },
{ 0x21, 0x02 }, { 0x22, 0x91 },
{ 0x29, 0x07 }, { 0x33, 0x0b },
{ 0x35, 0x0b }, { 0x37, 0x1d },
{ 0x38, 0x71 }, { 0x39, 0x2a },
{ REG_COM12, 0x78 }, { 0x4d, 0x40 },
{ 0x4e, 0x20 }, { REG_GFIX, 0 },
/{0x6b, 0x4a},*/{ 0x74, 0x10 },
{ 0x8d, 0x4f }, { 0x8e, 0 },
{ 0x8f, 0 }, { 0x90, 0 },
{ 0x91, 0 }, { 0x96, 0 },
{ 0x9a, 0 }, { 0xb0, 0x84 },
{ 0xb1, 0x0c }, { 0xb2, 0x0e },
{ 0xb3, 0x82 }, { 0xb8, 0x0a },
/* More reserved magic, some of which tweaks white balance /
{ 0x43, 0x0a }, { 0x44, 0xf0 },
{ 0x45, 0x34 }, { 0x46, 0x58 },
{ 0x47, 0x28 }, { 0x48, 0x3a },
{ 0x59, 0x88 }, { 0x5a, 0x88 },
{ 0x5b, 0x44 }, { 0x5c, 0x67 },
{ 0x5d, 0x49 }, { 0x5e, 0x0e },
{ 0x6c, 0x0a }, { 0x6d, 0x55 },
{ 0x6e, 0x11 }, { 0x6f, 0x9e }, / it was 0x9F "9e for advance AWB" */
{ 0x6a, 0x40 }, { REG_BLUE, 0x40 },
{ REG_RED, 0x60 },
{ REG_COM8, COM8_FASTAEC | COM8_AECSTEP | COM8_AGC | COM8_AEC | COM8_AWB },
/* Matrix coefficients */
{ 0x4f, 0x80 }, { 0x50, 0x80 },
{ 0x51, 0 }, { 0x52, 0x22 },
{ 0x53, 0x5e }, { 0x54, 0x80 },
{ 0x58, 0x9e },
{ REG_COM16, COM16_AWBGAIN }, { REG_EDGE, 0 },
{ 0x75, 0x05 }, { REG_REG76, 0xe1 },
{ 0x4c, 0 }, { 0x77, 0x01 },
{ REG_COM13, /0xc3/0x48 }, { 0x4b, 0x09 },
{ 0xc9, 0x60 }, /{REG_COM16, 0x38},/
{ 0x56, 0x40 },
{ 0x34, 0x11 }, { REG_COM11, COM11_EXP | COM11_HZAUTO },
{ 0xa4, 0x82/Was 0x88/ }, { 0x96, 0 },
{ 0x97, 0x30 }, { 0x98, 0x20 },
{ 0x99, 0x30 }, { 0x9a, 0x84 },
{ 0x9b, 0x29 }, { 0x9c, 0x03 },
{ 0x9d, 0x4c }, { 0x9e, 0x3f },
{ 0x78, 0x04 },
/* Extra-weird stuff. Some sort of multiplexor register /
{ 0x79, 0x01 }, { 0xc8, 0xf0 },
{ 0x79, 0x0f }, { 0xc8, 0x00 },
{ 0x79, 0x10 }, { 0xc8, 0x7e },
{ 0x79, 0x0a }, { 0xc8, 0x80 },
{ 0x79, 0x0b }, { 0xc8, 0x01 },
{ 0x79, 0x0c }, { 0xc8, 0x0f },
{ 0x79, 0x0d }, { 0xc8, 0x20 },
{ 0x79, 0x09 }, { 0xc8, 0x80 },
{ 0x79, 0x02 }, { 0xc8, 0xc0 },
{ 0x79, 0x03 }, { 0xc8, 0x40 },
{ 0x79, 0x05 }, { 0xc8, 0x30 },
{ 0x79, 0x26 },
void error_led(void){
DDRB |= 32;//make sure led is output
while (1){//wait for reset
PORTB ^= 32;// toggle led
_delay_ms(100);
void twiStart(void){
TWCR = _BV(TWINT) | _BV(TWSTA) | _BV(TWEN);//send start
while (!(TWCR & (1 << TWINT)));//wait for start to be transmitted
if ((TWSR & 0xF8) != TW_START)
error_led();
void twiWriteByte(uint8_t DATA, uint8_t type){
