IMU 3000 problem
HI ^^
After reading all IMU 3000 posts, there was noch solution for my Problem.
Problem: My Programm initializes the IMU 3000 quite good, but I cant read any GYRO data or Acceleration Data through the IMU ( Only directly from the ADXL 345 ) .
I tried every Code I found and after that I programmed every Register as described in the Reference.
Pin 20 and Pin 21 at the IMU 3000 Fusion Board are connected. Pin 21 must not be connected to anything ( as described in reference) .
Could this be the problem ?
Thank you
Can you post your current code
and some link to the datasheet?
okay, heres my Code :slight_smile:
#include <Wire.h>
#include "ADXL_345_REGISTER.h"
#include "I2C.h"
#include "IMU_3000_REGISTER.h"
#include "Values.h"
 *       IMU 3000
 * Digital Input auf +-2000°/sec
 *   -> FS_SEL = 3
 *   -> Scale Factor = 16.4
 * Daten 16 Bit gross
 * Startup Time bei 50ms
 * Temperatur Offset = 35°C
#define SCALE_FACTOR 16.4
#define ANZAHL_BYTE 14
byte BUFF[14]={
  0,0,0,0,0,0,0,0,0,0,0,0,0,0};
int cleanBUFF[14]={
int ERGEBNISSE[7]={
  0, 0, 0, 0, 0, 0, 0};
float ERGEBNISSE_NACH_UMRECHNUNG[7]={
  0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0};
int ADXL_DIREKT[3] = {
  0,0,0};
int FIFO_ANZAHL = 0;
byte CHECK_TRANSMISSION[1] = {
  0b00000000};
unsigned long time=0;
void INIT_IMU()
  writeTo(IMU_ADDR,PWR_MGM,PWR_MGM_VALUE);
  readFrom(IMU_ADDR,PWR_MGM,1,CHECK_TRANSMISSION);
  if(PWR_MGM_VALUE == CHECK_TRANSMISSION[0])
    Serial.print(" PWR_MGM OK ");
    Serial.print(" PWR_MGM ERROR ");
  CHECK_TRANSMISSION[0] = 0b00000000;
  writeTo(IMU_ADDR,USER_CTRL,0b00000000); // ADXL direkt auf I2C zum initialisieren
  readFrom(IMU_ADDR,USER_CTRL,1,CHECK_TRANSMISSION);
  if(0b00000000 == CHECK_TRANSMISSION[0])
    Serial.print(" USER_CTRL OK ");
    Serial.print(" USER_CTRL ERROR ");
  INIT_ADXL();
  writeTo(IMU_ADDR,USER_CTRL,0b00001010);
  writeTo(IMU_ADDR,USER_CTRL,0b01101010); // Set FIFO rst when changing FIFO_EN
  writeTo(IMU_ADDR,FIFO_EN,FIFO_EN_VALUE);
  readFrom(IMU_ADDR,FIFO_EN,1,CHECK_TRANSMISSION);
  if(FIFO_EN_VALUE == CHECK_TRANSMISSION[0])
    Serial.print(" FIFO_EN OK ");
    Serial.print(" FIFO_EN ERROR ");
  writeTo(IMU_ADDR,USER_CTRL,USER_CTRL_VALUE);
  if(USER_CTRL_VALUE == CHECK_TRANSMISSION[0])
  writeTo(IMU_ADDR,X_OFFS_USERH,X_OFFS_USERH_VALUE);
  writeTo(IMU_ADDR,X_OFFS_USERL,X_OFFS_USERL_VALUE);
  writeTo(IMU_ADDR,Y_OFFS_USERH,Y_OFFS_USERH_VALUE);
  writeTo(IMU_ADDR,Y_OFFS_USERL,Y_OFFS_USERL_VALUE);
  writeTo(IMU_ADDR,Z_OFFS_USERH,Z_OFFS_USERH_VALUE);
