Impossible to use wifiClient
Hi, here my code
#include <SPI.h>
#include <WiFi.h>
#include <WiFiClient.h>
char ssid[] = "NUMERICABLE-9B49";
char pass[] = "*******";    // your network password
int status = WL_IDLE_STATUS;
char servername[]="google.com";  // remote server we will connect to
WiFiClient client;
  Serial.println("Attempting to connect to WPA network...");
  Serial.print("SSID: ");
  Serial.println(ssid);
  status = WiFi.begin(ssid, pass);
  if ( status != WL_CONNECTED) {
    Serial.println("Couldn't get a wifi connection");
    // don't do anything else:
    while(true);
  else {
    Serial.println("Connected to wifi");
    Serial.println("\nStarting connection...");
    // if you get a connection, report back via serial:
    if (client.connect(servername, 80)) {
      Serial.println("connected");
      // Make a HTTP request:
      client.println("GET /search?q=arduino HTTP/1.0");
      client.println();
    else Serial.println("not connected");
And there the output :
SSID: NUMERICABLE-9B49
Connected to wifi
not connected
I can’t get the final “connected” output … I don’t understand why arduino can’t connect to google (i try’d with severals servers)
If anyone know how to fix this !
Thanks.
Have you upgraded the firmware? Check with this code after Serial.begin() in your setup. If upgraded, it should show version 1.1.0.
  // check for the presence of the shield:
  if (WiFi.status() == WL_NO_SHIELD) {
    Serial.println("WiFi shield not present");
    // don't continue:
    while(true);
  // check firmware version
  Serial.print(F("Firmware version: "));
  Serial.println(WiFi.firmwareVersion());
Works after upgrading the wifishield. Thx !
