salut,
je n’arrive pas à modifier le volume sur mon shield adafruit (musicmaker) et ne vois pas ce qui cloche…
merci du coup de main.
#include <SPI.h>
#include <Adafruit_VS1053.h>
#include <SD.h>
#define BREAKOUT_RESET 9 // VS1053 reset pin (output)
#define BREAKOUT_CS 10 // VS1053 chip select pin (output)
#define BREAKOUT_DCS 8 // VS1053 Data/command select pin (output)
#define SHIELD_CS 7 // VS1053 chip select pin (output)
#define SHIELD_DCS 6 // VS1053 Data/command select pin (output)
#define CARDCS 4 // Card chip select pin
#define DREQ 3 // VS1053 Data request, ideally an Interrupt pin
Adafruit_VS1053_FilePlayer musicPlayer = Adafruit_VS1053_FilePlayer(SHIELD_CS, SHIELD_DCS, DREQ, CARDCS);
int led = 3, btn1 = 1, btn2 = 2, volume = 1;
int maxTrack = 2;
char* songs[] = {"001.mp3","002.mp3"};
int songNumber = 1;
Serial.println("RadioMobile + Bru'Surf say u Hello asshole :p");
if (! musicPlayer.begin()) { // initialise the music player
Serial.println(F("Couldn't find VS1053, do you have the right pins defined?"));
while (1);
Serial.println(F("VS1053 found- mrd"));
SD.begin(CARDCS); // initialise the SD card
// Set volume for left, right channels. lower numbers == louder volume!
musicPlayer.setVolume(volume,volume);
musicPlayer.sineTest(0x44, 500); // Make a tone to indicate VS1053 is working
musicPlayer.GPIO_pinMode(led, OUTPUT);
musicPlayer.GPIO_pinMode(btn1 , INPUT);
musicPlayer.GPIO_pinMode(btn2, INPUT);
musicPlayer.useInterrupt(VS1053_FILEPLAYER_PIN_INT);
// musicPlayer.startPlayingFile(songs[songNumber]);
if (musicPlayer.GPIO_digitalRead(btn1) == HIGH) {
LED();
prev();
if (musicPlayer.GPIO_digitalRead(btn2) == HIGH) {
LED();
next();
void LED() {
musicPlayer.GPIO_digitalWrite(led, HIGH);
Serial.print("led"); delay(1000);
musicPlayer.GPIO_digitalWrite(led, LOW);
void prev() {
if (songNumber - 1 >= 0)
songNumber = songNumber - 1;
songNumber = maxTrack - 1;
Serial.println(songNumber);
void next() {
if (songNumber + 1 < maxTrack)
songNumber = songNumber + 1;
songNumber = 0;
void UP(){if (volume < 70)
volume = volume + 1;
musicPlayer.setVolume(volume, volume);
delay(50);
void DOWN(){ if (volume > 0)
volume = volume - 1;
delay(50);
