Hi! i am new to programming and would appreciate it if anyone could help.
This is the issue: I want to load different images to my 7 inch TFT LCD screen (sdd1963 based) from an SD Card and I'm not able to do it. I'm using the cold tears CTE Shield for Mega. This is the code I'm using:
#include <SdFat.h>
#include <UTFT.h>
#include <SdFatUtil.h>
#include <Importer.h>
#include "SPI.h"
#define BVS_13 10
#define BVS_15 12
#define BVS_19 14
#define BVS_22 18
#define BVS_28 22
#define BVS_34 28
#define BVS_43 38
#define BVS_52 53
#define BVS_74 78
#define BVS_112 122
UTFT myGLCD(CTE70);
const uint8_t chipSelect = 53; // SD CSpin
#define FLASH_CS_PIN 52 //Flash CSpin
#define SPI_RATE 4
#define BUF_SIZE 256
static char name[14];
static char flash_memory_type;
uint8_t buf[BUF_SIZE];
unsigned long Location;
unsigned long address;
char IMAGE_FILENAME[] = "0.CTE";
unsigned int MAX_sector;
// file system
SdFat sd;
// test file
SdFile file;
ArduinoOutStream cout(Serial);
#define error(s) sd.errorHalt_P(PSTR(s))
Serial.begin(38400);
SPI_Flash_init(FLASH_CS_PIN,SPI_RATE);
myGLCD.SPI_Flash_init(FLASH_CS_PIN,SPI_RATE);
myGLCD.InitLCD();
myGLCD.show_color_bar();
myGLCD.clrScr();
myGLCD.clrScr();
myGLCD.Swtich_LCD_TB_Bit(0);
myGLCD.setColor(255, 255, 0);
myGLCD.setBackColor(0, 0, 0);
myGLCD.Set_character_spacing(1);
myGLCD.Put_Text("Image importer via SD card",5,5,BVS_28);
char charBuf[1]; charBuf[0]=169;charBuf[1]=0;
myGLCD.setColor(255, 0, 255);
myGLCD.Put_Text(charBuf,5,40,BVS_28);
myGLCD.Put_Text(" Coldtears electronics",30,40,BVS_28);
myGLCD.setColor(255, 255, 255);
if (!sd.begin(chipSelect, SPI_HALF_SPEED))
myGLCD.Put_Text("SD Access Error",5,80,BVS_19);
sd.initErrorHalt();
else {
myGLCD.Put_Text("SD Access OK",5,80,BVS_19);
delay(1000); if (READ_ID()==0) {myGLCD.Put_Text("Flash memory Error",5,100,BVS_19); while(1){} }
else if (READ_ID()==1) {myGLCD.Put_Text("Flash: 32Mbit, Max Img location 799",2,100,BVS_19); flash_memory_type=1; MAX_sector=1023;}
else if (READ_ID()==2) {myGLCD.Put_Text("Flash: 64Mbit, Max Img location 1823",2,100,BVS_19); flash_memory_type=2; MAX_sector=2047;}
if (!file.open(IMAGE_FILENAME, O_RDWR)) {
myGLCD.Put_Text("file open failed",5,120,BVS_19);
error("open failed");
else{
myGLCD.Put_Text("file open OK",5,120,BVS_19);
char temp_buf[10];
file.read(temp_buf, sizeof(temp_buf));
file.rewind();
unsigned int ass=temp_buf[6]*256+temp_buf[7];
Location=ass; //DO NOT edit this, or else it may overwrite Font data
address=(Location+224)*4096; //DO NOT edit this, or else it may overwrite Font data
unsigned long filesize = file.fileSize();
unsigned long no_of_sectors = filesize/4096;
if (filesize%4096>0) no_of_sectors=no_of_sectors+1;
unsigned long no_of_page = filesize/256;
if (no_of_page%256>0) no_of_page=no_of_page+1;
if (Location+224+no_of_sectors>MAX_sector)
{ myGLCD.Put_Text("Not enough space",5,120,BVS_19); while(1){}}
file.getFilename(name);
myGLCD.Put_Text((String)filesize+"bytes, Filename:",1,120,BVS_19);
myGLCD.Put_Text(name,200,120,BVS_19);
myGLCD.Put_Text("Img location: " + (String)(Location) + "-" + (String)(Location+no_of_sectors-1),120,80,BVS_19);
unsigned char countdown=10;
myGLCD.setColor(255, 100, 100);
myGLCD.Put_Text("unplug power NOW to cancel..",1,140,BVS_22);
myGLCD.Put_Text(String(countdown)+" ",280,140,BVS_22); delay(1000);
while(countdown>0)
if (countdown%2==1) myGLCD.Put_Text("unplug power NOW to cancel..",1,140,BVS_22);
else myGLCD.Put_Text(" ",1,140,BVS_22);
countdown--;
unsigned long temp_add = address;
unsigned long m;
String total_sectors = " / "+ (String)(no_of_sectors-1);
for (m=0; m<no_of_sectors;m++)
WRITE_ENABLE();
if (flash_memory_type==1) WRITE_STATUS_REGISTER(48);
else if (flash_memory_type==2) WRITE_STATUS_REGISTER(44);
delay(30);WRITE_ENABLE();