  writeTo(IMU_ADDR,Z_OFFS_USERL,Z_OFFS_USERL_VALUE);
  writeTo(IMU_ADDR,AUX_VDDIO,AUX_VDDIO_VALUE);
  readFrom(IMU_ADDR,AUX_VDDIO,1,CHECK_TRANSMISSION);
  if(AUX_VDDIO_VALUE == CHECK_TRANSMISSION[0])
    Serial.print(" AUX_VDDIO OK ");
    Serial.print(" AUX_VDDIO ERROR ");
  writeTo(IMU_ADDR,AUX_SLV_ADDR,AUX_SLV_ADDR_VALUE);
  readFrom(IMU_ADDR,AUX_SLV_ADDR,1,CHECK_TRANSMISSION);
  if(AUX_SLV_ADDR_VALUE == CHECK_TRANSMISSION[0])
    Serial.print(" AUX_SLV_ADDR OK ");
    Serial.print(" AUX_SLV_ADDR ERROR ");
  writeTo(IMU_ADDR,SMPLRT_DIV,SMPLRT_DIV_VALUE);
  readFrom(IMU_ADDR,SMPLRT_DIV,1,CHECK_TRANSMISSION);
  if(SMPLRT_DIV_VALUE == CHECK_TRANSMISSION[0])
    Serial.print(" SMPLRT_DIV OK ");
    Serial.print(" SMPLRT_DIV ERROR ");
  writeTo(IMU_ADDR,AUX_BURST_ADDR,AUX_BURST_ADDR_VALUE);
  readFrom(IMU_ADDR,AUX_BURST_ADDR,1,CHECK_TRANSMISSION);
  if(AUX_BURST_ADDR_VALUE == CHECK_TRANSMISSION[0])
    Serial.print(" AUX_BURST_ADDR OK ");
    Serial.println(" AUX_BURST_ADDR ERROR ");
  writeTo(IMU_ADDR,DLPF_FS,DLPF_FS_VALUE);
  readFrom(IMU_ADDR,DLPF_FS,1,CHECK_TRANSMISSION);
  if(DLPF_FS_VALUE == CHECK_TRANSMISSION[0])
    Serial.print(" DLPF_FS OK ");
    Serial.print(" DLPF_FS ERROR ");
    Serial.print(CHECK_TRANSMISSION[0],DEC);
void INIT_ADXL()
  writeTo(ADXL_ADDR,POWER_CTL,0x00);
  writeTo(ADXL_ADDR,POWER_CTL,0x16);
  writeTo(ADXL_ADDR,POWER_CTL,POWER_CTL_VALUE);
  writeTo(ADXL_ADDR,FIFO_CTL,FIFO_CTL_VALUE);
  writeTo(ADXL_ADDR,INT_ENABLE,INT_ENABLE_VALUE);
void READ_IMU()
  readFrom(IMU_ADDR,TEMP_OUT_H,ANZAHL_BYTE,BUFF);
  cleanBUFF[0] = ((int)BUFF[0]<<8) & 0b1111111100000000;
  cleanBUFF[2] = ((int)BUFF[2]<<8) & 0b1111111100000000;
  cleanBUFF[4] = ((int)BUFF[4]<<8) & 0b1111111100000000;
  cleanBUFF[6] = ((int)BUFF[6]<<8) & 0b1111111100000000;
  cleanBUFF[8] = ((int)BUFF[8]<<8) & 0b1111111100000000;
  cleanBUFF[10] = ((int)BUFF[10]<<8) & 0b1111111100000000;
  cleanBUFF[12] = ((int)BUFF[12]<<8) & 0b1111111100000000;
  cleanBUFF[1] = ((int)BUFF[1]) & 0b0000000011111111;
  cleanBUFF[3] = ((int)BUFF[3]) & 0b0000000011111111;
  cleanBUFF[5] = ((int)BUFF[5]) & 0b0000000011111111;
  cleanBUFF[7] = ((int)BUFF[7]) & 0b0000000011111111;
  cleanBUFF[9] = ((int)BUFF[9]) & 0b0000000011111111;
  cleanBUFF[11] = ((int)BUFF[11]) & 0b0000000011111111;
  cleanBUFF[13] = ((int)BUFF[13]) & 0b0000000011111111;
  for(int i = 0; i<13;i++)
    ERGEBNISSE[i] = cleanBUFF[i] | cleanBUFF[i+1];
  for(int i = 1;i<4;i++)
    ERGEBNISSE_NACH_UMRECHNUNG[i] = (float)ERGEBNISSE[i]/16.4;
  for(int i = 4;i<7;i++)
