In Arduino ide 2.3.2 if i am enable bluetooth i am getting error in libaries
C:/Users/dhana/AppData/Local/Arduino15/packages/esp32/tools/esp-x32/2405/bin/../lib/gcc/xtensa-esp-elf/13.2.0/../../../../xtensa-esp-elf/bin/ld.exe: C:\Users\dhana\AppData\Local\Temp\arduino\sketches\0131BC7572C082E0EA6F18340FFA8C4F\libraries\BluetoothSerial\BluetoothSerial.cpp.o:(.literal._ZL16_spp_send_bufferv+0x18): undefined reference to `esp_spp_write'
C:/Users/dhana/AppData/Local/Arduino15/packages/esp32/tools/esp-x32/2405/bin/../lib/gcc/xtensa-esp-elf/13.2.0/../../../../xtensa-esp-elf/bin/ld.exe: C:\Users\dhana\AppData\Local\Temp\arduino\sketches\0131BC7572C082E0EA6F18340FFA8C4F\libraries\BluetoothSerial\BluetoothSerial.cpp.o:(.literal._ZL8_stop_btv$isra$0+0x8): undefined reference to `esp_spp_disconnect'
C:/Users/dhana/AppData/Local/Arduino15/packages/esp32/tools/esp-x32/2405/bin/../lib/gcc/xtensa-esp-elf/13.2.0/../../../../xtensa-esp-elf/bin/ld.exe: C:\Users\dhana\AppData\Local\Temp\arduino\sketches\0131BC7572C082E0EA6F18340FFA8C4F\libraries\BluetoothSerial\BluetoothSerial.cpp.o:(.literal._ZL8_stop_btv$isra$0+0xc): undefined reference to `esp_spp_deinit'
C:/Users/dhana/AppData/Local/Arduino15/packages/esp32/tools/esp-x32/2405/bin/../lib/gcc/xtensa-esp-elf/13.2.0/../../../../xtensa-esp-elf/bin/ld.exe: C:\Users\dhana\AppData\Local\Temp\arduino\sketches\0131BC7572C082E0EA6F18340FFA8C4F\libraries\BluetoothSerial\BluetoothSerial.cpp.o:(.literal._ZN15BluetoothSerial5beginE6Stringbb+0x38): undefined reference to `esp_bt_gap_register_callback'
C:/Users/dhana/AppData/Local/Arduino15/packages/esp32/tools/esp-x32/2405/bin/../lib/gcc/xtensa-esp-elf/13.2.0/../../../../xtensa-esp-elf/bin/ld.exe: C:\Users\dhana\AppData\Local\Temp\arduino\sketches\0131BC7572C082E0EA6F18340FFA8C4F\libraries\BluetoothSerial\BluetoothSerial.cpp.o:(.literal._ZN15BluetoothSerial5beginE6Stringbb+0x3c): undefined reference to `esp_spp_register_callback'
C:/Users/dhana/AppData/Local/Arduino15/packages/esp32/tools/esp-x32/2405/bin/../lib/gcc/xtensa-esp-elf/13.2.0/../../../../xtensa-esp-elf/bin/ld.exe: C:\Users\dhana\AppData\Local\Temp\arduino\sketches\0131BC7572C082E0EA6F18340FFA8C4F\libraries\BluetoothSerial\BluetoothSerial.cpp.o:(.literal._ZN15BluetoothSerial5beginE6Stringbb+0x40): undefined reference to `esp_spp_enhanced_init'
C:/Users/dhana/AppData/Local/Arduino15/packages/esp32/tools/esp-x32/2405/bin/../lib/gcc/xtensa-esp-elf/13.2.0/../../../../xtensa-esp-elf/bin/ld.exe: C:\Users\dhana\AppData\Local\Temp\arduino\sketches\0131BC7572C082E0EA6F18340FFA8C4F\libraries\BluetoothSerial\BluetoothSerial.cpp.o:(.literal._ZN15BluetoothSerial5beginE6Stringbb+0x44): undefined reference to `esp_bt_gap_set_device_name'