SECTOR_ERASE(temp_add);
temp_add=temp_add+0x001000;delay(300);
myGLCD.Put_Text("Erasing Sector: ",1,165,BVS_19);
String displaya = String(m) + total_sectors;
myGLCD.Put_Text(displaya,150,165,BVS_19);
temp_add = address;
volatile unsigned int counter=0;
String total_page = " / "+ (String)no_of_page;
for(unsigned long z=0;z<no_of_page;z++)
unsigned int bytes_read=file.read(buf, sizeof(buf));
if (bytes_read!=256)
for(unsigned int z=bytes_read;z<256;z++) buf[z]=0xFF;
WRITE_ENABLE();
PAGE_PROGRAME(temp_add,buf);
temp_add=temp_add+256;delay(20);
counter++;
myGLCD.Put_Text("Writing Page: ",1,185,BVS_19);
myGLCD.Put_Text((String)counter + total_page ,150,185,BVS_19);
myGLCD.Put_Text("Write File OK, Display image soon....",1,205,BVS_22);
WRITE_ENABLE(); WRITE_STATUS_REGISTER(252); delay(100);
countdown=5;
while(countdown>0)
myGLCD.Put_Text(String(countdown)+" ",300,205,BVS_22);
countdown--;
myGLCD.Load_image(0,0,(Location));
delay(2000);
file.close();
Location=Location+no_of_sectors;
while(1){} //disable this for batch files import
//IMAGE_FILENAME[0]=IMAGE_FILENAME[0]++; //myGLCD.clrScr(); //enable this for batch files import
However, i keep on getting an error during compilation as follow:
Arduino: 1.6.5 (Windows 8.1), Board: "Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)"
Image_importer.ino: In function 'void setup()':
Image_importer:65: error: 'class UTFT' has no member named 'SPI_Flash_init'
Image_importer:69: error: 'class UTFT' has no member named 'show_color_bar'
Image_importer.ino: In function 'void loop()':
Image_importer:80: error: 'class UTFT' has no member named 'Set_character_spacing'
Image_importer:81: error: 'class UTFT' has no member named 'Put_Text'
Image_importer:84: error: 'class UTFT' has no member named 'Put_Text'
Image_importer:85: error: 'class UTFT' has no member named 'Put_Text'
Image_importer:91: error: 'class UTFT' has no member named 'Put_Text'
Image_importer:95: error: 'class UTFT' has no member named 'Put_Text'
Image_importer:97: error: 'class UTFT' has no member named 'Put_Text'
Image_importer:98: error: 'class UTFT' has no member named 'Put_Text'
Image_importer:99: error: 'class UTFT' has no member named 'Put_Text'
Image_importer:103: error: 'class UTFT' has no member named 'Put_Text'
Image_importer:107: error: 'class UTFT' has no member named 'Put_Text'
Image_importer:124: error: 'class UTFT' has no member named 'Put_Text'
Image_importer:127: error: 'class UTFT' has no member named 'Put_Text'
Image_importer:128: error: 'class UTFT' has no member named 'Put_Text'
Image_importer:129: error: 'class UTFT' has no member named 'Put_Text'
Image_importer:134: error: 'class UTFT' has no member named 'Put_Text'
Image_importer:135: error: 'class UTFT' has no member named 'Put_Text'
Image_importer:138: error: 'class UTFT' has no member named 'Put_Text'
Image_importer:139: error: 'class UTFT' has no member named 'Put_Text'
Image_importer:140: error: 'class UTFT' has no member named 'Put_Text'
Image_importer:156: error: 'class UTFT' has no member named 'Put_Text'
Image_importer:158: error: 'class UTFT' has no member named 'Put_Text'
Image_importer:175: error: 'class UTFT' has no member named 'Put_Text'
Image_importer:176: error: 'class UTFT' has no member named 'Put_Text'
Image_importer:179: error: 'class UTFT' has no member named 'Put_Text'
Image_importer:185: error: 'class UTFT' has no member named 'Put_Text'
Image_importer:189: error: 'class UTFT' has no member named 'Load_image'
Multiple libraries were found for "UTFT.h"
Used: E:\Arduino\arduino-1.6.5-r2\libraries\UTFT
Not used: E:\Arduino\arduino-1.6.5-r2\libraries\UTFT_MEGA
Not used: E:\Arduino\arduino-1.6.5-r2\libraries\UTouch
Would any1 be kind enough to help as i am running short on time.
Thanks in advance.