    ERGEBNISSE_NACH_UMRECHNUNG[i] = (float)ERGEBNISSE[i]/256.0;
void GET_FIFO_COUNT()
  byte BUFF[2] = {
    0x0,0x0        };
  int cleanBUFF[2] = {
    0x00,0x00        };
  readFrom(IMU_ADDR,FIFO_COUNTH,2,BUFF);
  cleanBUFF[0] = ((int)BUFF[0]<<8) & 0b0000001100000000;
  FIFO_ANZAHL = cleanBUFF[0] | cleanBUFF[1];
  Serial.print(" FIFO COUNT : ");
  Serial.println(FIFO_ANZAHL);
void PRINT_VALUES(float VALUES[])
  Serial.print("TEMPERATUR: ");
  Serial.print(VALUES[0]);
  Serial.print(" GYRO X: ");
  Serial.print(VALUES[1]);
  Serial.print(" GYRO Y: ");
  Serial.print(VALUES[2]);
  Serial.print(" GYRO Z: ");
  Serial.print(VALUES[3]);
  Serial.print(" ACC X: ");
  Serial.print(VALUES[4]);
  Serial.print(" ACC Y: ");
  Serial.print(VALUES[5]);
  Serial.print(" ACC Z: ");
  Serial.print(VALUES[6]);
  Serial.print(" Bisherige Zeit ");
  Serial.println(time);
void READ_ADXL()
  byte wert[6]={
    0,0,0,0,0,0        };
  readFrom(ADXL_ADDR,DATAX0,6,wert);
  ADXL_DIREKT[0] = ((int)wert[1]<<8)|(int)wert[0];
  ADXL_DIREKT[1] = ((int)wert[3]<<8)|(int)wert[2];
  ADXL_DIREKT[2] = ((int)wert[5]<<8)|(int)wert[4];
  Serial.print("ADXL_DIREKT[0]: ");
  Serial.print(ADXL_DIREKT[0]);
  Serial.print(" ADXL_DIREKT[1]: ");
  Serial.print(ADXL_DIREKT[1]);
  Serial.print(" ADXL_DIREKT[2]: ");
  Serial.print(ADXL_DIREKT[2]);
void IMU_TEST()
  byte IDENTITAET[1] = {
    0        };
  readFrom(IMU_ADDR,WHO_AM_I,1,IDENTITAET);
  Serial.print(" Adresse des Geraets: ");
  Serial.println(IDENTITAET[0],DEC);
  Serial.begin(57600);
  Wire.begin();
  INIT_ADXL(); // Erst den ADXL initialisieren, da IMU danach die Daten ausliest
  INIT_IMU();
  IMU_TEST();
  delay(50);
  time = millis();
  if(time%40 <=2) // -> 25HZ
    PRINT_VALUES(ERGEBNISSE_NACH_UMRECHNUNG);
    READ_IMU();
    GET_FIFO_COUNT();
    //READ_ADXL(); //ADXL Direkt funktioniert
#ifndef IMU_3000_REGISTER
#define IMU_3000_REGISTER
#include "WProgram.h"
// IMU 3000
// Digital Input auf +-2000°/sec
//   -> FS_SEL = 3
//   -> Scale Factor = 16.4
// Daten 16 Bit groß
// Statup Time bei 50ms
// Temperatur Offset = 35°C
// IMU 3000 I²C Adresse
#define IMU_ADDR 0x68 // IMU_Reference S.30 = POWER-ON Value
// Register MAP IMU 3000:
#define WHO_AM_I 0x00
#define X_OFFS_USERH 0x0C
#define X_OFFS_USERL 0x0D
#define Y_OFFS_USERH 0x0E
#define Y_OFFS_USERL 0x0F
#define Z_OFFS_USERH 0x10
#define Z_OFFS_USERL 0x11
#define FIFO_EN 0x12     // TEMP_OUT GYRO_XOUT GYRO_YOUT GYRO_ZOUT AUX_XOUT AUX_YOUT AUX_ZOUT FIFO_FOOTER
Hope this helps a little bit....