C:/Users/dhana/AppData/Local/Arduino15/packages/esp32/tools/esp-x32/2405/bin/../lib/gcc/xtensa-esp-elf/13.2.0/../../../../xtensa-esp-elf/bin/ld.exe: C:\Users\dhana\AppData\Local\Temp\arduino\sketches\0131BC7572C082E0EA6F18340FFA8C4F\libraries\BluetoothSerial\BluetoothSerial.cpp.o:(.literal._ZN15BluetoothSerial5beginE6Stringbb+0x48): undefined reference to `esp_bt_gap_set_security_param'
C:/Users/dhana/AppData/Local/Arduino15/packages/esp32/tools/esp-x32/2405/bin/../lib/gcc/xtensa-esp-elf/13.2.0/../../../../xtensa-esp-elf/bin/ld.exe: C:\Users\dhana\AppData\Local\Temp\arduino\sketches\0131BC7572C082E0EA6F18340FFA8C4F\libraries\BluetoothSerial\BluetoothSerial.cpp.o:(.literal._ZN15BluetoothSerial5beginE6Stringbb+0x4c): undefined reference to `esp_bt_gap_set_cod'
C:/Users/dhana/AppData/Local/Arduino15/packages/esp32/tools/esp-x32/2405/bin/../lib/gcc/xtensa-esp-elf/13.2.0/../../../../xtensa-esp-elf/bin/ld.exe: C:\Users\dhana\AppData\Local\Temp\arduino\sketches\0131BC7572C082E0EA6F18340FFA8C4F\libraries\BluetoothSerial\BluetoothSerial.cpp.o:(.literal._ZL13esp_bt_gap_cb21esp_bt_gap_cb_event_tP21esp_bt_gap_cb_param_t+0x38): undefined reference to `esp_bt_gap_resolve_eir_data'
C:/Users/dhana/AppData/Local/Arduino15/packages/esp32/tools/esp-x32/2405/bin/../lib/gcc/xtensa-esp-elf/13.2.0/../../../../xtensa-esp-elf/bin/ld.exe: C:\Users\dhana\AppData\Local\Temp\arduino\sketches\0131BC7572C082E0EA6F18340FFA8C4F\libraries\BluetoothSerial\BluetoothSerial.cpp.o:(.literal._ZL13esp_bt_gap_cb21esp_bt_gap_cb_event_tP21esp_bt_gap_cb_param_t+0x40): undefined reference to `esp_bt_gap_cancel_discovery'
C:/Users/dhana/AppData/Local/Arduino15/packages/esp32/tools/esp-x32/2405/bin/../lib/gcc/xtensa-esp-elf/13.2.0/../../../../xtensa-esp-elf/bin/ld.exe: C:\Users\dhana\AppData\Local\Temp\arduino\sketches\0131BC7572C082E0EA6F18340FFA8C4F\libraries\BluetoothSerial\BluetoothSerial.cpp.o:(.literal._ZL13esp_bt_gap_cb21esp_bt_gap_cb_event_tP21esp_bt_gap_cb_param_t+0x4c): undefined reference to `esp_spp_start_discovery'
C:/Users/dhana/AppData/Local/Arduino15/packages/esp32/tools/esp-x32/2405/bin/../lib/gcc/xtensa-esp-elf/13.2.0/../../../../xtensa-esp-elf/bin/ld.exe: C:\Users\dhana\AppData\Local\Temp\arduino\sketches\0131BC7572C082E0EA6F18340FFA8C4F\libraries\BluetoothSerial\BluetoothSerial.cpp.o:(.literal._ZL13esp_bt_gap_cb21esp_bt_gap_cb_event_tP21esp_bt_gap_cb_param_t+0x50): undefined reference to `esp_bt_gap_pin_reply'
C:/Users/dhana/AppData/Local/Arduino15/packages/esp32/tools/esp-x32/2405/bin/../lib/gcc/xtensa-esp-elf/13.2.0/../../../../xtensa-esp-elf/bin/ld.exe: C:\Users\dhana\AppData\Local\Temp\arduino\sketches\0131BC7572C082E0EA6F18340FFA8C4F\libraries\BluetoothSerial\BluetoothSerial.cpp.o:(.literal._ZL13esp_bt_gap_cb21esp_bt_gap_cb_event_tP21esp_bt_gap_cb_param_t+0x54): undefined reference to `esp_bt_gap_ssp_confirm_reply'
C:/Users/dhana/AppData/Local/Arduino15/packages/esp32/tools/esp-x32/2405/bin/../lib/gcc/xtensa-esp-elf/13.2.0/../../../../xtensa-esp-elf/bin/ld.exe: C:\Users\dhana\AppData\Local\Temp\arduino\sketches\0131BC7572C082E0EA6F18340FFA8C4F\libraries\BluetoothSerial\BluetoothSerial.cpp.o:(.literal._ZL10esp_spp_cb18esp_spp_cb_event_tP18esp_spp_cb_param_t+0x24): undefined reference to `esp_bt_gap_set_scan_mode'
