Overview
I am currently working to implement ESP-NOW Protocol between two ESP8266 Modules. One Module acts as Master and it sends a message (say "Hello") and the other module, which is the slave, received the message and displays it on the serial monitor in Arduino IDE.
Now I am attempting to save the Received Data, on the Slave Module, to a MySQL Database using a PHP script.
I tried making changes in the code accordingly but facing some issues
Code for Master Device
#include <ESP8266WiFi.h>
#include <espnow.h>
//Slave MAC addresses
uint8_t slaveMac[] = { 0x40, 0x91, 0x51, 0x55, 0xA2, 0x51 };
// Structure to hold the data
typedef struct {
char message[50];
} MyData;
MyData dataToSend;
const char *ssid = "Arya_Krish";
const char *password = "$Disco427";
void onDataReceived(uint8_t *mac, uint8_t *data, uint8_t len) {
// Copy received data to our data structure
memcpy(&dataToSend, data, sizeof(dataToSend));
// Null-terminate the message to print it
dataToSend.message[len] = '\0';
// Print received data
Serial.print("Received from ");
for (int i = 0; i < 6; i++) {
Serial.print(mac[i], HEX);
if (i < 5) {
Serial.print(":");
Serial.print(" - Message: ");
Serial.println(dataToSend.message);
WiFi.begin(ssid, password);
Serial.println("Connecting to WiFi...");
Serial.println("Connected to WiFi");
// Init ESP-NOW
if (esp_now_init() != 0) {
Serial.println("Error initializing ESP-NOW");
return;
// Register callback function to handle received data
esp_now_set_self_role(ESP_NOW_ROLE_CONTROLLER);
esp_now_register_recv_cb(onDataReceived);
// Add the Slave to peer list
esp_now_add_peer(slaveMac, ESP_NOW_ROLE_SLAVE, 1, NULL, 0);
Serial.println("Master module initialized");
// Send data to the Slave
snprintf(dataToSend.message, sizeof(dataToSend.message), "Hello");
esp_now_send(slaveMac, (uint8_t *)&dataToSend, sizeof(dataToSend));
Serial.println("Message Sent");
// Wait for 2 seconds before sending the next message
delay(2000);
Code for Slave Device
#include <espnow.h>
#include <ESP8266HTTPClient.h>
typedef struct {
char message[50];
} MyData;
MyData receivedData;
// WiFi credentials
const char *ssid = "wifi_ssid";
const char *password = "wifi_password";
// MySQL server details
const char *serverAddress = "192.168.1.10";
const int serverPort = 8080;
const char *phpScript = "/espNow/server.php";
const String url = "http://" + String(serverAddress) + ":" + String(serverPort) + String(phpScript);
memcpy(&receivedData, data, sizeof(receivedData));
receivedData.message[len] = '\0';
if (i < 5) {
Serial.print(":");
Serial.println(receivedData.message);
sendDataToMySQL();
// Connect to WiFi
// Initialize ESP-NOW
return;
esp_now_set_self_role(ESP_NOW_ROLE_SLAVE);
Serial.println("Slave module initialized");
// Your code here (if needed)
delay(1500);
void sendDataToMySQL() {
if (WiFi.status() == WL_CONNECTED) {
WiFiClient client;
HTTPClient http;
char dataBuffer[50];
strncpy(dataBuffer, receivedData.message, sizeof(dataBuffer));
http.begin(client, url);
http.addHeader("Content-Type", "application/x-www-form-urlencoded");
int httpResCode = http.POST(dataBuffer);
Serial.print("HTTP Response Code: ");
Serial.println(httpResCode);
http.end();
When I run the Slave code, and try to send a POST request using httpClient, I get an exception(9) error and the module crashes. I tried to find solutions for it but I couldn't.
I'll share the Serial Monitor output Below
Connected to WiFi
Received from C8:C9:A3:52:F3:68 - Message: Hello
--------------- CUT HERE FOR EXCEPTION DECODER ---------------
Exception (9):
epc1=0x401058bc epc2=0x00000000 epc3=0x00000000 excvaddr=0x00000003 depc=0x00000000
>>>stack>>>
ctx: sys
sp: 3fffea80 end: 3fffffb0 offset: 0150
3fffebd0: 40105aed 002d1c6b 3ffee72c 00000000
3fffebe0: 3ffee190 3ffee72c 000000fa 40214034
3fffebf0: 00000000 001544e7 40204da4 00001388
3fffec00: 3ffee72c 0000118b 00001388 00001388