The Datasheets are available at : SparkFun IMU Fusion Board - ADXL345 & IMU3000 - SEN-10252 - SparkFun Electronics
and heres the rest after fifo footer
#define AUX_VDDIO 0x13   // 0 0 0 0 0 AUX_VDDIO 0 0
#define AUX_SLV_ADDR 0x14    //CLKOUT_EN AUX_ID
#define SMPLRT_DIV 0x15
#define DLPF_FS 0x16
#define INT_CFG 0x17
#define AUX_BURST_ADDR 0x18
#define INT_STATUS 0x1A
#define TEMP_OUT_H 0x1B
#define TEMP_OUT_L 0x1C
#define GYRO_XOUT_H 0x1D
#define GYRO_XOUT_L 0x1E
#define GYRO_YOUT_H 0x1F
#define GYRO_YOUT_L 0x20
#define GYRO_ZOUT_H 0x21
#define GYRO_ZOUT_L 0x22
#define AUX_XOUT_H 0x23
#define AUX_XOUT_L 0x24
#define AUX_YOUT_H 0x24
#define AUX_YOUT_L 0x26
#define AUX_ZOUT_H 0x27
#define AUX_ZOUT_L 0x28
#define DMP_REG1 0x35
#define DMP_REG2 0x36
#define DMP_REG3 0x37
#define DMP_REG4 0x38
#define DMP_REG5 0x39
#define FIFO_COUNTH 0x3A
#define FIFO_COUNTL 0x3B
#define FIFO_R 0x3C
#define USER_CTRL 0x3D
#define PWR_MGM 0x3E
#endif
#ifndef ADXL_345_Register
#define ADXL_345_Register
// IMU 3000
//   -> FS_SEL = 3
// I2C Adresse des ADXL 345
#define ADXL_ADDR 0x53 // ADXL345 Reference Seite 10 ( alternate I²C address)
// Register MAP ADXL 345:
#define DEVID 0x00 //11100101 Device ID.
#define THRESH_TAP 0x1D //R/W 00000000 Tap threshold.
#define OFSX 0x1E //R/W 00000000 X-axis offset.
#define OFSY 0x1F //R/W 00000000 Y-axis offset.
#define OFSZ 0x20 //R/W 00000000 Z-axis offset.
#define DUR 0x21 //R/W 00000000 Tap duration.
#define Latent 0x22 //R/W 00000000 Tap latency.
#define Window 0x23 //R/W 00000000 Tap window.
#define THRESH_ACT 0x24 //R/W 00000000 Activity threshold.
#define THRESH_INACT 0x25 //R/W 00000000 Inactivity threshold.
#define TIME_INACT 0x26 //R/W 00000000 Inactivity time.
#define ACT_INACT_CTL 0x27 //R/W 00000000 Axis enable control for activity and inactivity detection.
#define THRESH_FF 0x28 //R/W 00000000 Free-fall threshold.
#define TIME_FF 0x29 //R/W 00000000 Free-fall time.
#define TAP_AXES 0x2A //R/W 00000000 Axis control for tap/double tap.
#define ACT_TAP_STATUS 0x2B //R 00000000 Source of tap/double tap.
#define BW_RATE 0x2C //R/W 00001010 Data rate and power mode control.
#define POWER_CTL 0x2D //R/W 00000000 Power-saving features control.
#define INT_ENABLE 0x2E //R/W 00000000 Interrupt enable control.
#define INT_MAP 0x2F //R/W 00000000 Interrupt mapping control.
#define INT_SOURCE 0x30 //R 00000010 Source of interrupts.
#define DATA_FORMAT 0x31 //R/W 00000000 Data format control.
#define DATAX0 0x32 //R 00000000 X-Axis Data 0.
#define DATAX1 0x33 //R 00000000 X-Axis Data 1.
#define DATAY0 0x34 //R 00000000 Y-Axis Data 0.
#define DATAY1 0x35 //R 00000000 Y-Axis Data 1.
#define DATAZ0 0x36 //R 00000000 Z-Axis Data 0.
#define DATAZ1 0x37 //R 00000000 Z-Axis Data 1.
#define FIFO_CTL 0x38 //R/W 00000000 FIFO control.
#define FIFO_STATUS 0x39 //R 00000000 FIFO status.
