Import library problem
Hi, I'm using the old 1.0.6 version of arduino. This is because of an outdated library. However this library was put in multiple folders and because of it, the library wasn't funtioning properly. The problem is that this library (and other libraries added through this option) don't show up in the libraries folder in the arduino program files. When I tried to deinstall and install the IDE again, the libraries remained the same. They showed up again and the old library was still malfunctioning. Any ideas on how to solve this problem?
this library? this option? My crystal ball is unfortunately broken...
But to try to help, if you add a library to Arduino it shouldn't be in the "program files/Arduino" folder but in a folder called libraries in your Sketchbook ("my documents/Arduino" by default).
