Implement one 8x8 led matrix (max7219) into game code
(soory for bad grammar, not a native speaker)
Hello While surfing the web i came accross this Arduino code:(sorry code to long to put into post see attachments)
What i would like to know is how the heck am i to implement a 8x8 led matrix into this game, where the matrix shows the current level (gameRound) and maybe a smiley before the servo kicks in??
simongc.ino (9.4 KB)
You need the library LedControlMS before you can use this. Never used this library, so can't really give you any coding advice. Overall you will need to decide where you want to do your extra display and then run your code before the game continues.
It looks like the library uses one of these 8x8 matrices that are controlled by the MAX7219 IC, with an SPI interface.
  Configuring the LEDMatrix:
  Digital 7 is conneted to DIN (Data IN)
  Digital 12 is connected to CLK (CLocK)
  Digital 11 is connected to CS (LOAD)
  5V is connected to VCC
  GND is connected to GND
  There is only one MAX7219 display module.
ledcontrolms.h
 *    LedControl.h - A library for controling Leds with a MAX7219/MAX7221
 *    Copyright (c) 2007 Eberhard Fahle
 *    Permission is hereby granted, free of charge, to any person
 *    obtaining a copy of this software and associated documentation
 *    files (the "Software"), to deal in the Software without
 *    restriction, including without limitation the rights to use,
 *    copy, modify, merge, publish, distribute, sublicense, and/or sell
 *    copies of the Software, and to permit persons to whom the
 *    Software is furnished to do so, subject to the following
 *    conditions:
 *    This permission notice shall be included in all copies or
 *    substantial portions of the Software.
 *    THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND,
 *    EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES
 *    OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND
 *    NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT
 *    HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY,
 *    WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
 *    FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR
 *    OTHER DEALINGS IN THE SOFTWARE.
#ifndef LedControl_h
#define LedControl_h
#if (ARDUINO >= 100)
#include <Arduino.h>
#else
#include <WProgram.h>
#endif
 * Segments to be switched on for characters and digits on
 * 7-Segment Displays
const static byte charTable[128] = {
    B01111110,B00110000,B01101101,B01111001,B00110011,B01011011,B01011111,B01110000,
    B01111111,B01111011,B01110111,B00011111,B00001101,B00111101,B01001111,B01000111,
    B00000000,B00000000,B00000000,B00000000,B00000000,B00000000,B00000000,B00000000,
    B00000000,B00000000,B00000000,B00000000,B10000000,B00000001,B10000000,B00000000,
    B01111111,B01111011,B00000000,B00000000,B00000000,B00000000,B00000000,B00000000,
    B00000000,B01110111,B00011111,B00001101,B00111101,B01001111,B01000111,B00000000,
    B00110111,B00000000,B00000000,B00000000,B00001110,B00000000,B00000000,B00000000,
    B01100111,B00000000,B00000000,B00000000,B00000000,B00000000,B00000000,B00000000,
    B00000000,B00000000,B00000000,B00000000,B00000000,B00000000,B00000000,B00001000,
const static byte alphabetBitmap[41][6]={
  {0x7E,0x81,0x81,0x81,0x7E,0x0}, //0
  {0x4,0x82,0xFF,0x80,0x0,0x0},  //1
  {0xE2,0x91,0x91,0x91,0x8E,0x0},//2
  {0x42,0x89,0x89,0x89,0x76,0x0},//3
  {0x1F,0x10,0x10,0xFF,0x10,0x0},//4
  {0x8F,0x89,0x89,0x89,0x71,0x0},//5
  {0x7E,0x89,0x89,0x89,0x71,0x0},//6
  {0x1,0x1,0xF9,0x5,0x3,0x0},//7
  {0x76,0x89,0x89,0x89,0x76,0x0},//8
  {0x8E,0x91,0x91,0x91,0x7E,0x0},//9
  {0x0,0x0,0x0,0x0,0x0,0x0},// blank space
  {0x0,0x0,0x90,0x0,0x0,0x0}, //:
  {0x0,0x10,0x10,0x10,0x10,0x0},// -
  {0x0,0x0,0x80,0x0,0x0,0x0},// .
