Importing Arduino sketches to Eclipse (C/C++)
Hello I have this sketch:
int incomingByte = 0;   // for incoming serial data
  pinMode(13,OUTPUT);
        Serial.begin(9600);     // opens serial port, sets data rate to 9600 bps
        // send data only when you receive data:
        if (Serial.available() > 0) {
                // read the incoming byte:
                incomingByte = Serial.read();
                // say what you got:
                Serial.print("I received: ");
                Serial.println(incomingByte, DEC);
                if(incomingByte == 49){
                  digitalWrite(13,HIGH);
                }else if(incomingByte == 48){
                 digitalWrite(13,LOW);
that I would like to import into my Eclipse C/C++ project. Should I use external libraries such as CSerial or is there any way I can move it in? I have read the http://todbot.com/blog/2013/04/29/arduino-serial-updated/ but I still don't get what I am suppose to do to get the same results. Thanks.
Does this work if you link it with the Arduino core and libraries?
If you don’t want to use the Arduino libraries you will need to find replacements for pinMode(), Serial, and digitalWrite().
#include <Arduino.h>
  pinMode(13,OUTPUT);
Then is it okay if I do something like this? 1) Run the code first from the Arduino IDE to establish the connection 2) Run the "digitalWrite" statement from my C/C++ code within another running app on my Desktop?
Is that okay? Thanks~
maxwelltsai1987: 2) Run the "digitalWrite" statement from my C/C++ code within another running app on my Desktop?
I don't understand what you mean by this.
To compile an Arduino sketch outside of the Arduino IDE you need to compile and link the Arduino core libraries, like this:
Arduino/hardware/tools/avr/bin/avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega2560 -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=101 -IArduino/hardware/arduino/cores/arduino -IArduino/hardware/arduino/variants/mega build/sketch_may18a.cpp -o build/sketch_may18a.cpp.o
Arduino/hardware/tools/avr/bin/avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega2560 -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=101 -IArduino/hardware/arduino/cores/arduino -IArduino/hardware/arduino/variants/mega Arduino/hardware/arduino/cores/arduino/WInterrupts.c -o build/WInterrupts.c.o
Arduino/hardware/tools/avr/bin/avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega2560 -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=101 -IArduino/hardware/arduino/cores/arduino -IArduino/hardware/arduino/variants/mega Arduino/hardware/arduino/cores/arduino/wiring.c -o build/wiring.c.o
Arduino/hardware/tools/avr/bin/avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega2560 -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=101 -IArduino/hardware/arduino/cores/arduino -IArduino/hardware/arduino/variants/mega Arduino/hardware/arduino/cores/arduino/wiring_analog.c -o build/wiring_analog.c.o
Arduino/hardware/tools/avr/bin/avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega2560 -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=101 -IArduino/hardware/arduino/cores/arduino -IArduino/hardware/arduino/variants/mega Arduino/hardware/arduino/cores/arduino/wiring_digital.c -o build/wiring_digital.c.o
Arduino/hardware/tools/avr/bin/avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega2560 -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=101 -IArduino/hardware/arduino/cores/arduino -IArduino/hardware/arduino/variants/mega Arduino/hardware/arduino/cores/arduino/wiring_pulse.c -o build/wiring_pulse.c.o
Arduino/hardware/tools/avr/bin/avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega2560 -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=101 -IArduino/hardware/arduino/cores/arduino -IArduino/hardware/arduino/variants/mega Arduino/hardware/arduino/cores/arduino/wiring_shift.c -o build/wiring_shift.c.o
Arduino/hardware/tools/avr/bin/avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega2560 -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=101 -IArduino/hardware/arduino/cores/arduino -IArduino/hardware/arduino/variants/mega Arduino/hardware/arduino/cores/arduino/CDC.cpp -o build/CDC.cpp.o
Arduino/hardware/tools/avr/bin/avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega2560 -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=101 -IArduino/hardware/arduino/cores/arduino -IArduino/hardware/arduino/variants/mega Arduino/hardware/arduino/cores/arduino/HardwareSerial.cpp -o build/HardwareSerial.cpp.o
Arduino/hardware/tools/avr/bin/avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega2560 -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=101 -IArduino/hardware/arduino/cores/arduino -IArduino/hardware/arduino/variants/mega Arduino/hardware/arduino/cores/arduino/HID.cpp -o build/HID.cpp.o
