Import template
(iaqSensor.bme680Status != BME680_OK) { ^~~~~~~~~ /tmp/2781184141/Greenhouse_Humidity_and_Temperature_jul23a/Greenhouse_Humidity_and_Temperature_jul23a.ino:119:33: note: suggested alternative: 'BME68X_OK' if (iaqSensor.bme680Status != BME680_OK) { ^~~~~~~~~ BME68X_OK /tmp/2781184141/Greenhouse_Humidity_and_Temperature_jul23a/Greenhouse_Humidity_and_Temperature_jul23a.ino:120:19: error: 'class Bsec' has no member named 'bme680Status'; did you mean 'bme68xStatus'? if (iaqSensor.bme680Status < BME680_OK) { ^~~~~~~~~~~~ bme68xStatus /tmp/2781184141/Greenhouse_Humidity_and_Temperature_jul23a/Greenhouse_Humidity_and_Temperature_jul23a.ino:121:58: error: 'class Bsec' has no member named 'bme680Status'; did you mean 'bme68xStatus'? output = "BME680 error code : " + String(iaqSensor.bme680Status); ^~~~~~~~~~~~ bme68xStatus /tmp/2781184141/Greenhouse_Humidity_and_Temperature_jul23a/Greenhouse_Humidity_and_Temperature_jul23a.ino:126:60: error: 'class Bsec' has no member named 'bme680Status'; did you mean 'bme68xStatus'? output = "BME680 warning code : " + String(iaqSensor.bme680Status); ^~~~~~~~~~~~ bme68xStatus Multiple libraries were found for "SPI.h" Used: /home/builder/.arduino15/packages/arduino/hardware/samd/1.8.13/libraries/SPI Not used: /home/builder/opt/libraries/eventethernet_1_0_0 Multiple libraries were found for "ECCX08.h" Used: /home/builder/opt/libraries/arduinoeccx08_1_3_8 Not used: /home/builder/opt/libraries/rak5814_atecc608a_1_0_0 Multiple libraries were found for "Wire.h" Used: /home/builder/.arduino15/packages/arduino/hardware/samd/1.8.13/libraries/Wire Not used: /home/builder/opt/libraries/flexwire_1_2_1 Multiple libraries were found for "Adafruit_ST7735.h" Used: /home/builder/opt/libraries/adafruit_st7735_and_st7789_library_1_10_4 Not used: /home/builder/opt/libraries/vega_st7735_and_st7789_1_0_0 Multiple libraries were found for "Arduino_PMIC.h" Used: /home/builder/opt/libraries/arduino_bq24195_0_9_2 Not used: /home/builder/opt/libraries/arduino_pf1550_0_3_1 Multiple libraries were found for "Adafruit_GFX.h" Used: /home/builder/opt/libraries/adafruit_gfx_library_1_11_9 Not used: /home/builder/opt/libraries/hanuman_1_2_1 Not used: /home/builder/opt/libraries/dfrobot_rgbmatrix_1_0_1 Multiple libraries were found for "WiFiNINA.h" Used: /home/builder/opt/libraries/wifinina_1_8_14 Not used: /home/builder/opt/libraries/vega_wifinina_1_0_1 Not used: /home/builder/opt/libraries/betterwifinina_1_3_0 Multiple libraries were found for "Adafruit_I2CDevice.h" Used: /home/builder/opt/libraries/adafruit_busio_1_16_1 Not used: /home/builder/opt/libraries/vegaiot_busio_1_0_0 Error during build: exit status 1
Warum kommt das wenn ich ein Template importieren will ?
Weil deine Zeile 42 falsch ist.
Auch richtig, aber ich tippe eher darauf, weil der TO die Forumsregeln nicht gelesen hat.
Was meine Mitstreiter Dir so durch die Blume mit Hammermethoden sagen wollen, ist, daß ohne genauere Infos wir Dir keine Antworten geben können.
Gib uns den Sketch und die Quelle der Bibliothek/ Bauanleitung.
Hat C/C++ Templates?
Grüße Uwe
Verstehe das gut, du hast irgend was, von irgend wo kopiert, in die IDE eingefügt und das Ding funktioniert nicht?
Dan musst schon das zeigen, wir alle mussten unsere Glaskugel zu Inspektion gegeben.
C++, ja!
Aber sicher Doch.