  {0xFC,0x9,0x11,0x21,0xFC,0x0},//Ñ
  {0xFE,0x11,0x11,0x11,0xFE,0x0},//A
  {0xFF,0x89,0x89,0x89,0x76,0x0},//B
  {0x7E,0x81,0x81,0x81,0x42,0x0},//C
  {0xFF,0x81,0x81,0x81,0x7E,0x0},//D
  {0xFF,0x89,0x89,0x89,0x81,0x0},//E
  {0xFF,0x9,0x9,0x9,0x1,0x0},//F
  {0x7E,0x81,0x81,0x91,0x72,0x0},//G
  {0xFF,0x8,0x8,0x8,0xFF,0x0},//H
  {0x0,0x81,0xFF,0x81,0x0,0x0},//I
  {0x60,0x80,0x80,0x80,0x7F,0x0},//J
  {0xFF,0x18,0x24,0x42,0x81,0x0},//K
  {0xFF,0x80,0x80,0x80,0x80,0x0},//L
  {0xFF,0x2,0x4,0x2,0xFF,0x0},//M
  {0xFF,0x2,0x4,0x8,0xFF,0x0},//N
  {0x7E,0x81,0x81,0x81,0x7E,0x0},//O
  {0xFF,0x11,0x11,0x11,0xE,0x0},//P
  {0x7E,0x81,0x81,0xA1,0x7E,0x80},//Q
  {0xFF,0x11,0x31,0x51,0x8E,0x0},//R
  {0x46,0x89,0x89,0x89,0x72,0x0},//S
  {0x1,0x1,0xFF,0x1,0x1,0x0},//T
  {0x7F,0x80,0x80,0x80,0x7F,0x0},//U
  {0x3F,0x40,0x80,0x40,0x3F,0x0},//V
  {0x7F,0x80,0x60,0x80,0x7F,0x0},//W
  {0xE3,0x14,0x8,0x14,0xE3,0x0},//X
  {0x3,0x4,0xF8,0x4,0x3,0x0},//Y
  {0xE1,0x91,0x89,0x85,0x83,0x0}//Z
class LedControl {
 private :
    /* The array for shifting the data to the devices */
    byte spidata[16];
    /* Send out a single command to the device */
    void spiTransfer(int addr, byte opcode, byte data);
  /* We keep track of the led-status for all 8 devices in this array */
    byte status[64];
     /* Data is shifted out of this pin*/
    int LEDCONTROL_SPI_MOSI;
    /* The clock is signaled on this pin */
    int LEDCONTROL_SPI_CLK;
    /* This one is driven LOW for chip selectzion */
    int LEDCONTROL_SPI_CS;
    /* The maximum number of devices we use */
    int maxDevices;
 public:
     * Create a new controler
     * Params :
     * dataPin    pin on the Arduino where data gets shifted out
     * clockPin   pin for the clock
     * csPin    pin for selecting the device
     * numDevices maximum number of devices that can be controled
    LedControl(int dataPin, int clkPin, int csPin, int numDevices=1);
     * Gets the number of devices attached to this LedControl.
     * Returns :
     * int  the number of devices on this LedControl
    int getDeviceCount();
     * Set the shutdown (power saving) mode for the device
     * Params :
     * addr The address of the display to control
     * status If true the device goes into power-down mode. Set to false
     *    for normal operation.
    void shutdown(int addr, bool status);
     * Set the number of digits (or rows) to be displayed.
     * See datasheet for sideeffects of the scanlimit on the brightness
     * of the display.
     * Params :
     * addr address of the display to control
     * limit  number of digits to be displayed (1..8)
    void setScanLimit(int addr, int limit);
     * Set the brightness of the display.
     * Params:
     * addr   the address of the display to control
     * intensity  the brightness of the display. (0..15)
    void setIntensity(int addr, int intensity);
     * Switch all Leds on the display off.
     * Params:
    void clearDisplay(int addr);
    void clearAll();
     * Set the status of a single Led.
     * Params :
     * row  the row of the Led (0..7)
     * col  the column of the Led (0..7)
     * state  If true the led is switched on,
     *    if false it is switched off
    void setLed(int addr, int row, int col, boolean state);
     * Set all 8 Led's in a row to a new state
     * Params:
     * row  row which is to be set (0..7)
     * value  each bit set to 1 will light up the
     *    corresponding Led.
    void setRow(int addr, int row, byte value);
     * Set all 8 Led's in a column to a new state
     * Params:
     * col  column which is to be set (0..7)
    void setColumn(int addr, int col, byte value);
     * Display a hexadecimal digit on a 7-Segment Display
     * Params:
     * digit  the position of the digit on the display (0..7)
     * value  the value to be displayed. (0x00..0x0F)
     * dp sets the decimal point.
    void setDigit(int addr, int digit, byte value, boolean dp);
     * Display a character on a 7-Segment display.
     * There are only a few characters that make sense here :
     *  '0','1','2','3','4','5','6','7','8','9','0',
     *  'A','b','c','d','E','F','H','L','P',
     *  '.','-','_',' '
     * Params:
     * digit  the position of the character on the display (0..7)
     * value  the character to be displayed.
    void setChar(int addr, int digit, char value, boolean dp);
  //Returns the array number in the alphabetBitmap array
  int getCharArrayPosition(char c);
  void writeString(int mtx, char * displayString);
    void displayChar(int matrix, int charIndex);
#endif  //LedControl.h
Have tried to make som other changes, this time every ting exept the matrix is not working… :confused:
And neither is the servo
simonledmatrix.ino (13.7 KB)
Sprite.h (1.39 KB)
Matrix.h (1.44 KB)