C:/Users/dhana/AppData/Local/Arduino15/packages/esp32/tools/esp-x32/2405/bin/../lib/gcc/xtensa-esp-elf/13.2.0/../../../../xtensa-esp-elf/bin/ld.exe: C:\Users\dhana\AppData\Local\Temp\arduino\sketches\0131BC7572C082E0EA6F18340FFA8C4F\libraries\BluetoothSerial\BluetoothSerial.cpp.o:(.literal._ZL10esp_spp_cb18esp_spp_cb_event_tP18esp_spp_cb_param_t+0x28): undefined reference to `esp_spp_start_srv'
C:/Users/dhana/AppData/Local/Arduino15/packages/esp32/tools/esp-x32/2405/bin/../lib/gcc/xtensa-esp-elf/13.2.0/../../../../xtensa-esp-elf/bin/ld.exe: C:\Users\dhana\AppData\Local\Temp\arduino\sketches\0131BC7572C082E0EA6F18340FFA8C4F\libraries\BluetoothSerial\BluetoothSerial.cpp.o:(.literal._ZL10esp_spp_cb18esp_spp_cb_event_tP18esp_spp_cb_param_t+0x2c): undefined reference to `esp_spp_connect'
C:/Users/dhana/AppData/Local/Arduino15/packages/esp32/tools/esp-x32/2405/bin/../lib/gcc/xtensa-esp-elf/13.2.0/../../../../xtensa-esp-elf/bin/ld.exe: C:\Users\dhana\AppData\Local\Temp\arduino\sketches\0131BC7572C082E0EA6F18340FFA8C4F\libraries\BluetoothSerial\BluetoothSerial.cpp.o: in function `_spp_send_buffer()':
C:\Users\dhana\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.0\libraries\BluetoothSerial\src/BluetoothSerial.cpp:174:(.text._ZL16_spp_send_bufferv+0x32): undefined reference to `esp_spp_write'
C:/Users/dhana/AppData/Local/Arduino15/packages/esp32/tools/esp-x32/2405/bin/../lib/gcc/xtensa-esp-elf/13.2.0/../../../../xtensa-esp-elf/bin/ld.exe: C:\Users\dhana\AppData\Local\Temp\arduino\sketches\0131BC7572C082E0EA6F18340FFA8C4F\libraries\BluetoothSerial\BluetoothSerial.cpp.o: in function `_ZL8_stop_btv$isra$0':
C:\Users\dhana\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.0\libraries\BluetoothSerial\src/BluetoothSerial.cpp:734:(.text._ZL8_stop_btv$isra$0+0x13): undefined reference to `esp_spp_disconnect'
C:/Users/dhana/AppData/Local/Arduino15/packages/esp32/tools/esp-x32/2405/bin/../lib/gcc/xtensa-esp-elf/13.2.0/../../../../xtensa-esp-elf/bin/ld.exe: C:\Users\dhana\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.0\libraries\BluetoothSerial\src/BluetoothSerial.cpp:736:(.text._ZL8_stop_btv$isra$0+0x19): undefined reference to `esp_spp_deinit'
C:/Users/dhana/AppData/Local/Arduino15/packages/esp32/tools/esp-x32/2405/bin/../lib/gcc/xtensa-esp-elf/13.2.0/../../../../xtensa-esp-elf/bin/ld.exe: C:\Users\dhana\AppData\Local\Temp\arduino\sketches\0131BC7572C082E0EA6F18340FFA8C4F\libraries\BluetoothSerial\BluetoothSerial.cpp.o: in function `BluetoothSerial::begin(String, bool, bool)':
C:\Users\dhana\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.0\libraries\BluetoothSerial\src/BluetoothSerial.cpp:670:(.text._ZN15BluetoothSerial5beginE6Stringbb+0xfe): undefined reference to `esp_bt_gap_register_callback'
