in 18 days stop motor loop!
i use this code to rotate a motor
//2-Way motor control
int motorPin1 =  5;    // One motor wire connected to digital pin 5
int motorPin2 =  6;    // One motor wire connected to digital pin 6
int sixHours = 21600;
boolean changeRotation = false;
boolean oneTime = true;
unsigned long previousMillis = 0;
unsigned long currentMillis = 0;
// The setup() method runs once, when the sketch starts
  // initialize the digital pins as an output:
  pinMode(motorPin1, OUTPUT);
  pinMode(motorPin2, OUTPUT);
  currentMillis = millis();
  if((unsigned long) (currentMillis - previouwMillis) >= sixHours
      changeRotation = !changeRotation ;
  if((changeRotation == true) && (oneTime == true))
      rotateLeft(1500, 100000);
      oneTime = false;//
  else if((changeRotation == false) && (oneTime == false))
      rotateRight(1500, 100000);
      oneTime = true;
void rotateLeft(int speedOfRotate, int length)
  analogWrite(motorPin1, speedOfRotate); //rotates motor
  digitalWrite(motorPin2, LOW);    // set the Pin motorPin2 LOW
  delay(length); //waits
  digitalWrite(motorPin1, LOW);    // set the Pin motorPin1 LOW
void rotateRight(int speedOfRotate, int length)
  analogWrite(motorPin2, speedOfRotate); //rotates motor
any help how to stop the loop : 1 555 200 000 milliseconds = 18 days
Moderator edit: quote tags swapped for CODE TAGS. I'm really getting bored with this now.
18UL * 24 UL * 60UL * 60UL * 1000UL fits easily in an unsigned long.
If you need exact timing, you'll need an RTC.
