Importar CSS para Arduino Ethernet
Olá pessoal, estou com problemas para importar uma folha de estilos (CSS) no arduino ethernet
O código do arduino correspondente é esse:
          client.println("Content-Type: text/html");
          client.println();
          client.println("<html>");
          client.println("<head>");
          client.println("<title>Automa&ccedil;&atilde;o Residencial</title>");
          client.println("<meta http-equiv='Content-Type' content='text/html; charset=ISO-8859-1'>");
          client.println("<link  rel='idsheet' type='text/css' href='style.css' />");
          client.println("</head>");
          client.println("<body>");
          client.println("<div id='cabecalho'>");
          client.println("<h1 class='h1'>Automa&ccedil;&atilde;o Residencial</h1>");
          client.println("</div>");
          client.println("<div id='areaconteudo'>");
          client.println("<div id='area'>");
          client.println("<div id='titulo'>");
          client.println("<h2 class='h2'>Alarme</h2>");
          client.print("<h3 class='h3'>Status: ");
          // separa as linhas
          if(statusAlarme){
            client.println("AlarmeOn</h3>");
          else{
            client.println("AlarmeOff</h3>");
          client.println("<div id='space'></div>");
          client.println("<h2 class='h2'>Filtro</h2>");
          if(statusFiltro){
            client.print("FiltroOn</h3>");
          else{
            client.print("FiltroOff</h3>");
          client.println("<div id=''>");
          client.println("<h2 class='h2'>Temperatura</h2>");
          client.print("<h3>");
          client.print(temperatura);
          client.print(" graus Celsius</h3>");
          client.println("<h2 class='h2'>Luzes</h2>");
          client.println("<h3 class='h3'>Cozinha</h3>");
          client.print("<h4 class='h4'>Luz 1: ");
          if(SL1C){
            client.print("LuzOn</h4>");
          else{
            client.print("LuzOff</h4>");
          client.println("<h4 class='h4'>Luz 2: ");
          if(SL1C){
          else{
          client.println("<h4 class='h4'>Luz 3: ");
          if(SL1C){
          else{
          client.println("<h3 class='h3'>Corredor</h3>");
          client.print("<h4 class='h4'>Status: ");
          if(SL1C){
          else{
          client.println("<h3 class='h3'>Sala de Jantar</h3>");
          if(SL1C){
          else{
          client.println("<h3 class='h3'>Sala de TV</h3>");
          if(SL1C){
          else{
          client.println("<h3 class='h3'>Sala de Estar</h3>");
          if(SL1C){
          else{
          client.println("<h3 class='h3'>Escada</h3>");
          if(SL1C){
          else{
          client.println("<h2 class='h2'>Sensor de Presen&ccedil;a</h2>");
          if(valorSensorPIR == 1){
            client.print("MovOn</h4>");
          else{
            client.print("MovOff</h4>");
          if (valorSensorPIR == 1 && statusAlarme == 1){
            client.print("MovOn1</h4>");
          //limpa string para a próxima leitura
          readString="";
          // parar cliente
          client.stop();
Reparem que na 8ª linha, tem um link para minha folha de estilos
root {
    display: block;
body {
	margin-left: 0px;
	margin-top: 0px;
	margin-right: 0px;
	margin-bottom: 0px;
	background-color: #999;
#cabecalho {
	width: 100%; height: 150px;
#areaconteudo {
	width: 80%;	height: auto; margin-left: 10%;
#area { width: 100%; height: auto;
#titulo {
	width: 100%; height: 50px;
#space {
	width: 100%; height: 30px;
.h1 {
	font-family: Segoe, 'Segoe UI', 'DejaVu Sans', 'Trebuchet MS', Verdana, sans-serif;
	padding-top: 40px;
	font-size: 32px;
	color: #333;
	margin-top: 0;
	text-align: center;
.h2 {
	font-family: Segoe, 'Segoe UI', 'DejaVu Sans', 'Trebuchet MS', Verdana, sans-serif;	padding-top: 5px; font-size: 28px; color: #333; margin-top: 0;	text-align: center;
.h3 {
	font-family: Segoe, 'Segoe UI', 'DejaVu Sans', 'Trebuchet MS', Verdana, sans-serif;	padding-top: 5px; font-size: 26px; color: #F4F4F4;	margin-top: 0; margin-left: 35%;
.h4 {
	font-family: Segoe, 'Segoe UI', 'DejaVu Sans', 'Trebuchet MS', Verdana, sans-serif; padding-top: 5px; font-size: 26px; color: #F4F4F4; margin-top: 0;	text-align: center;
Mas quando abro no navegador, esta folha não é carregada, tendo ela, na mesma pasta do arquivo .INO
Alguém sabe o motivo?
Obrigado!
Correção da 8ª linha:
client.println("<link  rel='stylesheet' type='text/css' href='style.css' />");
Porém o erro persisti.
Não vi o código, mas vou assumir que o arduino está a fazer de servidor...
Explica-me como é que o cliente que está a aceder à página guardada no arduino acede ao ficheiro que está guardado num directório no teu computador? Imagina que i cliente que acede ao teu arduino é o meu computador. Vais ver que a resposta é óbvia. :)
Diz então que preciso guardar este CSS num SD Card do shield? Poderia hospedar ela em algum lugar e por o link dela no arduino?
Pois realmente, depois que envio o código, ele independe do computador, realmente óbvio. Mas as possibilidades acima são válidas? Tenho preferência em hospedar em algum lugar o arquivo CSS, evitando a compra de um sd só para isso.. O problema é: onde vou hospedar?
Eu não sou um guru em css… Esse ficheiro tem de estar num sítio que possa ser servido por algum computador. Se quiseres fazer isso com o arduino, tens de adaptar o código para fazê-lo… Ou podes pesquisar se o css pode estar guardado noutro servidor.
Porque queres fazer isto com o Arduino? Precisas mesmo de css?.??
Apenas para deixar a página mais agradável.
Tentei colocar os estilos no próprio arduino, mas não funcionou.
Estou pensando em hospedar em algo como este caso:
http://www.robocore.net/upload/projetos/RemoteAutomationV1.0.css
ficaria assim:
client.println("<link rel='stylesheet' type='text/css' href='http://www.robocore.net/upload/projetos/RemoteAutomationV1.0.css' />");
Creio que funcionaria, mas como disse, não acho um site para hospedar…
ao invés do link da robocore, colocaria o meu.
conseguiu resolver?
Nesse site, eles usam CSS em um projeto. Dê uma olhada:
http://www.automacaolivre.com.br/2015/02/automation-shield-webserver-com.html
O CSS deles está hospedado aqui:
https://maxcdn.bootstrapcdn.com/bootstrap/3.3.1/css/bootstrap.min.css
Para usar com arduino vc deve hospedar em algum site ou utilizar num cartão sd, onde o mesmo faz parte do conjunto do arduino.
Tenta usar css-inline
Voce abre umatag no html e coloca o seu css la, a maioria dos navegadores suportam isso… e funciona com arduino estou trabalhando em um projeto e achei essa solução ideal