#endif
#ifndef I2C
#define I2C
*  I²C Funktionen
/* Schreiben an einen I²C Teilnehmer */
void writeTo(int Teilnehmer, byte Adresse, byte WertZuSenden)
  Wire.beginTransmission(Teilnehmer); //start transmission to ACC
  Wire.send(Adresse);        // send register address
  Wire.send(WertZuSenden);        // send value to write
  Wire.endTransmission(); //end transmission
/* Lesen von einem I²C Teilnehmer */
void readFrom(int Teilnehmer, byte Adresse, int AnzahlZuLesen, byte buff[]) {
  Wire.send(Adresse);        //sends address to read from
  Wire.requestFrom(Teilnehmer, AnzahlZuLesen);    // request 6 bytes from ACC
  int i = 0;
  while(Wire.available())    //ACC may send less than requested (abnormal)
    buff[i] = Wire.receive(); // receive a byte
    i++;
  if(i!= AnzahlZuLesen)
    Serial.print(" FEHLER BEIM LESEN: ");
    Serial.println(Teilnehmer);
/* Lesen vom Accelerometer /
void getAccelerometerData(int * result) {
  int regAddress = 0x32;    // Addresse von XL             ADXL345
  byte buff[A_TO_READ];
  readFrom(ACC, regAddress, A_TO_READ, buff); // Beschleunigungsdaten ADXL345
  result[0] = (((int)buff[1]) << 8) | buff[0];
  result[0] = result[0] & 0b0000001111111111;  // 10 Bit
  result[1] = (((int)buff[3])<< 8) | buff[2];
  result[1] = result[1] & 0b0000001111111111;
  result[2] = (((int)buff[5]) << 8) | buff[4];
  result[2] = result[2] & 0b0000001111111111;
/* Lesen vom Gyro /
void getGyroscopeData(int * result)
  int regAddress = 0x1B;
  int temp, x, y, z;
  byte buff[G_TO_READ];
  readFrom(GYRO, regAddress, G_TO_READ, buff); //16-bit ADCs
  result[0] = ((buff[2] << 8) | buff[3]) + g_offx;
  result[1] = ((buff[4] << 8) | buff[5]) + g_offy;
  result[2] = ((buff[6] << 8) | buff[7]) + g_offz;
  result[3] = (buff[0] << 8) | buff[1];
#endif
#ifndef Values
#define Values
*  Werte die benötigt werden um
*  die Geräte zu initialisieren
/****** 1. IMU 3000 *****************/
#define X_OFFS_H_VALUE 0 // 16 Bit Offset X High             Seite 30
#define X_OFFS_L_VALUE 0 // 16 Bit Offset X High             Seite 30
#define Y_OFFS_H_VALUE 0 // 16 Bit Offset X High             Seite 30
#define Y_OFFS_L_VALUE 0 // 16 Bit Offset X High             Seite 30
#define Z_OFFS_H_VALUE 0 // 16 Bit Offset X High             Seite 30
#define Z_OFFS_L_VALUE 0 // 16 Bit Offset X High             Seite 30
/***** FIFO wird benutzt *****/
#define FIFO_EN_VALUE 0b11111111 //TEMP_OUT GYRO_XOUT GYRO_YOUT GYRO_ZOUT AUX_XOUT AUX_YOUT AUX_ZOUT FIFO_FOOTER
/******* Accel I²C level *********/
#define AUX_VDDIO_VALUE 0b00000100 // VDD
/***** AccelSlaveAddress *****/
#define AUX_SLV_ADDR_VALUE 0xD3 // Addresse des Accelerometers mgl auch : 0x3A write; 0x3B write;
                               // 0xA6 write 0xA7 read 0x53|0b10000000 = CLK EN
/******** Sample Rate Divider *********/
#define SMPLRT_DIV_VALUE 0x00010101 // Errechnet aus Formel IMU Ref Seite 32
/******* Messbereich des IMU 3000 bestimmen ***********
*  FS_SEL = 0 : 250°/sec
*  FS_SEL = 1 : 500°/sec
*  FS_SEL = 2 : 1000°/sec
*  FS_SEL = 3 : 2000°/sec
*  IMU Reference Seite  33
/******* Tiefpassfilter des IMU 3000 bestimmen ********
*  DLPF_CFG: 0 Low Pass Filter Bandwidth: 256Hz Analog Sample Rate: 8kHz
*  DLPF_CFG: 1 Low Pass Filter Bandwidth: 188Hz Analog Sample Rate: 1kHz
*  DLPF_CFG: 2 Low Pass Filter Bandwidth: 98Hz  Analog Sample Rate: 1kHz
*  DLPF_CFG: 3 Low Pass Filter Bandwidth: 42Hz  Analog Sample Rate: 1kHz
