Impossible to communicate with Nina chip
I installed everything required in tutorial (WiFiNINA library, Vidor libraries). I'm able to communicate with the board (MKR VIDOR 4000).
When I run the program VidorTestSketch, I have the followiing messages :
"Vidor bitstream version: 1020109
number of devices 9
1 02000000 MB_DEV_GPIO
1 03000000 MB_DEV_GFX
4 04000000 MB_DEV_I2C
6 05000000 MB_DEV_SPI
9 06000000 MB_DEV_UART
1 08000000 MB_DEV_SDRAM
4 09000000 MB_DEV_NP
11 0A000000 MB_DEV_ENC
0 0B000000 MB_DEV_REG
Pin A0 is HIGH
Pin A0 is LOW"
Which it's seems to be correct.
When I try now to run CheckFirmwareVersion on WiFiNINA examples, I got the following message :
"WiFiNINA firmware check.
Communication with WiFi module failed!"
I don't know how to solve this problem.
Any help ?
Thanks
The following thread (elsewhere on this forum) shows it has a solution to a WIFININA issue:
When I use Arduino's WIFI 101/WIFININA updater, I can get the test connection OK but when I try to install the firmware (only available 1.1.0) the prrogram block at "programming 814080 bytes..."
