The Button and Encoder input is easy.
What I’m working on is to be able to choose the next/previous characters with spaces and periods as needed.
Also I need functionality like shift and periods
Object is to use a LCD display to provide a user input with either buttons or encoder. the input would be for setting a password or other text based entries.
The following code works well but it seems to be messy and can be confusing.
The goals is to use a small footprint because of the memory limitations of the ATMEGA328p chip (UNO)
and be funcitonal.
At this time this code is the functioning correctly.
Parameters:
C: Character to start with
offset: any number positive or negative or even zero. will be constrained to increment only by 1 character
mode: Sets the available set of characters/numbers available to use
0 Numbers 9876543210
1 all zyxwvutsrqponmlkjihgfedcbaZYXWVUTSRQPONMLKJIHGFEDCBA9876543210
2 Letters only yxwvutsrqponmlkjihgfedcbaZYXWVUTSRQPONMLKJIHGFEDCBA
3 Numbers and Small Letters zyxwvutsrqponmlkjihgfedcba9876543210
4 Small Letters zyxwvutsrqponmlkjihgfedcba
5 Numbers and Capital Letters ZYXWVUTSRQPONMLKJIHGFEDCBA9876543210
6 Capital Letters ZYXWVUTSRQPONMLKJIHGFEDCBA
AddSpace: Makes a space or period available to choose from zyxwvutsrqponmlkjihgfedcba 9876543210.
SwitchCase: Either toggles between case when all letters are available or acts like s shift key when restricted to one case or the other.
Returns
altered character based on parameters.
char CharPicker(char C,int offset,int mode,bool AddSpace, bool SwitchCase){
static char LastC;
mode = constrain(mode, 0, 6);
char Limits[7][12]{// the following are jumps in the ASCii characters
{123,48, 91,48, 58,48, 47,57 , 96,57, 64,57 }, // 0 Numbers 9876543210.
{ 58,65, 91,97, 123,48, 47,122, 96,90, 64,57 }, // 1 all zyxwvutsrqponmlkjihgfedcba ZYXWVUTSRQPONMLKJIHGFEDCBA 9876543210.
{ 58,65, 91,97, 123,65, 64,122, 96,90, 64,122}, // 2 Letters only yxwvutsrqponmlkjihgfedcba ZYXWVUTSRQPONMLKJIHGFEDCBA
{ 58,97, 91,97, 123,48, 47,122, 96,57, 64,57 }, // 3 Numbers and Small Letters zyxwvutsrqponmlkjihgfedcba 9876543210.
{ 58,97, 91,97, 123,97, 96,122, 96,122, 64,122}, // 4 Small Letters zyxwvutsrqponmlkjihgfedcba
{ 58,65, 91,48, 123,48, 47, 90, 96,90, 64,57 }, // 5 Numbers and Capital Letters ZYXWVUTSRQPONMLKJIHGFEDCBA 9876543210.
{ 91,65, 91,65, 91,65, 64, 90, 64,90, 64,90 } // 6 Capital Letters ZYXWVUTSRQPONMLKJIHGFEDCBA
int x = (C>64) + (C > 96); // 0 = Num, 1 = Cap, 2 = Small
int y = (mode >= 3) + (mode >= 5); // 1 = Caps Only, 2 = Smalls Only
if ((y == 1) && (x == 1)) C = (C < 65) ? C : ((C >= 97) ? C - 32 : C + 32 ); // We are supposed to be Caps but we recieved a small letter
if ((y == 2) && (x == 2)) C = (C < 65) ? C : ((C >= 97) ? C - 32 : C + 32 ); // We are supposed to be Smalls but we recieved a Capital letter
if(AddSpace){
if((C == 32) || (C == 46)) { // last character was a space or a period.
C = LastC; // go back to the prior character.
char CC = C + constrain(offset, -1,1);
if (CC == 64 || CC == 96 || CC == 91 || CC == 123 ){ // Just outside letters
return(32);
if (CC == 47 || CC == 58){ // Just outside numbers
return(46);
C = C + constrain(offset, -1,1); //Change one letter
C = (C == Limits[mode][0]) ? Limits[mode][1]:((C == Limits[mode][2]) ? Limits[mode][3] : ((C >= Limits[mode][4]) ? Limits[mode][5] : C)); //Skip Non Letters and Numbers
C = (C <= Limits[mode][6]) ? Limits[mode][7]:((C == Limits[mode][8]) ? Limits[mode][9] : ((C == Limits[mode][10]) ? Limits[mode][11] : C)); //Skip Non Letters and Numbers
if (SwitchCase) {
C = (C < 65) ? C : ((C >= 97) ? C - 32 : C + 32 ); // Switch to other case
LastC = C; // Store current character
return(C);
Please post ideas as to how to refine this code and feel free to use my version or any alterations that come from this.
My test code:
char * MList[7] = {
" 0 Numbers"
," 1 all "
," 2 Letters"
," 3 NuSmall"
," 4 Small "
," 5 NuCaps "
," 6 Caps "};
static char C;
for (int Mode = 0; Mode <= 6; Mode++) {
for (int SwitchCase = 0; SwitchCase <= 1; SwitchCase++) {
for (int Dir = -1; Dir <= 1; Dir++) {
C = 0;
Serial.print(MList[Mode]);
Serial.print(F("\t Shift:"));
Serial.print(SwitchCase);
Serial.print(F("\t Direction:"));
Serial.print(Dir);
Serial.print(F("\t"));
delay(100);
for (int i = 0; i < 78; i++) {
C = CharPickerS(C, Dir, Mode,true, SwitchCase);
Serial.print(C);
while (1);
//Place complete function here:
Thanks in advance
