Today I uploaded 2 LCD5110 libraries. Those libraries are the LCD5110_Graph and LCD5110_Basic. I keep getting errors like fatal error: LCD5110_Graph.h: No such file or directory.
I've tried not only my source code which compiles properly with my Arduino IDE installed on a Windows 7 machine as well as the Example source code that is part of the library install and in all cases it fails within the On-Line Arduino Editor.
Here's the Example Source code:
// LCD5110_Graph - Version: Latest
#include <LCD5110_Graph.h>
// LCD5110_Graph_Demo
// Copyright (C)2015 Rinky-Dink Electronics, Henning Karlsen. All right reserved
// web: http://www.RinkyDinkElectronics.com/
// This program is a demo of most of the functions
// in the library.
// This program requires a Nokia 5110 LCD module.
// It is assumed that the LCD module is connected to
// the following pins using a levelshifter to get the
// correct voltage to the module.
// VCC - 3.3
// GND - GND
// SCK/SCLK - Pin 8
// MOSI/DN(MOSI) - Pin 9
// DC - Pin 10
// RST - Pin 11
// CS/SCE - Pin 12
#define SCK_PIN 8
#define MOSI_PIN 9
#define DC_PIN 10
#define RST_PIN 11
#define CS_PIN 12
//LCD5110 myGLCD(8,9,10,11,12);
LCD5110 myGLCD(SCK_PIN,MOSI_PIN,DC_PIN,RST_PIN,CS_PIN);
extern uint8_t SmallFont[];
extern uint8_t arduino_logo[];
extern unsigned char TinyFont[];
extern uint8_t The_End[];
extern uint8_t pacman1[];
extern uint8_t pacman2[];
extern uint8_t pacman3[];
extern uint8_t pill[];
float y;
uint8_t* bm;
int pacy;
myGLCD.InitLCD();
myGLCD.setFont(SmallFont);
randomSeed(analogRead(7));
myGLCD.clrScr();
myGLCD.drawBitmap(0, 0, arduino_logo, 84, 48);
myGLCD.update();
delay(2000);
myGLCD.clrScr();
myGLCD.print("LCD5110_Graph", CENTER, 0);
myGLCD.print("DEMO", CENTER, 20);
myGLCD.drawRect(28, 18, 56, 28);
for (int i=0; i<6; i++)
myGLCD.drawLine(57, 18+(i*2), 83-(i*3), 18+(i*2));
myGLCD.drawLine((i*3), 28-(i*2), 28, 28-(i*2));
myGLCD.setFont(TinyFont);
myGLCD.print("(C)2015 by", CENTER, 36);
myGLCD.print("Henning Karlsen", CENTER, 42);
myGLCD.update();
delay(5000);
myGLCD.clrScr();
for (int i=0; i<48; i+=2)
myGLCD.drawLine(0, i, 83, 47-i);
myGLCD.update();
for (int i=83; i>=0; i-=2)
myGLCD.drawLine(i, 0, 83-i, 47);
myGLCD.update();
delay(2000);
myGLCD.clrScr();
myGLCD.drawRect(0, 0, 83, 47);
for (int i=0; i<48; i+=4)
myGLCD.drawLine(0, i, i*1.75, 47);
myGLCD.update();
myGLCD.drawLine(83, 47-i, 83-(i*1.75), 0);
myGLCD.update();
delay(2000);
myGLCD.clrScr();
for (int i=0; i<8; i++)
myGLCD.drawRoundRect(i*3, i*3, 83-(i*3), 47-(i*3));
myGLCD.update();
delay(2000);
myGLCD.clrScr();
for (int i=0; i<17; i++)
myGLCD.drawCircle(41, 23, i*3);
myGLCD.update();
delay(2000);
myGLCD.clrScr();
myGLCD.drawLine(0, 23, 84, 23);
myGLCD.drawLine(41, 0, 41, 47);
for (int c=0; c<4; c++)
for (int i=0; i<84; i++)
y=i*0.017453292519943295769236907684886;
myGLCD.invPixel(i, (sin(y*6)*20)+23);
myGLCD.update();
delay(20);
delay(2000);
for (int pc=0; pc<3; pc++)
pacy=random(0, 28);
for (int i=-20; i<84; i++)
myGLCD.clrScr();
for (int p=4; p>((i+20)/20); p--)
myGLCD.drawBitmap(p*20-8, pacy+7, pill, 5, 5);
switch(((i+20)/3) % 4)
case 0: bm=pacman1;
case 1: bm=pacman2;
case 2: bm=pacman3;
case 3: bm=pacman2;
myGLCD.drawBitmap(i, pacy, bm, 20, 20);
myGLCD.update();
delay(25);
for (int i=0; i<25; i++)
myGLCD.clrScr();
myGLCD.drawBitmap(0, i-24, The_End, 84, 24);
myGLCD.update();
delay(100);
myGLCD.print("Runtime (ms):", CENTER, 32);
myGLCD.printNumI(millis(), CENTER, 40);
myGLCD.update();
for (int i=0; i<5; i++)
myGLCD.invert(true);
myGLCD.invert(false);
Thanks
LJ
