Impossible to program mini pro
Hi guys,
I open a thread because I've been trying since two days , searching the net , and I think I've exhausted all possibilities , there must be something that is going ignored me , but I can not see it.
I bought 2 Arduino pro mini and adapter , these are:
http://www.ebay.es/itm/121192432250?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
http://www.ebay.es/itm/300935559844?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
But I can not program it. The mini pro is not responding.
What I 've tried :
  • I connected the adapter and win7 I recognized me , I connected as it should GND -> GND supposedly 5V- > VCC TX- > RX and RX- > TX but nothing.
  • Same but investing TX and RX , nothing.
  • Giving the reset for a second, nothing .
  • Giving to reset until you get the message bytes , nothing.
  • Giving to reset the adapter until a second I see the TX LED , illuminates nothing .
  • Giving to reset until just before the TX LED lights , nothing.
  • I saw that there were problems with win7 with drivers , so I installed an old version , nothing.
  • Leo this thread , New Pro Mini atmega328 5V 16M (clone) - not in sync - solved - Other Hardware Development - Arduino Forum , same components I , 115200 baups change nothing .
  • I try to pins of the side , instead of the end , as it could have bad soldier or something , nothing.
  • I installed a virtual machine with windows XP , nothing.
  • I try different cards in the program , 5v, 3v , all possibilities , nothing.
  • I tried to use the adapter to program an arduino nano, and it worked perfectly . ( this means that the adapter / setup is correct ? )
Always the same error: avrdude stk500_getsync () not in sync resp = 0x00
Now comes the horny , I say , well , let's try using the arduino nano as an adapter to program the mini and the following occurs :
  • I connect everything, 5v -> VCC GND -> GND TX- > RX RX- > TX right ... I hit the reset and nothing, same error.
  • I connect the nano to RST PIn DTR mini and go , now it seems that if it works , do not give me any error, the LEDs blink , the nano is set to blink , the mini as you hear rain. Le LEd to connect a normal 13 pin mini , to see it better , but hey, it flashes every 16 seconds (same as having integrated) nothing to do with what I have allegedly sent .
  • Change the flicker delays in the nano works, the mini remains the same, at your pace.
  • Change the TX and RX and invest , and ... DO NOT GIVE ME ANY ERROR ! ? WTF? the mini course at their own pace , the nano program.
  • Change the program to Nano card , same result.
  • Change in a mini card program , same result.
So at this point I am, I think the adapter works well , since its LED TX if ignited , tries to send , and the nano has worked flawlessly I even doing manual reset as the first .
All indications are that the arduino mini pro is faulty but I do not. First because it turns perfectly and status LED flashes occasionally , and second because I bought two , and they both do exactly the same .
So I would like any suggestions or something you are overlooking. Now the last thing I would try is a tutorial to make an auto -reset the adapter, but this risk http://www.instructables.com/id/Arduino-USB/?ALLSTEPS blow the adapter because welding is very small, I would like to see if I'm doing something wrong before.
Thank you and sorry for my english.
Updated!
I made the auto-reset of http://www.instructables.com/id/Arduino-USB/?ALLSTEPS and it works perfectly, the led of arduino pro mini flash 3 times few milliseconds before attempting to send the code, but nothing changes.
Moreover I tried to install into ubuntu and nothing, everything exactly the same, so you can rule out a driver issue, or USB.
I've also changed the baud rate to 115200 in preferences.txt but nothing.
Now I am in a dead end, any ideas?
Have you tried this.
and
http://www.arduino.cc/en/Guide/ArduinoMiniThis is worked for me
Have you checked when you connected mini port has been detected in manage option from my computer??
Can you share some screen shots of test you are doing along with their error.
