What I am trying to do is that, I want to create my own circuit board, establishing Sensor a accquisition on I2C bus, consisting of these following components:
Atmega328p-pu (with Arduino bootloader preprogrammed) - As I2C master
two digital pressure sensors - I2C Slaves (1 & 2)
1 Humidity/Temperature Sensor - I2C slave 3
So as a start to my small project, I wanted a help. I would like to know that:
If I can buy an Arduino compatible microcontroller with bootloader, Can I use simply this microcontroller and Arduino IDE to burn my sketch? If yes, what all (hardware and software) would I need for the burning process? Are there some good tutorials for this online if you could suggest?
I sincerely seek your support as I am totally new to Arduino..
Some kind of an interface PC-ATmega is needed for programming. In case of the bootloader and programming via USART (serial line) of the ATmega, the most used device is USB/RS232 convertor based on FTDI or similar chip.
Here is an example http://arduino.cc/en/Main/USBSerial. With this device and a few additional components (resistor, capacitors, breadboard, wires) you can develop and upload with Arduino IDE. Here is tutorial http://arduino.cc/en/Main/Standalone how to.
Do you have a normal Arduino board, like the Arduino Uno to test the sensors and develop the code ?
It is best to start with an Arduino Uno, and do all the fancy things once you know about using Arduino.
Do be careful of the terminology. Budvar10 incorrectly described the interface as a "USB/RS232 converter". It has nothing to do with RS-232 - the FTDI and similar chips convert the USB to a "TTL" or more correctly, 5V logic level. You do not want an RS-232 converter; RS-232 is in fact +/- 5 to 15V levels of the opposite polarity.
it is a help if the interface provides a DTR (or RTS) signal for providing an "auto-reset" to the Reset line via a 01µF capacitor.
My next doubt which I have harboured is that regarding the frequency of I2C bus. If I simply connect my sensor to the Arduino on I2C interface with suitable Pull-up Resistors, would it be ok?
Or I need to do some frequency matching?
Thank you!
Pramit
The frequency is not an issue I guess because the master (arduino) provides the clock, just leave it at default.