TWDR = DATA;
TWCR = _BV(TWINT) | _BV(TWEN);
while (!(TWCR & (1 << TWINT))) {}
if ((TWSR & 0xF8) != type)
error_led();
void twiAddr(uint8_t addr, uint8_t typeTWI){
TWDR = addr;//send address
TWCR = _BV(TWINT) | _BV(TWEN); /* clear interrupt to start transmission /
while ((TWCR & _BV(TWINT)) == 0); / wait for transmission */
if ((TWSR & 0xF8) != typeTWI)
error_led();
void writeReg(uint8_t reg, uint8_t dat){
//send start condition
twiStart();
twiAddr(camAddr_WR, TW_MT_SLA_ACK);
twiWriteByte(reg, TW_MT_DATA_ACK);
twiWriteByte(dat, TW_MT_DATA_ACK);
TWCR = (1 << TWINT) | (1 << TWEN) | (1 << TWSTO);//send stop
_delay_ms(1);
static uint8_t twiRd(uint8_t nack){
if (nack){
while ((TWCR & _BV(TWINT)) == 0); /* wait for transmission /
if ((TWSR & 0xF8) != TW_MR_DATA_NACK)
error_led();
return TWDR;
else{
TWCR = _BV(TWINT) | _BV(TWEN) | _BV(TWEA);
if ((TWSR & 0xF8) != TW_MR_DATA_ACK)
error_led();
return TWDR;
uint8_t rdReg(uint8_t reg){
uint8_t dat;
twiStart();
_delay_ms(1);
twiStart();
twiAddr(camAddr_RD, TW_MR_SLA_ACK);
dat = twiRd(1);
_delay_ms(1);
return dat;
void wrSensorRegs8_8(const struct regval_list reglist){
uint8_t reg_addr, reg_val;
const struct regval_list *next = reglist;
while ((reg_addr != 0xff) | (reg_val != 0xff)){
reg_addr = pgm_read_byte(&next->reg_num);
reg_val = pgm_read_byte(&next->value);
writeReg(reg_addr, reg_val);
next++;
void setColor(void){
wrSensorRegs8_8(yuv422_ov7670);
// wrSensorRegs8_8(qvga_ov7670);
void setResolution(void){
writeReg(REG_COM3, 4); // REG_COM3 enable scaling
void camInit(void){
writeReg(0x12, 0x80);
_delay_ms(100);
wrSensorRegs8_8(ov7670_default_regs);
writeReg(REG_COM10, 32);//PCLK does not toggle on HBLANK.
void arduinoUnoInut(void) {
cli();//disable interrupts
/* Setup the 8mhz PWM clock
- This will be on pin 11*/
DDRB |= (1 << 3);//pin 11
ASSR &= ~(_BV(EXCLK) | _BV(AS2));
TCCR2A = (1 << COM2A0) | (1 << WGM21) | (1 << WGM20);
TCCR2B = (1 << WGM22) | (1 << CS20);
OCR2A = 0;//(F_CPU)/(2*(X+1))
DDRC &= ~15;//low d0-d3 camera
DDRD &= ~252;//d7-d4 and interrupt pins
_delay_ms(3000);//set up twi for 100khz
TWSR &= ~3;//disable prescaler for TWI
TWBR = 72;//set to 100khz//enable serial
UBRR0H = 0;
UBRR0L = 1;//0 = 2M baud rate. 1 = 1M baud. 3 = 0.5M. 7 = 250k 207 is 9600 baud rate.
