In a function show me error, 'x' was not declared in this scope
In an array byte, according to Packet[1] i want to:
if ((Packet[1] | 0x7F) == 0x7F)
{for (byte x = 2; x <= y; x++)
{ Packet[x]; Functions(); } //Show me packets from Packet[2] to y
if((Packet[1] & 0xC0) == 0xC0)
{for (byte x = 3; x <= y; x++)
{ Packet[x]; Functions(); } //Show me packets from Packet[3] to y
void Functions()
Serial.print(Packet[x], HEX);
Serial.print(" ");
Serial.println("End");
But it is not working.
It show me error here: Serial.print(Packet[x], HEX);
What can i do ?
I add
byte x;
before error and it is working .
billys7:
I add
byte x;
That's how you declare it!
Working? Compiling more like. You need to pass "x" to the function.
http://snippets-r-us.com/
I can't understand it!
Please edit your post, select the code, and put it between [code] ... [/code] tags.
You can do that by hitting the # button above the posting area.
What is this doing?
More like:
Functions(Packet[x]);
void Functions(byte c)
       Serial.print(c, HEX);
       Serial.print(" ");
You are right,
I thought that if i will copy all the code will be boring for someone to read it.
Thank you!
Your comment and your code do not match. What do you think this is doing?
It's equivalent to
   47;
   Functions();
which makes no sense, since Functions() (a stupid name, by the way) takes an argument and you are not supplying one.
billys7:
Not as boring as trying to guess what you are doing.
I have borrow this code. The original works fine, if you want to read the packets.
I am trying to partially extract some infos from the code
Here is the main code :
byte dccPacket[6]; // buffer to hold a packet - shared with A_dccGetPacket.ino
word Address;
word CV = 210;
  Serial.println("Starting ReadDccPackets.ino");
  pinMode(3, OUTPUT);  //Function 1
  pinMode(4, OUTPUT);  //Function 1
  pinMode(5, OUTPUT);  //Function 1
  pinMode(6, OUTPUT);  //Function 1
  pinMode(7, OUTPUT);  //Function 1
  pinMode(8, OUTPUT);  //Function 1
  //PWM :pin 9
  //CS: pin 10
  //MOSI: pin 11
  //MISO: pin 12
  //SCK: pin 13
  //Reverse : pin A0
  //Forward : pin A1
  pinMode(A2, OUTPUT);  //Function 1
  pinMode(A3, OUTPUT);  //Function 1
  pinMode(A4, OUTPUT);  //Function 1
  //BEMF : pin A5
  beginBitDetection();
   getPacket();
   showValidPacket();
void showValidPacket()
{  // this only shows packets with valid check sums
  byte pktByteCount = dccPacket[0];
  if (pktByteCount == 0) {
    return;
  byte checksum = 0;
  for (byte n = 1; n <= pktByteCount; n++) {    //Starts from dccPacket[1] and increment till the No of the packets, pktByteCount
     checksum ^= dccPacket[n];                  //checksum (error detection byte) is the XOR of the dccPackets[1 - n]
  if (checksum) {
//    Serial.println("Invalid Checksum");
    return;
   //--------------------------Get Address------------------------------------------
    if ((dccPacket[1] | 0x7F) == 0x7F)                             //Bitwise OR to read the Most Significant bit (first left) and if it is 0
        { Address = dccPacket[1];}                                 //then it is Short Address - Baseline  CV1
       else                                                        //else
        {  if(((dccPacket[1] & 0xC0) == 0xC0)&&(dccPacket[1]!=255))//Bitwise AND to read if the first two bits (first left) are 11, and the remaining not 111111
              { Address = word(dccPacket[1]-192,dccPacket[2]); }   //then it is Extended Address CV17 - CV18
        }   //εδω μάλλον λειπει η εντολή που θα μας στείλει πάλι στην αρχή. Να δοκιμάσω και το switch - case.
  //---------------------------End Address------------------------------------------
  if (Address == CV)
  //--------------------------Get Data and Functions--------------------------------
        if ((dccPacket[1] | 0x7F) == 0x7F)                          //Get Data Byte from dccPacket[2] to dccPacket[n-1]
            {for (byte n = 2; n < pktByteCount; n++)
                  { Functions(dccPacket[n]); }
        if(((dccPacket[1] & 0xC0) == 0xC0)&&(dccPacket[1]!=255))   //Get Data Byte from dccPacket[3] to dccPacket[n-1]
              {for (byte n = 3; n < pktByteCount; n++)
void Functions(byte n)
       {Serial.print(dccPacket[n], HEX);
       Serial.print(" ");}
       Serial.println("=End=");
Unfortunately i can't make it to work correct.
From the last part -----Get Data and Functions------- i want to read only the data bytes.
If the dccPacket[1] starts from 0 then data bytes are from dccPacket[2] to n-1,
If the dccPacket[1] starts from 11 then data bytes are from dccPacket[3] to n-1,
You didn't do what I suggested in reply #5.
void Functions(byte myByte)
       Serial.print(myByte, HEX);
       Serial.print(" ");
Calling a function "Functions" is like calling a variable "Variables" and a constant "Constants".
Can't you think of a better name?
Ok. I understood it.
Thank you!
