IMU Value tracking
i would please like some help with obtaining a Yaw value initially and keep it.
So i am using a motor carrier that makes use of the BNO055 orientation sensor and produces the the yaw , pitch and roll. So i would like to a assign a variable to an initial yaw value and that variable should not change even through the current yaw value is changing.
So what is the problem ?
Read the sensor
Save the value in a variable
Don't change the variable again
The obvious place to do the initial reading is in the setup() function
