Implementing code with ServoEasing
Hello to all.
I would like to insert in my code for the management of two servos the library servoeasing.h . What changes do I have to make to the code to make the library work?
//---- Included Libraries ----//
#include <Wire.h>                           // I²C library
#include <math.h>                           // trig functions
#include <Adafruit_Sensor.h>                // Base library for sensors
#include <Adafruit_BNO055.h>                // BNO055 specific library
#include <utility/imumaths.h>               // Vector, Matrix, and IMUMath library
#include <servo.h>                          // Standard Servo library
#define BNO055_SAMPLERATE_DELAY_MS (20)     // Set pause between samples
//---- Variable Declaration ----//
boolean debug = true;                       // true/false = extra/no information over serial
int rollPin  = 9;                           // Digital pin for roll
int pitchPin = 10;                          // Digital pin for pitch
float roll, pitch;                     // Variable to hold roll, pitch information
Adafruit_BNO055 bno = Adafruit_BNO055();    // Use object bno to hold information
Servo rollServo;                            // Create servo rollServo
Servo pitchServo;                           // Create servo pitchServo
void setup(void) {
  rollServo.attach(rollPin);                // The rollServo is connected at rollPin
  pitchServo.attach(pitchPin);              // The pitchServo is connected at pitchPin
  Serial.begin(2000000);                     // Create serial connection at 115,000 Baud
  if (!bno.begin())                         // Attempt communication with sensor
    Serial.print("Ooops, no BNO055 detected ... Check your wiring or I2C ADDR!");
  delay(1000);                               // Wait 1 seconds to allow it to initialize
  bno.setExtCrystalUse(true);               // Tell sensor to use external crystal
//---- Main Program Loop ----//
  //---- Request Euler Angles from Sensor ----//
  sensors_event_t event;
  bno.getEvent(&event);
 /* if (debug) {                             // If debug is true, send information over serial
    Serial.print("Measured Euler Roll-Pitch");
    Serial.print("\t pitch: "); Serial.print(event.orientation.y, 4); Serial.print("\t");
    Serial.print("\t  roll: "); Serial.print(event.orientation.z, 4); Serial.println();
  /* Remap information from the sensor over the 0° - 180° range of the servo
     The Roll values are between -90° and +90°
     The Pitch values are between -180° and +180°
  int servoRoll =  map(event.orientation.z,  -90, 90, 180, 0);
  int servoPitch = map(event.orientation.y, -90, 90, 0, 180);
  servoRoll = constrain(servoRoll, 45, 135);  //limits roll angle range
  servoPitch = constrain(servoPitch, 70, 115);//limits pitch angle range
    Serial.print("\t Pitch Servo: "); Serial.print(servoPitch); Serial.print("\t");
    Serial.print("\t  Roll Servo: "); Serial.print(servoRoll);  Serial.println();
  if (debug) {
    Serial.println("Calculated Servo Roll-Pitch");
    Serial.print("\t roll:");  Serial.print(servoRoll, DEC);  Serial.print("\t");
    Serial.print("\t pitch:"); Serial.print(servoPitch, DEC); Serial.print("\t");
  rollServo.write(servoRoll);              // Send mapped value to rollServo
  pitchServo.write(servoPitch);            // Send mapped value to pitchServo
  delay(BNO055_SAMPLERATE_DELAY_MS);       // Wait before rerunning loop
Thanks to those who will dedicate a moment of their time to me :wink:
I would start by downloading the library and looking at the examples that come with it.
I've never used it but it looks like you just need to follow the instructions at GitHub - ArminJo/ServoEasing: Arduino library to enable smooth servo movement. That and the examples cover it pretty well.
Give it a try and let us know if you have any problems.
Steve
Welp, that looks like a bug. You might want to append a “;” at the end of “if (!bno.begin())” since you commented out the if statement’s content.
Also, curious, what is your main goal with this project?
blh64:
Thanks. The examples helped me figure out where I was wrong.
slipstick:
Steve
Thank you, the explanation was helpful. I had a compilation problem that I solved by looking at the examples.
The idea was to solve a jitter problem with this library, but the problem is still there.
Servo jitter problems are most often caused by insufficient power or sometimes by servos not powerful enough for the load they're expected to move/hold in place.
What is the project, what servos and how are you powering them?
Steve
slipstick:
Steve
I'm powering them with a dc power supply that can give up to 5 Amps. I've the same problem with a car battery and linear tension regulators (that can give 1,5 amp to each servo).
I've posted the problem in this topic :
Power_Broker:
Welp, that looks like a bug. You might want to append a ";" at the end of "if (!bno.begin())" since you commented out the if statement's content.
I commented out the serial print because I have a problem of jittering on the servos. I have read in a topic, that the problem can be a communication problem due to the timer and interrupts and a possible solution was to comment out the serial print.
I want to stabilize a camera to mount on a motorcycle.
The topic where I posted the problem is this: Jitter problem with the servos managed by Arduino UNO and IMU sensor (BNO055) - Programming Questions - Arduino Forum
Hello, everyone! I wanted to tell you that I managed to solve the problem of jitter. To do this I replaced the servo.h library with the "Adafruit_TiCoServo.h" library found on the "The TiCoServo Library | Using NeoPixels and Servos Together | Adafruit Learning System" page. This library controls servos (only on certain pins) without being influenced by an i2c bus (I tested it out and it works perfectly).
Thank you very much to all for your advice, greetings from Switzerland :wink:
Just for interest where did you get your original library? The standard Arduino library for servos is Servo.h (note the capital S). I can't compile your code because of that.
Steve