C:/Users/dhana/AppData/Local/Arduino15/packages/esp32/tools/esp-x32/2405/bin/../lib/gcc/xtensa-esp-elf/13.2.0/../../../../xtensa-esp-elf/bin/ld.exe: C:\Users\dhana\AppData\Local\Temp\arduino\sketches\0131BC7572C082E0EA6F18340FFA8C4F\libraries\BluetoothSerial\BluetoothSerial.cpp.o: in function `_init_bt':
C:\Users\dhana\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.0\libraries\BluetoothSerial\src/BluetoothSerial.cpp:677:(.text._ZN15BluetoothSerial5beginE6Stringbb+0x10a): undefined reference to `esp_spp_register_callback'
C:/Users/dhana/AppData/Local/Arduino15/packages/esp32/tools/esp-x32/2405/bin/../lib/gcc/xtensa-esp-elf/13.2.0/../../../../xtensa-esp-elf/bin/ld.exe: C:\Users\dhana\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.0\libraries\BluetoothSerial\src/BluetoothSerial.cpp:693:(.text._ZN15BluetoothSerial5beginE6Stringbb+0x126): undefined reference to `esp_spp_enhanced_init'
C:/Users/dhana/AppData/Local/Arduino15/packages/esp32/tools/esp-x32/2405/bin/../lib/gcc/xtensa-esp-elf/13.2.0/../../../../xtensa-esp-elf/bin/ld.exe: C:\Users\dhana\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.0\libraries\BluetoothSerial\src/BluetoothSerial.cpp:695:(.text._ZN15BluetoothSerial5beginE6Stringbb+0x131): undefined reference to `esp_bt_gap_set_device_name'
C:/Users/dhana/AppData/Local/Arduino15/packages/esp32/tools/esp-x32/2405/bin/../lib/gcc/xtensa-esp-elf/13.2.0/../../../../xtensa-esp-elf/bin/ld.exe: C:\Users\dhana\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.0\libraries\BluetoothSerial\src/BluetoothSerial.cpp:707:(.text._ZN15BluetoothSerial5beginE6Stringbb+0x164): undefined reference to `esp_bt_gap_set_security_param'
C:/Users/dhana/AppData/Local/Arduino15/packages/esp32/tools/esp-x32/2405/bin/../lib/gcc/xtensa-esp-elf/13.2.0/../../../../xtensa-esp-elf/bin/ld.exe: C:\Users\dhana\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.0\libraries\BluetoothSerial\src/BluetoothSerial.cpp:716:(.text._ZN15BluetoothSerial5beginE6Stringbb+0x16f): undefined reference to `esp_bt_gap_set_cod'
C:/Users/dhana/AppData/Local/Arduino15/packages/esp32/tools/esp-x32/2405/bin/../lib/gcc/xtensa-esp-elf/13.2.0/../../../../xtensa-esp-elf/bin/ld.exe: C:\Users\dhana\AppData\Local\Temp\arduino\sketches\0131BC7572C082E0EA6F18340FFA8C4F\libraries\BluetoothSerial\BluetoothSerial.cpp.o: in function `esp_bt_gap_cb(esp_bt_gap_cb_event_t, esp_bt_gap_cb_param_t*)':
C:\Users\dhana\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.0\libraries\BluetoothSerial\src/BluetoothSerial.cpp:129:(.text._ZL13esp_bt_gap_cb21esp_bt_gap_cb_event_tP21esp_bt_gap_cb_param_t+0x11e): undefined reference to `esp_bt_gap_resolve_eir_data'
