importing boost library
I am trying to import the boost library. I go to sketch->include library-> boost. It inserts two lines at the top:
#include <predef.h>
#include <regex.h>
I then run my code.
The error I get is this:
In file included from C:\Users\user\Documents\Arduino\ultrasonic\ultrasonic.ino:1:0:
C:\Users\user\Documents\Arduino\libraries\boost/predef.h:13:35: fatal error: boost/predef/language.h: No such file or directory
 #include <boost/predef/language.h>
compilation terminated.
Using library boost in folder: C:\Users\user\Documents\Arduino\libraries\boost (legacy)
It would help to know where to find the 'boost' library.
Because the library is described as "(legacy)" I think it is not in the current format and may not be entirely compatible with the latest version of Arduino. Do you have a file named C:\Users\user\Documents\Arduino\libraries\boost\predef\language.h?
I believe this is the library I am looking for: http://www.boost.org/
And yes, there is a language.h file at that location.
Java use import. C and C++ do not. Make it look somewhat like you know what you are talking about by using the correct terminology.
The problem is that library was apparently written for a different system of includes. Instead of:
The Arduino IDE doesn’t work like that, it should be:
#include <predef/language.h>
actually most correct would be:
#include "predef/language.h"
but the angle brackets will work.
You can fix this by doing a search and replace of:
#include <boost/
to:
#include <
on all files in the library (there are over 51000 occurrences!). Then do a search and replace of
#   include <boost/
to:
#   include <
After that, compiling for Uno I encountered another compile error:
E:\Stuff\misc\electronics\arduino\libraries\boost/predef/detail/_cassert.h:12:19: fatal error: cassert: No such file or directory
 #include <cassert>
but maybe this would work for a different architecture.
I suspect you might be better off telling us what you’re actually trying to accomplish.
Sure! I am trying to retrieve JSON data, then parse through it.
Why do you want to use the Boost library? Which board are you using?
I was following a tutorial, and saw that they included boost at the top, which led me to this. I have no preference. I just want to use the easiest way to get/parse json data. I am using the arduino uno.
I have no experience with using JSON with Arduino but I do know there's a library named ArduinoJson:
You can install it by:
  • Sketch > Include Library > Manage Libraries
  • Wait for download to complete
  • Type "arduinojson" in the "Filter your search..." box
  • Click on the "ArduinoJson" entry
  • Click "Install"
  • Wait for installation to complete
  • Click "Close"
You will find some usage examples at File > Examples > ArduinoJson.
