Implementation of Voice Command to Different Codes
I have a code compiled for my robot, but I am having trouble applying the voice command to the void setup so the action is only performed when I say the command. I am using a Voice Recognition Shield V2, or a Geeetech High Sensitivity Voice Recognition Module.
[#include <Servo.h> //include Servo library
const int RForward = 0;
const int RBackward = 180;
const int LForward = RBackward;
const int LBackward = RForward;
const int RNeutral = 90;
const int LNeutral = 90; //constants for motor speed
const int pingPin = 7;
const int irPin = 0;  //Sharp infrared sensor pin
const int dangerThresh = 10; //threshold for obstacles (in cm)
int leftDistance, rightDistance; //distances on either side
Servo panMotor;
Servo leftMotor;
Servo rightMotor; //declare motors
long duration; //time it takes to recieve PING))) signal
  rightMotor.attach(11);
  leftMotor.attach(10);
  panMotor.attach(6); //attach motors to proper pins
  panMotor.write(90); //set PING))) pan to center
  int distanceFwd = ping();
  if (distanceFwd>dangerThresh) //if path is clear
    leftMotor.write(LForward);
    rightMotor.write(RForward); //move forward
  else //if path is blocked
    leftMotor.write(LNeutral);
    rightMotor.write(RNeutral);
    panMotor.write(0);
    rightDistance = ping(); //scan to the right
    panMotor.write(180);
    delay(700);
    leftDistance = ping(); //scan to the left
    panMotor.write(90); //return to center
    delay(100);
    compareDistance();
void compareDistance()
  if (leftDistance>rightDistance) //if left is less obstructed
    leftMotor.write(LBackward);
    rightMotor.write(RForward); //turn left
  else if (rightDistance>leftDistance) //if right is less obstructed
    rightMotor.write(RBackward); //turn right
   else //if they are equally obstructed
    rightMotor.write(RBackward); //turn 180 degrees
long ping()
  // Send out PING))) signal pulse
  pinMode(pingPin, OUTPUT);
  digitalWrite(pingPin, LOW);
  delayMicroseconds(2);
  digitalWrite(pingPin, HIGH);
  delayMicroseconds(5);
  //Get duration it takes to receive echo
  pinMode(pingPin, INPUT);
  duration = pulseIn(pingPin, HIGH);
  //Convert duration into distance
  return duration / 29 / 2;
Sorry if I wasn't clear enough.
What I was trying to say was that I recorded three voice commands for my first group- Stop, Wander, Look Around
I want to run separate codes for each of them, the stop being indefinite delay- which I don't know a code for?
Wander being a self run obstacle avoidance code, as listed above.
Look around being a 90 degree sweep of the pan motor in both directions.
I need to know how I can make the code above apply only when I say Wander and the VR replies.
I also don't know how to make a "stop" code so it would be great if someone helped!
:slight_smile: Thanks!
