immediate avrdude error when uploading
This happens when I upload the blink sketch
Arduino: 1.8.13 (Windows 10), Board: "Arduino Uno"
Sketch uses 924 bytes (2%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
C:\Users\David Allen\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude -CC:\Users\David Allen\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf -v -patmega328p -carduino -PCOM3 -b115200 -D -Uflash:w:C:\Users\DAVIDA~1\AppData\Local\Temp\arduino_build_756750/Blink.ino.hex:i
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Users\David Allen\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
         Using Port                    : COM3
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
avrdude done.  Thank you.
An error occurred while uploading the sketch
option enabled in File -> Preferences.
I have had this happen to 4 arduinos: 2 real nanos, one knockoff uno and one real uno. They work perfectly fine for two weeks and then suddenly they crash and I can't communicate with them anymore.
Checked my drivers, tried another computer, tried another cable, tried hitting the reset button before uploading, reinstalling the IDE. Loopback test fails but I may have been doing it wrong, when I type, nothing gets displayed and the rx light flashes, but tx doesn't, even though they are connected. I've been working on a project for a few months and my setback keeps being that the arduino crashes out for some reason, even when I'm only using like 60% dynamic memory and storage space each, and I am sick of it, any help would be greatly appreciated.
