I am working on this project to control solenoids and datalog. For the solenoid control, I need to be able to pull the data and filter it as quickly as possible. This all needs to be written to an SD card for analysis later. This is for a rocket and thus I cannot watch serial data or determine if the software is working properly until post-flight analysis (after I am happy with the software of course). All sensor data comes from the Adafruit 10DOF sensor and I am using the Sainsmart microSD adapter.
I am new to Arduino programming, however, I have had experience with Java and other higher level languages (a bit rusty though).
I originally implemented the standard SD libraries, however, I was only getting about 15 Hz from this. I then switched over to a similar implementation using SdFat and now it is about 20 Hz. Just using the barebones implementation (just writing the time, no actual data) I only reached 70 Hz. Testing the sdcard using the SDFat "LowLatencyLogger" example, I was able to achieve 500 Hz, but this is without customizing it for my own use. I have absolutely no idea where to start in implementing that method for the 10DOF data and even then I suspect the number of cycles going into retrieving that data will limit that heavily.
Here is what I have so far:
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_LSM303_U.h>
#include <Adafruit_BMP085_U.h>
#include <Adafruit_L3GD20_U.h>
#include <Adafruit_10DOF.h>
#include <SPI.h>
#include <SdFat.h>
#include <SdFatUtil.h>
/*** CONSTANTS ***/
/* Assign a unique ID to the sensors */
Adafruit_10DOF dof = Adafruit_10DOF();
Adafruit_LSM303_Accel_Unified accel = Adafruit_LSM303_Accel_Unified(30301);
Adafruit_LSM303_Mag_Unified mag = Adafruit_LSM303_Mag_Unified(30302);
Adafruit_BMP085_Unified bmp = Adafruit_BMP085_Unified(18001);
const int chipSelect = 4; // digital pin for SD Card writing
/* Update this with the correct SLP for accurate altitude measurements */
float seaLevelPressure = SENSORS_PRESSURE_SEALEVELHPA; // sea level pressure in hPa
const int dataTypes = 7 * 2; // Number of data types to log, update if number of outputs changes, multiplied by 2 for commas for csv
/*** INITIALIZE VARIABLES ***/
String dataLine[dataTypes]; // Stores line of data for datalogger
SdFat SD;
SdFile File;
/*** FUNCTIONS ***/
/* Writes to datalog file */
void dataLogWrite(String data[])
String dataString = "";
for (int i = 0; i < dataTypes; i++)
dataString += data[i];
// open the file for write at end like the Native SD library
if (!File.open("test.csv", O_RDWR | O_CREAT | O_AT_END)) {
SD.errorHalt(F("opening test.csv for write failed"));
// if the file opened okay, write to it:
File.println(dataString);
// close the file:
File.close();
void setup(void)
/* see if the card is present and can be initialized: */
if (!SD.begin(chipSelect, SPI_FULL_SPEED)) {
Serial.println(F("Card failed, or not present"));
SD.initErrorHalt();
/* Initialise the sensor */
if(!accel.begin())
/* There was a problem detecting the ADXL345 ... check your connections */
Serial.println(F("No LSM303 detected"));
while(1);
if(!bmp.begin())
/* There was a problem detecting the BMP085 ... check your connections */
Serial.print(F("No BMP085 detected"));
while(1);
// Write column titles
dataLine[0] = F("Time(s)");
dataLine[1] = F(",");
dataLine[2] = F("x(m/s^2)");
dataLine[3] = F(",");
dataLine[4] = F("y(m/s^2)");
dataLine[5] = F(",");
dataLine[6] = F("z(m/s^2)");
dataLine[7] = F(",");
dataLine[8] = F("Temp(C)");
dataLine[9] = F(",");
dataLine[10] = F("Press(hPa)");
dataLine[11] = F(",");
dataLine[12] = F("Alt(m)");
dataLine[13] = F(",");
dataLogWrite(dataLine);
void loop(void)
/* Get a new sensor event */
sensors_event_t eventBaro;
sensors_event_t eventAccel;
accel.getEvent(&eventAccel);
bmp.getEvent(&eventBaro);
float temperature;
bmp.getTemperature(&temperature);
// Create new line of data
dataLine[0] = String(millis()/1000.0,4);
dataLine[2] = String(eventAccel.acceleration.x,4);
dataLine[4] = String(eventAccel.acceleration.y,4);
dataLine[6] = String(eventAccel.acceleration.z,4);
dataLine[8] = String(temperature,4);
dataLine[10] = String(eventBaro.pressure,4);
dataLine[12] = String(bmp.pressureToAltitude(seaLevelPressure,eventBaro.pressure),4);
Any suggestions on how to drastically improve the datalogging performance? I still need to implement the actual control logic which is the main purpose of the project.
Thanks!