*  DLPF_CFG: 4 Low Pass Filter Bandwidth: 20Hz  Analog Sample Rate: 1kHz
*  DLPF_CFG: 5 Low Pass Filter Bandwidth: 10Hz  Analog Sample Rate: 1kHz
*  DLPF_CFG: 6 Low Pass Filter Bandwidth: 5Hz   Analog Sample Rate: 1kHz
*  DLPF_CFG: 7 Reserved Reserved
#define DLPF_FS_VALUE 0b00011000 // 2000°/s 5Hz 1kHz
/******* Interrupt Konfiguration *********************
*  IMU Reference Seite 35
/******** Anfangsaddresse des ADXL345 für den IMU ****
#define AUX_BURST_ADDR_VALUE 0b00110010
/******** Konfiguration des IMU 3000 *****************
*  DMP aus                          0
*  FIFO an                          1
*  IMU als Master zum ADXL345 ein   1
*                                   0
*  Kein Reset des ADXL              0
*  kein DMP Reset                   0
*  FIFO nicht an                    0
*  kein Gyro Reset                  0
#define USER_CTRL_VALUE 0b01100000
//1. 0b00001010
// USER 0b01101010
// USER_CTRL_VALUE
/***** Energieeinstellungen des IMU 3000 *************
*  H_RESET                          0
*  SLEEP    kein standby            0
*  STBY_XG  kein gyro standby       0
*  STBY_YG  kein gyro standby       0
*  STBY_ZG  kein gyro standby       0
*  CLK_SEL  Internal Oscillator     000
#define PWR_MGM_VALUE 0b00000000
/*********** OFFSETS ********************************/
#define X_OFFS_USERH_VALUE 0
#define X_OFFS_USERL_VALUE 0
#define Y_OFFS_USERH_VALUE 0
#define Y_OFFS_USERL_VALUE 0
#define Z_OFFS_USERH_VALUE 0
#define Z_OFFS_USERL_VALUE 0
/****************** ADXL 345 *************************/
/********** OFFSETS ***************************/
#define OFSX_VALUE 0
#define OFSY_VALUE 0
#define OFSZ_VALUE 0
/*************** POWER CONTROL ****************/
/** Muss mehrfach konfiguriert werden
*   Endkonfiguration : 0x08 Measure = '1'     */
#define POWER_CTL_VALUE 0x08
/******************* FIFO ausschalten *********/
#define FIFO_CTL_VALUE 0x00
/**************** keine Interrupts ************/
#define INT_ENABLE_VALUE 0x00
#endif
PLease modify your post, select the code and press the # button, that makes it more readable.
Can you print the content of the buff directly ? // I allways use hexadecimal for 16 bit consts, dont know if 16 bits binary work.
Hi in my Code, I don't use the read_Accelerometer function, because I want to read the Accelerometer Data through my IMU 3000.
But Yes, I can read the ADXL345 directly without problems and good Values.
I just cant read out the IMU 3000.
I tried so many codes ....
In the reference is written, that you can always read out the Measurement Data out of the Registers that doesn't work too,
The Code I posted is a little Bit strange maybe, cause I tested some functions of the IMU:
  • Not in this Code: I enabled the FIFO. But the Value of the FIFO count REegister has always been zero.
Thank you ^^
Hi my Board works now.
After looking for a production mistake i found a soldering mistake at the imu 3000 pins (SMD) .
I disconnected both Pins with a scalpel.
Now it works !
Dear friends
I'm also dealing with the IMU-3000 now, but I don't know how to start. I am still a student, so maybe I have to learn more.
The question is where you write this code. I know we should write some program to read from the gyro, but how can we put that code into the gyro. Moreover, do you have some guide lines which we can follow to read data from the Gyro and the accelerometer?
regards,
