After prodding around the standard Arduino PID library, I decided to make an improved version that can be found here: ArduPID. It can also be installed via the libraries manager.
These are the improvements so far:
- More settings to configure your controller
- Added functions such as
start()
,reset()
,stop()
,reverse()
,setBias()
, andsetWindUpLimits()
- Added a debug function that can print any combination of various controller state data to the serial plotter/monitor for troubleshooting
- Trapezoidal integration is used compared to the sample and hold integration of the standard library
- Controllers are not constrained to a specific sample frequency - asynchronous calls of
compute()
will still result in valid outputs
Here is an example:
#include "ArduPID.h"
ArduPID myController;
double input;
double output;
// Arbitrary setpoint and gains - adjust these as fit for your project:
double setpoint = 512;
double p = 10;
double i = 1;
double d = 0.5;
myController.begin(&input, &output, &setpoint, p, i, d);
// myController.reverse() // Uncomment if controller output is "reversed"
// myController.setSampleTime(10); // OPTIONAL - will ensure at least 10ms have past between successful compute() calls
myController.setOutputLimits(0, 255);
myController.setBias(255.0 / 2.0);
myController.setWindUpLimits(-10, 10); // Groth bounds for the integral term to prevent integral wind-up
myController.start();
// myController.reset(); // Used for resetting the I and D terms - only use this if you know what you're doing
// myController.stop(); // Turn off the PID controller (compute() will not do anything until start() is called)
input = analogRead(A0); // Replace with sensor feedback
myController.compute();
myController.debug(&Serial, "myController", PRINT_INPUT | // Can include or comment out any of these terms to print
PRINT_OUTPUT | // in the Serial plotter
PRINT_SETPOINT |
PRINT_BIAS |
PRINT_P |
PRINT_I |
PRINT_D);
analogWrite(3, output); // Replace with plant control signal
If anyone has any improvements or finds any bugs, please let me know!
