This isn’t so much a question about how to do something, it’s more a question about how to do something better.
Thanks to dc42 I’ve managed to create a library that uses LiquidCrystal.h.
To implement the print() methods in my library I’ve explicitly coded methods that directly call the LiquidCrystal object (see attached files). I’ve coded one method to print integers, and another method to print strings, these both work fine. I’ve noticed that neither the .cpp and .h files for LiquidCrystal library include any coding for print() methods, but the class definition in the .h file does include the following phrase “: public Print” after the class name. So, firstly, what does “: public Print” do? And secondly, why can’t I do something similar to implement the print methods myself in my class (I’ve tried adding “: public Print” after the class name but get an error (listed below)
LCDvario.h
#ifndef LCDvario_h // These lines (together with the #endif at the end of the file) prevent
#define LCDvario_h // any problems occuring if this library should be included twice.
extern "C" {
#include <string.h>
#include <stdlib.h> // needed for 'free'
#include "WProgram.h" // needed for 'Serial'
#include <avr/pgmspace.h> // Needed for PROGMAN stuff
#include <ProgmemConst.h> // Global progmem constants
#include <Wire.h> // Needed for I2C comms.
#include <LiquidCrystal.h> // Drives the LCD screen
#include <inttypes.h>
#include "Print.h"
class LCDvario : public Print
public:
LCDvario(uint8_t rs, uint8_t enable,uint8_t d0, uint8_t d1, uint8_t d2, uint8_t d3); // Constructor
void begin(uint8_t cols, uint8_t rows, uint8_t charsize = LCD_5x8DOTS); // initialise stuff
//void print(int x);
//void print(char * x);
private:
// Member variables
LiquidCrystal _lcd;
#endif
LCDvario.cpp
extern "C" {
#include <string.h>
#include <stdlib.h>
//#include <cstring> // replacement for "extern "C" {#include <string.h>}" .... produces 'error file not found'
//#include <cstdlib> // replacement for #include <stdlib.h> .... produces 'error file not found'
#include <Wire.h>
#include <math.h> // needed for log functions
#include "LCDvario.h" // Header for this library
LCDvario::LCDvario(uint8_t rs,uint8_t enable,uint8_t d0,uint8_t d1,uint8_t d2,uint8_t d3) : _lcd(rs,enable,d0,d1,d2,d3)
void LCDvario::begin(uint8_t cols, uint8_t rows, uint8_t charsize)
_lcd.begin(cols, rows);
//void LCDvario::print(int x)
// _lcd.print(x);
//void LCDvario::print(char * x)
// _lcd.print(x);
The sketch…
#include <Wire.h> // Library to control I2C comunications
#include <LiquidCrystal.h> // Controls access to the LCD display
#include <LCDvario.h> // LCD screen customised for vario use.
const int rs=8,en=9,d4=10,d5=11,d6=12,d7=13; // Pin definitions for LCD
LCDvario lcd(rs, en, d4, d5, d6, d7); // Display
// set up the LCD's number of columns and rows:
lcd.begin(16, 2);
lcd.print("Starting !");
//lcd.print(123);
The error…
LCDvarioTest:11: error: cannot declare variable ‘lcd’ to be of abstract type ‘LCDvario’
C:\all_apps\arduino-0021\libraries\LCDvario/LCDvario.h:18: note: because the following virtual functions are pure within ‘LCDvario’:
C:\all_apps\arduino-0021\hardware\arduino\cores\arduino/Print.h:40: note: virtual void Print::write(uint8_t)
As I said, this problem isn’t a show-stopper, the two methods I’ve implemented manually work, but I’d like to know if I can do the same thing without having to code each different print method (for floats, longs, bytes etc) individually.
Thanks
