Import tensorflow model on arduino
Hi, I trained a model on Tensorflow and I saved the model in a file with this extension: .pb
Does anyone know how I can convert this file and load it on a Arduino board?
see if this link helps.
https://www.arduino.cc/reference/en/libraries/arduino_tensorflowlite/
You seem to have a picture of microcontrollers that microcontrollers are mini-computers running an operating system. It seems that you expect that you upload some kind of "emulator" or if you convert the file-format from *.pb to some other fileformat that things will work.
surely not. On a microcontroller is running absolutely exclusively only one software: The firmware you have uploaded into the tiny and very small flash-memory of the microcontroller.
An Arduino has
0,000000032 GB of flash-memory (32 kB)
0,000000002 GB of RAM-memory ( 2 kB)
So if your *.PB-file has some hundred kB you are forced to use a Raspberry Pi as the minimum to use that *.PB-file that you have created.
best regards Stefan
A typical Arduino cannot do this.
A K210 can probably do it.