Arduino/hardware/tools/avr/bin/avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega2560 -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=101 -IArduino/hardware/arduino/cores/arduino -IArduino/hardware/arduino/variants/mega Arduino/hardware/arduino/cores/arduino/IPAddress.cpp -o build/IPAddress.cpp.o
Arduino/hardware/tools/avr/bin/avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega2560 -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=101 -IArduino/hardware/arduino/cores/arduino -IArduino/hardware/arduino/variants/mega Arduino/hardware/arduino/cores/arduino/main.cpp -o build/main.cpp.o
Arduino/hardware/tools/avr/bin/avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega2560 -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=101 -IArduino/hardware/arduino/cores/arduino -IArduino/hardware/arduino/variants/mega Arduino/hardware/arduino/cores/arduino/new.cpp -o build/new.cpp.o
Arduino/hardware/tools/avr/bin/avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega2560 -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=101 -IArduino/hardware/arduino/cores/arduino -IArduino/hardware/arduino/variants/mega Arduino/hardware/arduino/cores/arduino/Print.cpp -o build/Print.cpp.o
Arduino/hardware/tools/avr/bin/avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega2560 -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=101 -IArduino/hardware/arduino/cores/arduino -IArduino/hardware/arduino/variants/mega Arduino/hardware/arduino/cores/arduino/Stream.cpp -o build/Stream.cpp.o
Arduino/hardware/tools/avr/bin/avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega2560 -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=101 -IArduino/hardware/arduino/cores/arduino -IArduino/hardware/arduino/variants/mega Arduino/hardware/arduino/cores/arduino/Tone.cpp -o build/Tone.cpp.o
Arduino/hardware/tools/avr/bin/avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega2560 -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=101 -IArduino/hardware/arduino/cores/arduino -IArduino/hardware/arduino/variants/mega Arduino/hardware/arduino/cores/arduino/USBCore.cpp -o build/USBCore.cpp.o
Arduino/hardware/tools/avr/bin/avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega2560 -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=101 -IArduino/hardware/arduino/cores/arduino -IArduino/hardware/arduino/variants/mega Arduino/hardware/arduino/cores/arduino/WMath.cpp -o build/WMath.cpp.o
Arduino/hardware/tools/avr/bin/avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega2560 -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=101 -IArduino/hardware/arduino/cores/arduino -IArduino/hardware/arduino/variants/mega Arduino/hardware/arduino/cores/arduino/WString.cpp -o build/WString.cpp.o
Arduino/hardware/tools/avr/bin/avr-ar rcs build/core.a build/WInterrupts.c.o
Arduino/hardware/tools/avr/bin/avr-ar rcs build/core.a build/wiring.c.o
Arduino/hardware/tools/avr/bin/avr-ar rcs build/core.a build/wiring_analog.c.o
Arduino/hardware/tools/avr/bin/avr-ar rcs build/core.a build/wiring_digital.c.o
Arduino/hardware/tools/avr/bin/avr-ar rcs build/core.a build/wiring_pulse.c.o
Arduino/hardware/tools/avr/bin/avr-ar rcs build/core.a build/wiring_shift.c.o
Arduino/hardware/tools/avr/bin/avr-ar rcs build/core.a build/CDC.cpp.o
Arduino/hardware/tools/avr/bin/avr-ar rcs build/core.a build/HardwareSerial.cpp.o
Arduino/hardware/tools/avr/bin/avr-ar rcs build/core.a build/HID.cpp.o
Arduino/hardware/tools/avr/bin/avr-ar rcs build/core.a build/IPAddress.cpp.o
Arduino/hardware/tools/avr/bin/avr-ar rcs build/core.a build/main.cpp.o
Arduino/hardware/tools/avr/bin/avr-ar rcs build/core.a build/new.cpp.o
Arduino/hardware/tools/avr/bin/avr-ar rcs build/core.a build/Print.cpp.o
Arduino/hardware/tools/avr/bin/avr-ar rcs build/core.a build/Stream.cpp.o
Arduino/hardware/tools/avr/bin/avr-ar rcs build/core.a build/Tone.cpp.o
Arduino/hardware/tools/avr/bin/avr-ar rcs build/core.a build/USBCore.cpp.o
Arduino/hardware/tools/avr/bin/avr-ar rcs build/core.a build/WMath.cpp.o
Arduino/hardware/tools/avr/bin/avr-ar rcs build/core.a build/WString.cpp.o
Arduino/hardware/tools/avr/bin/avr-gcc -Os -Wl,--gc-sections,--relax -mmcu=atmega2560 -o build/sketch_may18a.cpp.elf build/sketch_may18a.cpp.o build/core.a -Lbuild/ -lm
Arduino/hardware/tools/avr/bin/avr-objcopy -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 build/sketch_may18a.cpp.elf build/sketch_may18a.cpp.eep
Arduino/hardware/tools/avr/bin/avr-objcopy -O ihex -R .eeprom build/sketch_may18a.cpp.elf build/sketch_may18a.cpp.hex
use Eclipse plugin AVR-eclipse?
http://playground.arduino.cc/Code/Eclipse
http://www.baeyens.it/eclipse/
Or in fact much better yet, use the Arduino Eclipse plugin. Newest version is 2.1.0.4. Installation instructions are here under "Teensy, Arduino, Etc." :
trippylighting.com
