Implementing recursive "dir" command: I can't call "dir" 3 times :-)
I’m writing a small interpreter for simple SD commands like “dir” or “type the content of a specific file in serial monitor” or others.
The “dir” command has been implemented recursively using printDirectory(), like in the examples.
The strange situation is the following: if I complie the code and call printDirectory() one time, it works.
If I compile “dir” and call two times in sequence, it do wors.
But if I compile and then call three times, the third call doesn’t find any file; it seems that a sort of “close” or “rewind” of the SD have to be made, but I wasn’t able to find what to do.
Here the failing code with the 3 call in sequence:
#include <SD.h>
File root;
SD.begin(4);
Serial.println("****************************************");
SD.begin(4);
root = SD.open("/");
printDirectory(root, 0);
Serial.println(“done!”);
SD.begin(4);
SD.begin(4);
// nothing happens after setup finishes.
void printDirectory(File dir, int numTabs) {
Serial.println(“Starting directory analysis…”);
while(true) {
File entry = dir.openNextFile();
if (! entry) {
// no more files
Serial.println(“nomorefiles”);
for (uint8_t i=0; i<numTabs; i++) {
Serial.print(’\t’);
Serial.print(entry.name());
if (entry.isDirectory()) {
Serial.println("/");
printDirectory(entry, numTabs+1);
// files have sizes, directories do not
Serial.print("\t\t");
Serial.println(entry.size(), DEC);
You should only call SD.begin(4); once.
Pete
Thanks Pete,
I've tried but the output of the third "call"remain the same:
Starting directory analysis..
SYSTEM~1/
INDEXE~1 76
nomorefiles
EXAMPLE2.TXT 0
EXAMPLE3.TXT 0
TEST.TXT 126
PIPPO 18
PLUTO 18
PAPERINO 18
MINNIE 18
CLARAB 18
QUI 18
nomorefiles
done!
SYSTEM~1/
INDEXE~1 76
nomorefiles
EXAMPLE2.TXT 0
EXAMPLE3.TXT 0
TEST.TXT 126
PIPPO 18
PLUTO 18
PAPERINO 18
MINNIE 18
CLARAB 18
QUI 18
nomorefiles
done!
nomorefiles
done!
That isn’t the complete code for printdirectory.
You need entry.close():
     entry.close();
Note my use of code tags. Read How to post code properly and then use the </> icon to create
[code]...[/code]
tags around your code so that it is easier to read.
Pete
Thanks a lot, Pete.
Unfortunatly, despite your help, the problem wasn't solved.
But, after reading one more time the language gude, I have inserted a "caller function" (that should be called from the main) named "dir()" and this function dir() calls printdirectory().
Finally the problem was solved inserting a call to root.rewindDirectory(); just before the first call of printdirectory().
At the and, this is the code of the dir() function:
void dir()  {
   root.close();
Being the SD seen from a program as an abstract data, I suppose that the call to root.rewind() resets some global status variable defined and used inside the SD library.
At the end, we got it!! :slight_smile:
Thanks a lot
Fabio
