IMPORTANT - robotarm with VB and arduino
im having a problem. for my final work for school i’m trying to controle a robotarm with my computer.
i code in VB on the pc so i used it for my work.
now i’m trying to put a loop so the robot wil make some moves automaticly until i say to stop it.
my problem is ones i put it in the loop i cant make it stop anymore.
do any of you guys and girls have a idea to make it stop?
i am using the ladyada motorshield.
ps sorry for my bad englisch i’m dutch
code vb: main form
Imports System.IO
Imports System.IO.Ports
Imports System.Threading
Public Class Form1
    Dim compoort As String
    Shared _continue As Boolean
    Shared _serialPort As SerialPort
    Sub GetSerialPortNames()
        For Each sp As String In My.Computer.Ports.SerialPortNames
            ComboBox1.Items.Add(sp)
        Next
        ComboBox1.SelectedIndex = 0
        compoort = ComboBox1.SelectedItem
    End Sub
    Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
        SerialPort1.Close()
        SerialPort1.PortName = compoort 'change com port to match your Arduino port
        SerialPort1.BaudRate = 9600
        SerialPort1.DataBits = 8
        SerialPort1.Parity = Parity.None
        SerialPort1.StopBits = StopBits.One
        SerialPort1.Handshake = Handshake.None
        SerialPort1.Encoding = System.Text.Encoding.Default 'very important!
    End Sub
    Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.MouseHover
        Try
            SerialPort1.Open()
        Catch ex As Exception
            MsgBox(ex.ToString)
        End Try
        SerialPort1.Write("1")
        SerialPort1.Close()
    End Sub
    Private Sub Button1_Click_1(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.MouseLeave, Button4.MouseLeave, Button2.MouseLeave, Button3.MouseLeave, Btntest.MouseLeave, Button5.MouseLeave, Button6.MouseLeave, Button7.MouseLeave
        Try
            SerialPort1.Open()
            MsgBox(ex.ToString)
        End Try
        SerialPort1.Write("5")
        SerialPort1.Close()
    End Sub
    Private Sub Button2_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button2.MouseHover
        Try
            SerialPort1.Open()
            MsgBox(ex.ToString)
        End Try
        SerialPort1.Write("3")
        SerialPort1.Close()
    End Sub
    Private Sub Button4_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button4.MouseHover
        Try
            SerialPort1.Open()
            MsgBox(ex.ToString)
        End Try
        SerialPort1.Write("2")
        SerialPort1.Close()
    End Sub
    Private Sub Button3_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button3.MouseHover
        Try
            SerialPort1.Open()
            MsgBox(ex.ToString)
        End Try
        SerialPort1.Write("4")
        SerialPort1.Close()
    End Sub
    Private Sub Btntest_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Btntest.MouseHover
        Try
            SerialPort1.Open()
            MsgBox(ex.ToString)
        End Try
        SerialPort1.Write("7")
        SerialPort1.Close()
    End Sub
    Private Sub Button5_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button5.MouseHover
        Try
            SerialPort1.Open()
            MsgBox(ex.ToString)
        End Try
        SerialPort1.Write("6")
        SerialPort1.Close()
    End Sub
    Private Sub Button6_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button6.MouseHover
        Try
            SerialPort1.Open()
            MsgBox(ex.ToString)
        End Try
        SerialPort1.Write("8")
        SerialPort1.Close()
    End Sub
    Private Sub Button7_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button7.MouseHover
        Try
            SerialPort1.Open()
            MsgBox(ex.ToString)
        End Try
        SerialPort1.Write("9")
        SerialPort1.Close()
    End Sub
    Private Sub ComboBox1_SelectedIndexChanged(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles ComboBox1.SelectedIndexChanged
        SerialPort1.PortName = ComboBox1.SelectedItem
    End Sub
    Private Sub Button8_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button8.Click
        Dim msg1 As String
        msg1 = MsgBox("de positie waarin de robot arm zich nu bevind is de startpositie. ben u zeker dat u het automatisch programma wilt starten", vbYesNo, "WARNING")
        If msg1 = vbYes Then
            Form2.Show()
            Timer1.Enabled = True
        ElseIf MsgBoxResult.No Then
            MsgBox("stel start positie in en probeer opnieuw")
        End If
    End Sub
    Public Sub stopauto()
        Timer2.Enabled = True
        Form2.Close()
        MsgBox("autorun gestopt")
    End Sub
    Public Sub Timer1_Tick(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Timer1.Tick
        Try
            SerialPort1.Open()
            MsgBox(ex.ToString)
        End Try
        SerialPort1.Write("0")
        SerialPort1.Close()
    End Sub
    Private Sub Timer2_Tick(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Timer2.Tick
        Try
            SerialPort1.Open()
            MsgBox(ex.ToString)
        End Try
        SerialPort1.Close()
    End Sub
End Class
code 2nd form:
Public Class Form2
    Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
        Form1.Timer1.Enabled = False
        Form1.stopauto()
    End Sub
End Class
aruino code:
#include <AFMotor.h>
  AF_DCMotor MGrab(1, MOTOR12_1KHZ);
  AF_DCMotor MOperSwing(2, MOTOR12_1KHZ);
  AF_DCMotor MUnderSwing(3, MOTOR12_1KHZ);
  AF_DCMotor MBase(4, MOTOR12_1KHZ);
  Serial.println("Motor test!");
  MGrab.setSpeed(200);
  MOperSwing.setSpeed(200);
  MUnderSwing.setSpeed(200);
  MBase.setSpeed(200);
void loop(){
 while (Serial.available() == 0);
 int val = Serial.read() - '0';
if (val == 1)
  MUnderSwing.run(FORWARD);
 else if (val == 5)
 MUnderSwing.run(RELEASE);
 MBase.run(RELEASE);
 MGrab.run(RELEASE);
 MOperSwing.run(RELEASE);
 else if (val == 3)
  MBase.run(FORWARD);
 else if (val == 7)
  MGrab.run(BACKWARD);
  else if (val == 4)
  MBase.run(BACKWARD);
 else if (val == 8)
 MOperSwing.run(FORWARD);
  else if (val == 2)
 MUnderSwing.run(BACKWARD);
 else if (val == 6)
 MGrab.run(FORWARD);
 else if (val == 9)
 MOperSwing.run(BACKWARD);
 else if (val == 0)
  MUnderSwing.run(BACKWARD);      // turn it on going forward
  delay(800);
  delay(800);
  MGrab.run(BACKWARD);      // stopped
  delay(300);
  MGrab.run(RELEASE);      // stopped
  delay(800);
  MUnderSwing.run(FORWARD);      // turn it on going forward
  delay(800);
  delay(800);
  MBase.run(FORWARD);
  MBase.run(RELEASE);
  delay(800);
  delay(800);
  delay(800);
  MGrab.run(FORWARD);      // stopped
  delay(300);
  MGrab.run(RELEASE);
  delay(800);
  delay(800);
  delay(800);
  MBase.run(RELEASE);
delay(800);
  Serial.flush();
