Import sensor fails
I have a giga with a display shield and an arducam GC2145
the display sketch example in the IDE 2.0 works well: it reads the camera and shows the image. so, hardware should be good then
however, if i flash my giga to openmv with latest firmware and then try to do same, the example script fails on import sensor with
RuntimeError: Failed to detect the image sensor or image sensor is detached.
any ideas or suggestions would be highly appreciated.
  • erik
Can you post an annotated schematic showing exactly how you have assembled this. Be sure to include all connections, power, ground, power sources and note any wires over 10"/25cm in length.
thanks! sure: see attached pictures. no wires, just the cam on the shield while attached to the board. again: like this it works with the arudiuno sketch, and fails with the openmv script on the import sensor statement. power via usb c from an iMac 2017.
Hello @eerduino, please could you share the OpenMV code you are using?
Thank you