UCSR0A |= 2;//double speed aysnc
UCSR0B = (1 << RXEN0) | (1 << TXEN0);//Enable receiver and transmitter
UCSR0C = 6;//async 1 stop bit 8bit char no parity bits
void StringPgm(const char * str){
do{
while (!(UCSR0A & (1 << UDRE0)));//wait for byte to transmit
UDR0 = pgm_read_byte_near(str);
} while (pgm_read_byte_near(++str));
static void captureImg(uint16_t wg, uint16_t hg){
uint16_t y, x;
StringPgm(PSTR("RDY"));
while (!(PIND & 8));//wait for high
while ((PIND & 8));//wait for low
y = hg;
while (y--){
x = wg;
//while (!(PIND & 256));//wait for high
while (x--){
while ((PIND & 4));//wait for low
UDR0 = (PINC & 15) | (PIND & 240);
while (!(PIND & 4));//wait for high
// while ((PIND & 256));//wait for low
_delay_ms(100);
void setup(){
arduinoUnoInut();
camInit();
setResolution();
setColor();
writeReg(0x11, 10); //Earlier it had the value:writeReg(0x11, 12); New version works better for me !!!!
void loop(){
captureImg(320, 240);
It worked! I used the application Serial Port Reader (which I downloaded from that site) to see the images sent from the camera through the Arduino Board.
Now I´m trying something different:
Instead of cable connection and transmission, I´m trying to use APC 220 antennas (APC220 Radio Communication Module-DFRobot) to do the wireless image transmission. I just connected the antennas to the arduino board and expected to receive the images in the serial port reader. It did not work. I´m doing something wrong. The antennas are working in other projects.
I don`t if I need to install a new program to receive the images or something else
@cansateva
Why did you ignore the advice to use code tags when posting your code ?
I don't know what you did but your post using code tags is wrong
Here is your code copied from the IDE using "Copy for forum" and pasted here
#include <stdint.h>
#include <avr/io.h>
#define vga 0
#define qvga 1
#define qqvga 2
#define yuv422 0
#define rgb565 1
#define bayerRGB 2
/* Registers /
#define DBLV 0x6b
struct regval_list
uint8_t reg_num;
uint16_t value;
{ 0x72, 0x11 },
{ 0x73, 0xf1 },
{ REG_HREF, 0xa4 },
{ REG_VREF, 0x0a },
{ REG_COM1, 0 },
{ 0x51, 0 }, / vb /
const struct regval_list ov7670_default_regs PROGMEM = //from the linux driver
/{0x6b, 0x4a},*/ { 0x74, 0x10 },
{ REG_RED, 0x60 },
{ 0x58, 0x9e },
{ REG_COM13, / 0xc3 / 0x48 }, { 0x4b, 0x09 },
{ 0xc9, 0x60 }, / {REG_COM16, 0x38}, /
{ 0x56, 0x40 },
{ 0xa4, 0x82 / Was 0x88 / }, { 0x96, 0 },
{ 0x78, 0x04 },
{ 0x79, 0x26 },
while (1) //wait for reset
_delay_ms(100);
void twiStart(void)
error_led();
TWDR = DATA;
error_led();
error_led();
twiStart();
_delay_ms(1);
if (nack)
error_led();
return TWDR;
else{
error_led();
return TWDR;
uint8_t dat;
twiStart();
_delay_ms(1);
twiStart();
dat = twiRd(1);
_delay_ms(1);
return dat;
next++;
void setColor(void)
void camInit(void)
_delay_ms(100);
UBRR0H = 0;
do
uint16_t y, x;
y = hg;
while (y--)
x = wg;
while (x--)
_delay_ms(100);
arduinoUnoInut();
camInit();
setResolution();
setColor();
writeReg(0x11, 10); //Earlier it had the value:writeReg(0x11, 12); New version works better for me :slight_smile: !!!!
How are you dealing with Wireless transmission and reception errors or overruns ?
It did not work.
Please appreciate that you know what happens when it does 'not work'
I am not receiving any message from errors or overruns. The only thing that happens is when I change cable connection to the Wireless transmission, putting the APC 220 antennas, one connected to the computer and another connected the arduino, i can´t receive any images. I open the "serial port reader" application, it recognises the transmission and says that the connection is "open", but the screen stays white as I´m not receiving any images. What am I doing wrong?
Thank you for the code. I will be more careful next time.
I suspect you have a fundamental missunderstanding of whats involved in transmitting an 'image'
If just one bit of a single byte in the whole image file transfer is not correct then assume no image is received.
Blindly transmitting stuff over a serial RF link and assuming all the data is all going to be received completly error free is daft.