C:/Users/dhana/AppData/Local/Arduino15/packages/esp32/tools/esp-x32/2405/bin/../lib/gcc/xtensa-esp-elf/13.2.0/../../../../xtensa-esp-elf/bin/ld.exe: C:\Users\dhana\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.0\libraries\BluetoothSerial\src/BluetoothSerial.cpp:473:(.text._ZL13esp_bt_gap_cb21esp_bt_gap_cb_event_tP21esp_bt_gap_cb_param_t+0x170): undefined reference to `esp_bt_gap_cancel_discovery'
C:/Users/dhana/AppData/Local/Arduino15/packages/esp32/tools/esp-x32/2405/bin/../lib/gcc/xtensa-esp-elf/13.2.0/../../../../xtensa-esp-elf/bin/ld.exe: C:\Users\dhana\AppData\Local\Temp\arduino\sketches\0131BC7572C082E0EA6F18340FFA8C4F\libraries\BluetoothSerial\BluetoothSerial.cpp.o: in function `get_name_from_eir':
C:\Users\dhana\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.0\libraries\BluetoothSerial\src/BluetoothSerial.cpp:131:(.text._ZL13esp_bt_gap_cb21esp_bt_gap_cb_event_tP21esp_bt_gap_cb_param_t+0x1fe): undefined reference to `esp_bt_gap_resolve_eir_data'
C:\Users\dhana\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.0\libraries\BluetoothSerial\src/BluetoothSerial.cpp:474:(.text._ZL13esp_bt_gap_cb21esp_bt_gap_cb_event_tP21esp_bt_gap_cb_param_t+0x25a): undefined reference to `esp_spp_start_discovery'
C:/Users/dhana/AppData/Local/Arduino15/packages/esp32/tools/esp-x32/2405/bin/../lib/gcc/xtensa-esp-elf/13.2.0/../../../../xtensa-esp-elf/bin/ld.exe: C:\Users\dhana\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.0\libraries\BluetoothSerial\src/BluetoothSerial.cpp:536:(.text._ZL13esp_bt_gap_cb21esp_bt_gap_cb_event_tP21esp_bt_gap_cb_param_t+0x41a): undefined reference to `esp_bt_gap_pin_reply'
C:/Users/dhana/AppData/Local/Arduino15/packages/esp32/tools/esp-x32/2405/bin/../lib/gcc/xtensa-esp-elf/13.2.0/../../../../xtensa-esp-elf/bin/ld.exe: C:\Users\dhana\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.0\libraries\BluetoothSerial\src/BluetoothSerial.cpp:546:(.text._ZL13esp_bt_gap_cb21esp_bt_gap_cb_event_tP21esp_bt_gap_cb_param_t+0x444): undefined reference to `esp_bt_gap_ssp_confirm_reply'
C:/Users/dhana/AppData/Local/Arduino15/packages/esp32/tools/esp-x32/2405/bin/../lib/gcc/xtensa-esp-elf/13.2.0/../../../../xtensa-esp-elf/bin/ld.exe: C:\Users\dhana\AppData\Local\Temp\arduino\sketches\0131BC7572C082E0EA6F18340FFA8C4F\libraries\BluetoothSerial\BluetoothSerial.cpp.o: in function `esp_spp_cb(esp_spp_cb_event_t, esp_spp_cb_param_t*)':
C:\Users\dhana\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.0\libraries\BluetoothSerial\src/BluetoothSerial.cpp:248:(.text._ZL10esp_spp_cb18esp_spp_cb_event_tP18esp_spp_cb_param_t+0x7e): undefined reference to `esp_bt_gap_set_scan_mode'
C:/Users/dhana/AppData/Local/Arduino15/packages/esp32/tools/esp-x32/2405/bin/../lib/gcc/xtensa-esp-elf/13.2.0/../../../../xtensa-esp-elf/bin/ld.exe: C:\Users\dhana\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.0\libraries\BluetoothSerial\src/BluetoothSerial.cpp:253:(.text._ZL10esp_spp_cb18esp_spp_cb_event_tP18esp_spp_cb_param_t+0x9b): undefined reference to `esp_spp_start_srv'
