IMPORTANT!!
We have a big (important) question:
Maybe you can help;)
We have the error:
sketch_dec02a:41: error: expected constructor, destructor, or type conversion before '.' token
Here is our program:
#include <Shieldbot.h>
#include <SD.h>
#include <SPI.h>
#include "TFTv2.h"
File bmpDatei;
File bmpFile;
unsigned char saved_spimode;
int bmpWidth, bmpHeight;
uint8_t bmpDepth, bmpImageoffset;
int SDPin=4;
#define chipSelect 4
Sd2Card card;
SdVolume volume;
SdFile root;
Shieldbot shieldbot = Shieldbot();
int S1,S2,S3,S4,S5;
void setup(){
 pinMode(11,INPUT);
 pinMode(12,INPUT);
 pinMode(13,INPUT);
 TFT_CS_HIGH;
 pinMode(SDPin,OUTPUT);
 digitalWrite(SDPin,HIGH);
 SPI.begin();
 Tft.TFTinit();
 DDRB |= 0x04;
 card.init(SPI_FULL_SPEED,SDPin);//SPI_QUARTER_SPEED   SPI_HALF_SPEED, SPI_FULL_SPEED,
 if(!SD.begin(SDPin))//SPI_QUARTER_SPEED,
   Serial.println("failed!");
   while(1);
[color=red] Serial.println("SD OK!");
  [/color]
 Tft.setCol(0,239);
 Tft.setPage(0,319);
 Tft.sendCMD(0x2c);//start to write to display ram
 TFT_BL_ON;
void loop(){
 S1 = shieldbot.readS1();
 S2 = shieldbot.readS2();
 S3 = shieldbot.readS3();
 S4 = shieldbot.readS4();
 S5 = shieldbot.readS5();
 Serial.print("S5: ");
 Serial.print(S5);
 Serial.print(" S4: ");
 Serial.print(S4);
 Serial.print(" S3: ");
 Serial.print(S3);
 Serial.print(" S2: ");
 Serial.print(S2);
 Serial.print(" S1: ");
 Serial.print(S1);
  if(S1 == HIGH && S5 == HIGH){
   shieldbot.forward();
Serial.println("Forward");
 }else if(S1 == LOW && S5 == LOW){
   shieldbot.stop();
Serial.println("Stop");
   delay(100);
 }else if((S1 == LOW) || (S2 == LOW)){
   shieldbot.drive(127,-128);
Serial.println("Right");
   delay(100);
 }else if((S5 == LOW) || (S4 == LOW)){
   shieldbot.drive(-128,127);
Serial.println("Left");
   delay(100);
char bmpfiles[][18]={
   "bmp1.bmp","bmp2.bmp","bmp3.bmp"
 for(unsigned char i=0;i<3;i++) {
   bmpFile = SD.open(bmpfiles[i]);
    if (! bmpFile){
      Serial.println("didnt find image");
      while (1);
  Tft.setCol(0,239);
  Tft.setPage(0,319);
  bmpDatei = SD.open("bmp1.bmp");
  if (!bmpReadHeader(bmpDatei)){
    return;
    if (! bmpReadHeader(bmpFile)) {
      Serial.println("bad bmp");
      return;
    Serial.print("image size ");
    Serial.print(bmpWidth, DEC);
    Serial.print(", ");
    Serial.println(bmpHeight, DEC);
    bmpdraw(bmpFile, 0, 0);
    bmpFile.close();
  bmpdraw(bmpDatei, 0, 0);
  bmpDatei.close();
  delay(5000);
  Tft.setCol(0,239);
  Tft.setPage(0,319);
  bmpDatei = SD.open("bmp3.bmp");
    return;
  bmpDatei.close();
  delay(5000);
// This procedure reads a bitmap and draws it to the screen
// its sped up by reading many pixels worth of data at a time
// instead of just one pixel at a time. increading the buffer takes
// more RAM but makes the drawing a little faster. 20 pixels' worth
// is probably a good place
#define BUFFPIXEL 20
void bmpdraw(File f, int x, int y){
  bmpDatei.seek(bmpImageoffset);
  uint32_t time = millis();
  uint16_t p;
  uint8_t g, b;
  int i, j;
  uint8_t sdbuffer[3 * BUFFPIXEL];  // 3 * pixels to buffer
  uint8_t buffidx = 3*BUFFPIXEL;
  for (i=0; i< bmpHeight; i++){
    for (j=0; j<bmpWidth; j++){
      // read more pixels
      if (buffidx >= 3*BUFFPIXEL){
        bmpDatei.read(sdbuffer, 3*BUFFPIXEL);
        buffidx = 0;
      b = sdbuffer[buffidx++];     // blue
      g = sdbuffer[buffidx++];     // green
      p = sdbuffer[buffidx++];     // red
      p >>= 3;
      p <<= 6;
      g >>= 2;
      p |= g;
      p <<= 5;
      b >>= 3;
      p |= b;
      // write out the 16 bits of color
      Tft.sendData(p);
  Serial.print(millis() - time, DEC);
  Serial.println(" ms");
boolean bmpReadHeader(File f) {
  // read header
  uint32_t tmp;
  if (read16(f) != 0x4D42) {
    // magic bytes missing
    return false;
  // read file size
  tmp = read32(f);
  Serial.print("size 0x");
  Serial.println(tmp, HEX);
  // read and ignore creator bytes
  read32(f);
  bmpImageoffset = read32(f);
  Serial.print("offset ");
  Serial.println(bmpImageoffset, DEC);
  // read DIB header
  tmp = read32(f);
  Serial.print("header size ");
  Serial.println(tmp, DEC);
  bmpWidth = read32(f);
  bmpHeight = read32(f);
  if (read16(f) != 1)
    return false;
  bmpDepth = read16(f);
  Serial.print("bitdepth ");
  Serial.println(bmpDepth, DEC);
  if (read32(f) != 0) {
    // compression not supported!
    return false;
  Serial.print("compression ");
  return true;
// These read data from the SD card file and convert them to big endian
// (the data is stored in little endian format!)
// LITTLE ENDIAN!
uint16_t read16(File f) {
  uint16_t d;
  uint8_t b;
  b = f.read();
  d = f.read();
  d <<= 8;
  d |= b;
  return d;
// LITTLE ENDIAN!
uint32_t read32(File f) {
  uint32_t d;
  uint16_t b;
  b = read16(f);
  d = read16(f);
  d <<= 16;
  d |= b;
  return d;
This program is for a linefollowing shieldbot and a display with pictures.
PLEEEEEEEEEEEEEEASE help us!!
It's a school-project.
We're one unit! :smiley: :wink: [/i]
Moderator: added [code]...[/code] tags to show code properly.
Code tags?
Our question is so IMPORTANT that we couldn't be bothered to read the simple posting guidelines, and we thought we'd chuck in a couple of "Report to moderator"s too?
Braces need to match.
Thread locked.
And that question is?
AWOL:
Report to moderator?
Doesn't work. I don't get any notifications.
So don't bother doing that.
We're one unit!
So am I.
