Hello all,
Per the title, I am trying to implement a finite state machine (actually a series of tasks, all of which are FSMs, but that will come later) in Arduino and am running into some issues.
My program is built as follows:
A main .INO file, which will serve as a mastermind file for calling a set of .CPP and .H files, which will each contain a task.
Right now I am just trying to get one FSM up and running before implementing task scheduling, etc.
Here is the code I have, broken into 3 files: Testing3.ino, t3p0.cpp and t3p0.h.
Testing3.ino:
#include "t3p0.h"
pat0 Pat0;
Serial.println("loop"); //used for debugging purposes
Pat0.main(); //Right now, I only want to call one of my tasks, later I will build in task handling, etc.
t3p0.cpp:
#include "t3p0.h"
#include <Arduino.h>
#include "HardwareSerial.h"
#include "print.h"
pat0::pat0(){
pat0fn pat0_array[] = {&pat0::p0_s0, &pat0::p0_s1, &pat0::p0_s2};
void pat0::p0_s0(){
Serial.println("p0 state0");
zerostate++;
void pat0::p0_s1(){
Serial.println("p0 state1");
zerostate++;
void pat0::p0_s2(){
Serial.println("p0 state2");
zerostate=0;
void pat0::main(){
//This is where I want to implement my state machine.
t3p0.h:
t3p0.h
Created on: Dec 13, 2018
Author:
#ifndef T3P0_H_
#define T3P0_H_
class pat0
static int zerostate; //This is the state variable for task/pattern 0.
public:
pat0(); //Class constructor
void p0_s0(); // Function for state 0 of pattern 0.
void p0_s1(); // Function for state 1 of pattern 0.
void p0_s2(); // Function for state 2 of pattern 0.
void main();
typedef void (pat0::*pat0fn)();
extern pat0fn pat0_array[3];
#endif /* T3P0_H_ */
My goal is for my mastermind file to decide which task it needs to be running on each run through loop(), and then step into the relevant .cpp file, and have the task's state machine be implemented in a main() function there.
The issue I am having is when I attempt to use the array of pointer to member functions that I created. I have tried the following methods, all in t3p0's main() function, which right now I automatically run when I put the code on the board:
METHODS
Method1 :
(pat0_array[zerostate])();
//Method 2:
(pat0fn ->*pat0_array[zerostate])();
//Method 3:
(pat0fn .*pat0_array[zerostate])()
I attempted these based on feedback I was given in a still open thread, which I plan to update as soon as this is working properly.
Here are the errors I get when I attempt methods 1-3
ERRORS:
//Error for Method 1:
sketch\t3p0.cpp: In member function 'void pat0::main()':
t3p0.cpp:39:27: error: must use '.*' or '->*' to call pointer-to-member function in 'pat0_array[((pat0*)this)->pat0::zerostate] (...)', e.g. '(... ->* pat0_array[((pat0*)this)->pat0::zerostate]) (...)'
exit status 1
//Error for Method 2
t3p0.cpp:40:10: error: expected primary-expression before '->*' token
exit status 1
//Error for Method 3
t3p0.cpp:40:10: error: expected primary-expression before '.*' token
(pat0fn .*pat0_array[zerostate])();
exit status 1
I have also tried the same three methods but passing in an integer instead of zerostate, just in case. I used the integer 0. The results were the same.
Has anyone seen this before? If I don't include the 3 lines that cause errors, I can run the code. It will step through my loop() function in Testing3.ino, then when loop() calls Pat0.main(), I can individually call any of the 3 state functions in t3p0 within main. I just can't seem to use my array of pointers to member functions.
I appreciate any insight folks can give!
