Implementing CRC (8 bit, Maxim 1-wire)
I’m trying to implement the algorithm as per https://www.maximintegrated.com/en/app-notes/index.mvp/id/27.
I’m using 0x02 as testinput, to be able to compare the result with Example 2 page 5 in the linked application note, it goes well until the 6th cycle.
I get the serial output (leading zeros added for readability):
--- Begin ---
00000000
00000000
10001100
01000110
00100011
10011101
11001110
01100111
which should be
--- Begin ---
00000000
00000000
10001100
01000110
00100011
10011101
11000010    (not 11001110)
01100001    (not 01100111)
Can anybody see what’s going wrong? Thanks.
byte temp;
byte old_X;
int i = 0;
////////// Testdata ///////
byte input = 0b00000010;
byte X = 0b00000000;
// X = X0 X1 X2 X3 X4 X5 X6 X7
if(i == 0){Serial.println("— Begin —");}
if(i < 8){
Serial.println(X, BIN);
old_X = X;
// X = X >> 1
// X0 = X8 XOR input
temp = (input ^ old_X) << 7;
X = X >> 1;
X = X | temp;
// X4 = old X3 XOR new X0
temp = ( (X >> 3) ^ old_X ) & 0b00010000;
temp = temp >> 1;
X = X | temp;
// X5 = old X4 xor new X0
temp = ( (X >> 4) ^ old_X ) & 0b00001000;
temp = temp >> 1;
X = X | temp;
++i;
input = input >> 1;
The MAXIM Onewire 8-bit CRC is implemented in the OneWire library. It would save you a lot of pain :)
Pete
Hi Pete Nice to hear from you.
I know, but I would like to implement it anyway.
Can you see what's going wrong?
Markus
After I’d figured out that you were trying to implement the shift register in Figure 2 of your link, I changed your code to this:
byte temp;
byte old_X;
int i = 0;
// Print one byte as 8 binary bits including leading zeros
void print_binary(byte b)
  int i,bit = 0x80;
  for(i=0;i<8;i++) {
    if(b&bit)Serial.print("1");
    else Serial.print("0");
    bit >>= 1;
  while(!Serial);
  for(int i=0;i<8;i++) {
    print_binary(X);
    old_X = X;
    // generate the feedback bit from the XOR gate at X8
    X = X >> 1;
    X = X | temp;
    // XOR the feedback into X4
    X = X ^ (temp >> 4);
    // XOR the feedback into X5
    X = X ^ (temp >> 5);
    input = input >> 1;
Pete
