I'm looking for a sensor to measure the force of impact. Specifically the impact of a soccer ball on a solid target. It does not have to be accurate, it will not be calibrated or calibrate-able. Just needs return a value that increases with force.
I've used a piezo disk for detecting impacts on a surface. Perhaps it's not the best sensor for that purpose, but it's certainly cheap and simple, and it worked perfectly for my application (which was detecting impact with much less force than yours). I got the idea from remembering the common "Knock Sensor" projects. You would need to make sure to set it up so that the voltages generated by the impacts were within the range of the ADC.
I saw the knock sensor projects as well, but wasn’t sure if I could get a sample rate high enough to capture the peak magnitude of the impact. The accelerometer looks like it has an internal peak capture.
adwsystems:
The Uno max analog sample rate (out of the box) of 9kSPS is going to be quite enough to capture a soccer ball
bounce, lets say it travels at 20m/s, thats about 2.2mm per sample! A soccer ball is going to deform many
cm during the impact, it won’t be hard to integrate the samples in question for a good measure of momentum
and the peak reading will be pretty accurately representative of the peak force.
pert:
The impact causes the wall to move a small amount, and the accelerometer along with it.
So the backstop does have to move in order for the accelerometer to read.
I'm trying to determine, with 200g of range and mounted to the center a piece of 4'x4'x1/2" piece of plywood hanging from the top edge (ie., hinged) impacted by a 16 ounce soccer ball, will the sensor read anything? What range of reading could be expected? How does the readings depend on the weight of the backstop?
Newton’s Third Law: for every force, there is an equal and opposite reaction force.
No kidding, hence the thread. The ask was for an impact sensor, then direction has gone the way of using accelerometers. I’m trying to figure out how to make it work.
What is the informed basis for your decision to use a 200 g acceleration sensor?
If you are not capable of making a reasonable estimate of the acceleration experienced by a soccer ball when it impacts a surface, how do you plan to interpret any measurements you might make?
jremington:
I haven't decided to use it. Hence the question. I'm trying to determine if it is the range sensor to use.
jremington:
Hence the questions. I'm trying to remember my physics classes from 22 years ago. That's not going so well. In the end the exact number doesn't matter. But for the design phase, I need to determine of the sensor is one of the correct range and sensitivity to make sure it will read something non-zero and the maximum value. It is not of much use if it only read 0 or max all the time.
jremington:
If you are serious about this project, you will have to spend some time with the available literature.
I always get a kick out of this assumption. But what needs to be evaluated is the impact of the backstop design on the readings or operation of the device), which is partially independent of the force from the soccer ball. It can be any force applied, but come back to how the design of the backstop affects the operation of the accelerometer.
It’s all about the keywords. I just found something similar.
But the question remains, what is the mounting requirements for the sensor? How does the design of the backstop affect the readings (or what are is the best design characteristics for the backstop)? Should it be heavier, lighter, light and bottom weighted, or?
Mount it on some kind of springs. If you hit it in the center, the deflection for a given soccerball velocity should have a high degree of repeatability.
The pressure in the soccer ball will have some effect. The mass of the plywood will affect it, the heavier the plywood, the smaller the acceleration.
The springs will of course affect the acceleration, too, if they are very stiff or are initially pulled tight.
