Implementing overloaded function stops processing.
I am trying to learn function overloading and not sure why this does not work .
The code snippet is the only real code in setup, I have commented out most of the other function calls.
I am using two overloaded functions
Here are the definitions
bool DebugPrintNew ( char * Print, char*  Value )
bool DebugPrintNew ( char * Print, int Value )
AS soon as the the function with overloaded parameters  char * Print, int Value gets  coded
the program stops. And it does not have to be used to cause this behavior.
Both functions work as expected when coded separately.
Personally I do not see any advantage using overloaded functions as far as memory saving and have no problem having functions with different names.
[b]But for learning purpose  I sure would like to know what is going on. [/b]
#ifdef DEBUG_SERIAL
  Serial.println("test DEBUG_SERIAL");
  char *Print = "Test Print ";
  char *Value = "Test Value ";
  DebugPrintNew(Print,Value); // passing char* s
STOP
  int iValue = 12345;
  DebugPrintNew( Print,iValue); // passing char* and iValue
  STOP
    for(;;);
#endif
return;
    for(;;);
By over loading is not intended to save memory.
Mark
Maybe sort out the tags?
holmes4:
    for(;;);
Mark
Thanks Mark.
I guess since these functions do pretty much same except handle different parameter type it does not improve memory usage.
I may chop it up and replace common code with functions later.
As far as for(;;); goes - that is the poor man brake point I use.
  for(;;); Stops your code dead, what kind of ICE are you using?
Mark
holmes4:
Mark
I just collect data I need before the for(;;); and output it to LCD. Been working OK.
Just found out if you output more than 16 characters to LCD things for wild.
I thing I 'll try scrolling thru the line characters , just for fun.
And I am getting pretty handy using types conversions in the process.
Tried Serial.print but not having much luck with it especially when I forget to add closing null to character array pointer.
Vaclav
