system
November 9, 2010, 4:08pm
#1
I'm trying to imitate a potentiometer so that I can control an RC car remote control using an Arduino.
What is the best way to imitate a potentiometer with an Arduino? Do I need one of these?
http://en.wikipedia.org/wiki/Digital_potentiometer
Thanks!
Basically yes.
You also need to make sure the voltage of what you are putting this in is less than or equal to the arduino and you need to connect the grounds together.
http://www.arduino.cc/en/Tutorial/SPIDigitalPot
system
November 9, 2010, 4:24pm
#3
The device runs on a 9V batter, but the voltage when I put a multimeter over the terminals of the potentiometer I get between 2.5 and 1.5 volts
Is there a digital potentiometer that only has 1 or 2 outputs instead of 6?
It should be OK then.
Yes there are lots of different types.
http://www.maxim-ic.com/products/digi_pot/
system
November 9, 2010, 6:33pm
#5
A great little "poor mans" digital pot woult be a simle DAC.
(At least I think thats what you're asking :P)
http://www.play-hookey.com/analog/d2a_converter.html
No it would not be a simple DAC. It would only remotely be a DAC if the pot were connected between two rails.
system
November 9, 2010, 6:51pm
#7
Ah I thought he wanted to be able to vary the voltage? I guess I misunderstood the question.