C:/Users/dhana/AppData/Local/Arduino15/packages/esp32/tools/esp-x32/2405/bin/../lib/gcc/xtensa-esp-elf/13.2.0/../../../../xtensa-esp-elf/bin/ld.exe: C:\Users\dhana\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.0\libraries\BluetoothSerial\src/BluetoothSerial.cpp:274:(.text._ZL10esp_spp_cb18esp_spp_cb_event_tP18esp_spp_cb_param_t+0x196): undefined reference to `esp_spp_connect'
C:/Users/dhana/AppData/Local/Arduino15/packages/esp32/tools/esp-x32/2405/bin/../lib/gcc/xtensa-esp-elf/13.2.0/../../../../xtensa-esp-elf/bin/ld.exe: C:\Users\dhana\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.0\libraries\BluetoothSerial\src/BluetoothSerial.cpp:298:(.text._ZL10esp_spp_cb18esp_spp_cb_event_tP18esp_spp_cb_param_t+0x212): undefined reference to `esp_spp_disconnect'
C:/Users/dhana/AppData/Local/Arduino15/packages/esp32/tools/esp-x32/2405/bin/../lib/gcc/xtensa-esp-elf/13.2.0/../../../../xtensa-esp-elf/bin/ld.exe: C:\Users\dhana\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.0\libraries\BluetoothSerial\src/BluetoothSerial.cpp:383:(.text._ZL10esp_spp_cb18esp_spp_cb_event_tP18esp_spp_cb_param_t+0x2fe): undefined reference to `esp_spp_disconnect'
collect2.exe: error: ld returned 1 exit status
Multiple libraries were found for "BluetoothSerial.h"
  Used: C:\Users\dhana\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.0\libraries\BluetoothSerial
  Not used: C:\Users\dhana\Documents\Arduino\libraries\BluetoothSerial
exit status 1
Compilation error: exit status 1
can anyone knows help mw
Welcome dhanalakshmi_4567
Your topic does not immediately indicate a problem with IDE 2.x and hence has been moved to the Programming section of the forum.
Which board are you compiling for?
Please provide your sketch; do not forget to use code tags as described in https://forum.arduino.cc/t/how-to-get-the-best-out-of-this-forum/679966#posting-code-and-common-code-problems.
In future, please also use code tags for error messages. I have added them to your post so it's easier to read and copy.
#include "BluetoothSerial.h"
BluetoothSerial SerialBT;
SerialBT.begin("ESP32test"); // Bluetooth device name
Serial.println("The device started, now you can pair it with Bluetooth!");
if (Serial.available()) {
SerialBT.write(Serial.read()); // Send data from Serial Monitor to Bluetooth
if (SerialBT.available()) {
Serial.write(SerialBT.read()); // Send data from Bluetooth to Serial Monitor
} for these if add bluetoothserial libary also the above code is not compiling for esp32s3
What don't you understand about that?
BluetoothSerial uses Bluetooth Classic. ESP32S3 does not support Classic, only BLE.
Take a look at ESP32_BleSerial.
You already have a reply by oqibidipo to explain it.
I could reproduce your problem. Next I compiled one of the BluetoothSerial examples for the ESP32S3 and got the following error
#error Serial Bluetooth not available or not enabled. It is only available for the ESP32 chip.
