in and out puts
Hi there, I'm building a and logic gate circuit with 2 switches, and 1 LED. How can I do this?
I have it programed as one switch then just hard wired in another, but ideally I'm hoping when I press one button it will send a signel to the board to give power to another port. Then the power can run from this port to the next switch. Any ideas how I can do this?
Thanks
if (digitalRead(inputPin) == LOW)  //adjust the logic to match your input wiring
  digitalWrite(outputPin, HIGH);
EDIT
As has been pointed out the code above is wrong. It should be
@HeliBob:
Is the plan to never have outputPin LOW again ?
Then you just have to replace the first closing brace } by an opening one {
Of course you can also alternatively simulate a wire by some code and two wires:
digitalWrite (outputPin, digitalRead(inputPin) );
@lukeob123:
"switch" and "button" are equivalent,
"port" is what we usually call "pin"
"power" means some voltage level
What's the Arduino got to do with this?
Mark
Simply put the two switches in series, then wire one end to the +ve and the other end to the resistor and LED and finally the LED to ground.
However I suspect that is not your problem, it is this:- X-Y Problem
Thanks for the help, I'll try that in a while hopefully I get it working
