IMU based mobile robot.
hello everyone…i am new to programming… i have an arduino UNO and adafruit BNO055 imu breakout board…has am getting output X,Y,Z in serial monitor…i dont know what to do with it…to do a mobile robot which moves in a straight line for some given distance. i hope you friends can help me with this.
and i also have chassis,2 x dc motor, L293D driver ic.
Thanking You…
What exactly is being measured to give you the X, Y and Z values bearing in mind that the IMU has 9 degrees of freedom (gyroscope, accelerometer and geomagnetic) ?
When the IMU is stationary you get a value for say X. What happens to that value when you move the IMU in the X direction then stop? What happens to the value when you move the IMU in the opposite direction then stop ?
hlo UKHeliBob...
will you show some example code for imu based mobile robot..so i can see what data they have used....toturial links are welcome as well..
Thanking you
Sorry but I don't have any such code
Which library are you using and does it come with any examples ?
am having Adafruit BNO055 module.... check it out..they have some code with library.
Thanking you
I have no way of checking it out. I have no idea where to find the library or which example you are using.
If you want help then then post a link to the library and the code that you are using but read read this before posting a programming question first and follow the advice it contains with respect to formatting the code and using code tags when posting it.
